Question about Mitsubishi MSH09TW Air Conditioner
Mitsubishi Air Conditioner blinking Problem
In Mitsubishi Air Conditioner in Inverter type, Its timer indicator shows 6 times blinking and outdoor not run, how can i solve this problem?
  • 2 more comments
  • Anonymous Mar 01, 2017
    This indoor single not coming outdoor uint you check fancoil one by one outdoor unit not problem good
  • Anbu Anbu
    Anbu Anbu May 20, 2017
    Check read
  • Dinesh Kumar
    Dinesh Kumar Jun 05, 2018
    Run light 4time and run +time light 4tiime that is the problem
  • SK Suleman
    SK Suleman Jun 07, 2018
    six times blinking outdoor not run mitshubishi heavy duty inverter ac
    Problem Solver:
Mitsubishi inverter timer flash
Posted on Jul 27, 2013
  • Mitsubishi Master
  • 43,501 Answers
Here is where you can find all the info you will ever need about Mitsubishi Air Conditioning units...
Check out this tip that I wrote about that...
Mitsubishi Air Conditioner Troubleshooting and Repair
http://www.fixya.com/support/r5643983-mitsubishi_air_conditioner
heatman101
Posted on Aug 20, 2010
  • noe eulalio
    noe eulalio Mar 08, 2014
    what caous of blingking timer
Mitsubishi timer light 6 times blinking
Indoor unit indicator
RUN lamp = 6 time flash
TIMER lamp = Comes on
Outdoor unit indicator (LED5) = Stays off
Description of trouble = Indoor fan motor error (2)
Cause = Defective fan motor, Connector poor connection
Conditions of flashing = When air conditioner is operating and indoor fan motor is turned ON, indoor fan motor speed of 400 rpm or under continued for more than 30 seconds. (Air conditioner stops.)
May 29, 2016 | Mitsubishi Heating & Cooling
We have fujitsu inverter plasma airconditioner mpdelastb09ldc ths fan runs but timer light blinks 3 times but outdoor does not start
Hi Rajneel,
I hope this link is of some help to you
Good luck
http://www.climatecenter.co.uk/wcsstore/ClimateCenter/Attachment/downloads/fujitsu-trouble.pdf
Feb 10, 2015 | Fujitsu Heating & Cooling
E4 Error Code
Could be overheating and a sensor is triggering the machine to turn off or it could be short of gas. Check all pipework connections for tightness and especially look for oily residue on any of them. This would indicate a leak. Unfortunately, if there is a leak, you would require a licensed air con Tech to repair the leak and regas it.
Apr 09, 2014 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi air conditioner flashing timer light flashes twice
Switch the polarity of the control voltage...make sure it matches with the indoor & outdoor unit
Dec 18, 2013 | Mitsubishi Heating & Cooling
I have a Panasonic air conditioner model CU-E12EKU (inverter). The unit stop working and the timer indicator is blinking. I checked for this error and followed the instructions in the Operating Manual,...
Not sure if yours has a letter 'H' before the 16 but if it does, it's the:
- Outdoor Current Transformer open circuit.
which means that your outdoor controller board is faulty.
Sep 08, 2011 | Panasonic Heating & Cooling
I have 3 aircndition mitsubishi heavy industry one
heatman101
Aug 09, 2010 | Whirlwind FH-778 Air Conditioner
U4 System transmission between indoor and outdoor units Daikin
Sounds like an interconnecting wiring error. Check wiring connection i.e. wires are connected in right order 1 to1 2 to 2 etc. from indoor terminal board to outdoor terminal board. Also check for slack or loose connections.
Hope this helps I take the time to answer your question so please rate me
May 28, 2010 | Cfm Daikin R410a Split System Air...
Panasonic air conditioner CS-E24GKR...The unit stops and the timer indicator blinks. Also displays error code H 11...Help...Please...its hot in here
H-11Indoor / outdoor abnormal communication. Check • Internal / external cable connections
• Indoor / Outdoor PCB
Jan 04, 2010 | Panasonic CS-A12C Air Conditioner
Panasonic Inverter CS-E12EKU timer indicator blink. The unit not work at all, I follow the manual instructions using the remote control but the instructions are not clear. Using other similar Panasonic...
Today I install a new unit Panasonic CS-S13KKP also have a same problem timer blink and the outdoor unit wont start. Error code is 11. after checking the problem, can not using a 3 cable cord, solve the problem using 4 Cable cord and its run !
Victor
Aug 21, 2009 | Panasonic Heating & Cooling
Mitsubishi MSH09TW Air Conditioner Logo
8,921 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
