Question about Adtran NetVanta 3200 Router
How to configure dhcp in a netvanta 3200?
I need help setting up dhcp in a netvanta router
3 Suggested Answers
SOURCE: Can not ping our netvanta 3200 from behind a Linksys nat router
The switch between the NAT routers and the Netvanta had some faulty ports ... the physical connection was broken. Once the switch was replaced, the internet connection was restored.
Posted on Dec 30, 2009
SOURCE: setting timezones on Netvanta 3200 router
clock auto-correct-dst
clock timezone -5-Eastern-Time
clock set 23:58:00 05 May 2010
Posted on May 06, 2010
How do I factory default adtran netvanta 1224st?
Every router has a reset button on it.
Try to find that button and press it for 30 Second.
It will reset your router to factory setting.
I hope it will help you.
Thanks for using FixYa.
May 19, 2011 | Adtran NetVanta 1224ST PoE w/ UK power...
Is there a way to perform local password recovery on a Netvanta 3200 router?
can you not reset it, there should be a small hole at the back of the router
just push the point of a pen in the hole and that should reset it..
Nov 24, 2010 | Adtran NetVanta 3200 Router
Can't connect Dell TrueMobile 1184 with Adtran NetVanta 3200
It sounds like you need to "crossover" the connection.
Using a crossover patch cable to connect the two devices is the first thing that comes to mind. (http://en.wikipedia.org/wiki/Ethernet_crossover_cable)
However, some routers/switches have physical buttons on ports to cross them over or you can use their web-based management to change port settings.
I hope this helps.
Jan 27, 2010 | Adtran NetVanta 3305 Router
Dec 29, 2009 | Adtran NetVanta 3200 Router
Password apparently lost on Netvana 3200 - any hidden reset?
http://kb.adtran.com/display/2n/articleDirect/index.asp?aid=1786&r=0.6352198
connect console cable
Bootstrap# bypass passwords
Bootstrap# boot
Oct 20, 2009 | Adtran NetVanta 3200 Router
Setting timezones on Netvanta 3200 router
Aug 28, 2009 | Adtran NetVanta 3200 Router
Netvanta reset password
Enter admin as the username, enter your admin password, and click the OK button. (The default password is
password.) Here is a link to your manual:
http://www.wedophones.com/Manuals/Adtran/NetVanta%202000%20Series%20Quick%20Start%20Guide%20(Rev%20B)%202nd%20gen.pdf
May 25, 2009 | Adtran NetVanta 3200 Router
Zyxel modem and wrt54g modem
You need to put the zyxel p600 into bridged mode
Mar 26, 2009 | Linksys Wireless-G WRT54G Router
RE: My posted. Connecting DSL/Router to DIR-628 internet router
Installing a router to work as the second one on a home networkrequires special configuration. Do the following on the second routerto ensure it (and the devices attached) function properly:1. Connect as local device or bridge - If connecting the second router via Ethernet cable, plug it into one of the LAN ports on the first router. If connecting the second router wirelessly, ensure the second router is set for client mode.Note that some home wireless routers do not support client mode; thesemust be connected by cable. Check your router documentation for detailson its client mode configuration support.
2. Check / change IP address - Most home network routers use a default IP addresssetting. Often, these default IP addresses will not work in a tworouter environment. Check the second router's IP address value andreset it if necessary to work within the valid address range of thefirst router (and to not conflict with any other device on the network).
3. Disable DHCP- To avoid IP address conflicts between all of the devices on the homenetwork, only one of your two routers should assign addresses via DHCP. All mainstream routers provide an option to disable DHCP as part of the router's configuration screens.
(My netgear router supports client mode. The 2wire supports bridged and router mode. My 2wire is the main router. I set up my netgear using my laptop. Once you change the address on the router.. You will only be able to directly access through the main router to the 2701.)
Configure your 2701 IP address to a static address in the 192.168.2.1 range and diable DHCP. Only 1 router can run the DHCP service. To disable Dhcp on the 2701.... log on to 2701> click on home network>advanced settings>uncheck enable DHCP>Next section is Public routed subinterface...Check enable and Aout Firewall Open>Input your main router address and mask>save config..
This worked with the Netgear router.. May not with your router. Good Luck! Hope this helps!
Jan 16, 2009 | 2wire 2700HG-B Router (2700HGB)
Configuring remote access
Here is a document which describes this.
Please download, it then:
1. Connect the console.
2. Configure ip address of the router
3. Enable telnet access.
Here is the document location:
http://www.adtran.com/adtranpx/Doc/0/UL9SGGEDF2I4D51F3K4IIEE2FC/61202860L1-13B.pdf
Jan 09, 2009 | Adtran NetVanta 3200 Router
Adtran NetVanta 3200 Router Logo
464 people viewed this question
Top Adtran Computers & Internet Experts
Gareth Tomlinson
Gareth Tomlinson
Jax Planet
Jax Planet
Are you an Adtran Computer and Internet Expert? Answer questions, earn points and help others
