Question about RIM BlackBerry ® 8830 Cellular Phone
How do I stop the blue flashing light...I don't use blue tooth
Thanks
    Problem Solver:
  • 7 Answers
Visit this site and try hard reset
Posted on Oct 25, 2009
My nokia n70 bluetooth is telling me unable to perfome bluetooth operation what is solution
Hi, Most Nokia phone all have similar problem about blue tooth operation failing.
What prompt "Operation failed" is when there an application on your phone , and an application your transferred through blue tooth or any other means has contacted Virus and it's affecting the blue tooth operation.
Solutions to this problem is to restore the blue tooth device back to normal by flashing the phone.
Flashing of phone restore back the lost or corrupted data on phones.To flash a phone, you will need to purchase a device used for flashing of phones. But to save you the cost of purchasing a flashing machine, i would advice you go to the nearest phone repair store around you for assistance. Skill personnel.
Thanks for using fixya..................
Jan 06, 2011 | Nokia N70 Cellular Phone
I don"t know how to put my blue tooth in discoverable mode
Try this:
1. With your headset turned on, simultaneously
press the listen volume adjust button marked
+ (volume up) and the call control button.
Release the buttons when the indicator light
begins to flash red then blue.
2. While the headset is flashing red and blue,
use the phone menu to search for Bluetooth
devices and select "510 Plantronics".
3. When prompted for password, enter 0000.
The headset will flash blue when paired
successfully.
Don't forget to rate if this was helpful :-)
Sep 19, 2010 | Plantronics Explorer 230 Bluetooth Headset
I am having problems connecting my plantronics explorer 390 to my black berry curve
First turn your Blue Tooth setting to "ON" on your Black Berry Curve, as it searches for a Blue Tooth Device, Push and hold on the middle button of the Blue Tooth until you see a flashing "blue light & red light." It's important that you see both flashing lights.
May 19, 2010 | Plantronics Explorer 390 Bluetooth Headset
I cannot connect bluetooth headset,please tellme how to connect
Hi and thank you for using fixya:
1- go to communication settings on your phone and turn blue tooth on and on discoverable mode
2- press down blue tooth button down until light flashes repeatedly
3- cellphone should show that it found a blue tooth device and it will ask you if you want to connect
4- say yes and it will ask you for a code or password
5- here are some standard passwords
1234 0000 00000
thank you and good luck
Mar 20, 2010 | Logitech Bluetooth Wireless Talking Kit...
Jabra VBT2050 Not detecting
On The Blue Tooth You Have To Hold The On Off Till The Light Flash's Blue Red Over And Over Then Search For It On Your Phone.
Once You Find It It Will Be Recognized For Now On. Just Hit The Button On The Blue Tooth One More Time To Stop The Sync Mode.
Jan 19, 2009 | Jabra BT350 Bluetooth Headset Headset
Syncing the HFBLU-10K with the iphone
for iphone : set your phone to scan for wireless device
1 unlock
2 settings icon
3 general
4 bluetooth ON
the hold the big button on the blue tooth once it flashes blue DO NOT LET GO! keep holding it till it flashs red and blue red and blue then let go and it should find it instantly then press on the BK-600 word and enter the 0000 code and you should be all set.
Jan 06, 2009 | Cellular Innovations HFBLU-CX1 Wireless...
Instuctions
1. Turn on the blue tooth headset
2. Press both volumes keys together so light flashes red/green
3. turn on phones blue tooth
4. Find device and select.
Jul 15, 2008 | Sony Ericsson Akono HBH-300 Consumer...
Plantronics 220 blue tooth
Another bang bang solution...
Be sure to charge your headset for atleast 15-25 minutes minimum to get a starting charge. This will also give you 15-30 minutes of talk time to test out your headset and placement, and also get used to being a part of the bluetooth generation.
Once charged, press the call button(the big button on the side) and hold it down until you see a flashing red/blue combination of lights, now you only have 2 minutes to set this up, or you have to start over.
Once the lights are flashing on the headset, it is searching for a phone, now you go to your phone, and find your options for connectivity or bluetooth, once in your menu, look for the option to search or connect to a blue tooth device. Let it search/connect automatically.
Once it is connected, the flashing lights on your headset should stop, finish the connect process on your phone, if it says found it, install it, entering device data, etc etc, follow everything it says by entering YES, hitting OK, or CONTINUE.
Once it says CODE or PASSWORD to enter for your bluetooth device, enter 0000 .Which is ZERO ZERO ZERO ZERO and then press enter.
It should take 2-10 seconds for the password to initiate, record into your phone, and pair your device. This is a detailed explanation. Please rate me for my effort.
ManOwar
Dec 31, 2007 | Plantronics - Bluetooth Headset Plus Base...
Bluetooth pairing
1.Explore blue tooth devices from your motorola phone.
2.it will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on
4.in pairing function select your blue tooth headset
Dec 22, 2007 | Motorola Mobility Bluetooth Hands Free...
RIM BlackBerry ® 8830 Cellular Phone Logo
65 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
