Question about Cell Phones
3100key pad problem only no5not working - Cell Phones
All guages and tach work no speedometer no lights 91 pont bonn se
body{padding: 10px;}#Post p {margin: 0px; padding: 0px;}#Post ul{padding: 0px;margin: 0px;list-style-position: inside;}body{padding: 10px;}#Post p {margin: 0px; padding: 0px;}#Post ul{padding: 0px;margin: 0px;list-style-position: inside;}may need a speed senser in transmission or a problem with instrument cluster instrument cluster may need to be replaced
Feb 14, 2013 | 1991 Pontiac Bonneville
Hotpoint microwave key pad parcially not working
The pads actually share some of the same lines inside the touch pad. There are silver oxide traces inside there. If a trace inside breaks, it depends on which trace breaks as to what pads dont work. If a trace that is common to say pads 1,3,5,7 you would lose function of those pads. 1.....2.....3.....4......5....... it is sort of set up like that inside wher eone connects to another and so on. So lets say a line between 2 and 3 breaks then you would lose pads 3, 4, 5 and any others on that same line. Will have to replace touch pad, cannot repair.
Oct 15, 2017 | Hotpoint JE740WY/GY Microwave Oven
My microwave oven WMG187EG digital key pad does not work properly
The only way possible to see if the touch pads are working is to test the voltage of the control pads when it contacts. The input of the Microprocessor should be checked for the pad control impulse to come in. If there is no trigger voltage to the mP this can be the control pad problem.
The mP must be checked for the working voltage and also the frequency oscillation at the crystal leads. If so the mP is working with a suspected control pads which are not able to set the program or timing.
There is no way but to remove the sticker pad and replace, One difficult way to have a chance is to remove the carbon sticker pads and check continuity , You can use a carbon pen to line the tracks so that the multi-meter reads a continuity. With this you can have a temporary fix
Jul 22, 2011 | Westpoint Microwave Ovens
The touch pads of my microwave are not functioning
In most cases if the pads are not working it must be replaced, some times the carbon tracks that are worn out can be repaired temporarily.The only way possible to see if the touch pads are working is to test the voltage of the control pads when it contacts. The input of the Microprocessor should be checked for the pad control inpulse to come in. If there is no trigger voltage to the mP this can be the control pad problem.
The mP must be checked for the working voltage and also the frequency oscillation at the crystal leads. If so the mP is working with a suspected control pads which is not able to set the program or timing.
There is no way but to remove the sticker pad and replace, One difficult way to have a chance is to remove the carbon sticker pads and check continuity , You can use a carbon pen to line the tracks so that the multimeter reads a continuity. With this you can have a temporary fix
Jul 05, 2011 | Microwave Ovens
I have a Pelican dance pad compatible with Gamecube/XBox/Playstation DDR games. Plugging into port 1 of the GC Port on my Wii, I can play DDR Hottest Party 1/2/3 with no problems in any mode, but it...
me too. i get this problem . i have a wii dance pad that has a gamecube connector , and i guess the DDR doesn't detect it as a dance pad , but as a gamecube controller . so think , you can't hold the nunchuck and the gamecube controller at the same time . so i guess we need a wireless dance pad for the nunchuck to work as well .
Apr 23, 2011 | Konami Video Game Consoles & Games
Lenovo n500 laptop ... mouse pad not working
The mouse pad maybe faulty or the ribbon cable from the mouse pad to the motherboard may not be properly connected. Reseat this cable.
You can connect an USB optical mouse to the laptop. I prefer you use a USB mouse all the time over the mouse pad.
Sep 29, 2009 | Lenovo 3000 N500 Notebook
Oven touch pad not working properly.
Hi. this will only get worse. i would replace this defective touch pad asap if possible.
Jun 23, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
360 dance pad not working on xbox
try plugging your usb connector into the usb port located in the back of your xbox 360 next to the power cable coneccion
Mar 31, 2009 | Konami Dance Revolution DDR Original Dance...
N81 8gb,keypad lock switch not working
check kep pad connector
or - chnga ic
Mar 26, 2009 | Nokia N81 Smartphone
N73 D pad
for me replacing the pad is good but you analyze first, you can do first is to clean the pad and try if it is working but if not you replace the pad
Aug 10, 2008 | Nokia N73 Cellular Phone
Cell Phones Logo
18 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
