Question about Minka -Aire Brushed Nickel Remote Control Fan MIA F518-BN
Minka Aire Fan will not reverse.
The only way to reverse the fan is with the remote. It slows as though it is about to reverse and then speed up with out reversing, then slows again to the low speed it was set in.
    New Friend:
My fan is a concept II and it had the same behavior. I called Minka Aire support about this - they said it was either the reverse module or the receiver. They sent me both no charge! I replaced them and now my fan reverses. i am not an electrician, but the replacement was fairly easy. Just made sure to disconnect 1 wire at a time, connect it to the new wire, etc until I was done. Minka Aire support said they would walk me through it on the phone but I didn't need them to.
Posted on Dec 10, 2012
    New Friend:
Me me does the same thing, if I press and hold the reverse it will slow the blades like its reversing but then it speeds right back up.
What I've found is that as it starts to slow I have to press the reverse button slowly and firmly 2 or 3 more times and I can usually hear the "switch" and then the blades will actually reverse and be set...
Frustrating as it isn't what the instructions say to do
Posted on Nov 26, 2016
SOURCE: minka aire concept II ceiling fan bulb replacement
I found that the minka website has the installation manuals online.
www.minkagroup.net/http://www.minkagroup.net/minkaairemanuals.asp The glass cover on a Concept I fans turns counterclockwise. I had to use rubber gloves to get a good grip on the light cover.
Posted on May 03, 2008
  • 10865 Answers
SOURCE: Como Fan MInka Aire light bulb burned out
remove the cover and unscrew the bulb. get a replacement especially designed for a ceiling fan.
Posted on Sep 07, 2009
  • 13 Answers
SOURCE: Noisey Minka Aire Napoli ceiling fans
Minka fan are life time warrantied, have you tried contacting customer service... Minka fans motors have a very simply design... uninstall the fan... try balancing the fan on a table or some where that allows you to remove the shell that covers the main body of the fan... Carefully (someone that is very familiar with the electrical components.) soft wire the fan allowing you to see the motor as the blades turn... You will then see what is making the scraping noise... I may have some extra fan parts that you can easily replace... If you like to write me at payitforwardx2 @ gmail . com I am willing to try to further assist you...
Posted on Apr 23, 2010
alpug
  • 1961 Answers
SOURCE: Minka Aire Concept II Wet fan with remote control.
the electronic board of your fan must be check.there are triac transistors that switch the motor to it variable speed check the triac and replace it if you find it faulty.there 3 triac found on it these rae the switches of 3 speeds you can compare the resistance reading of all of the 3 triacs to determine which triac is faulty...good luck.
Posted on May 31, 2011
SOURCE: I have a Minka Aire
I have the same problem! Please post if you find a solution and I'll do the same.
Posted on Jul 26, 2011
Why can't I control fan speed with remote?
Either has a bad receiver or bad capacitor. Call Minka aire @ 1-800-307-3267
Mar 31, 2016 | Minka Aire F803-TL Artemis? Fan
My Minka Aire ceiling fan has a wall mount remote and now will not reverse
call Minka Aire @ 1-800-307-3267. You might need a new receiver.
Sep 23, 2014 | Minka Dryers
I have a Minka Aire Concept 1 which has been programmed to operate from a different frequency than nearby fans with remotes. The light goes on and off by itself at will and goes off each and every tim
Does your neighbor have a remote fan? Check wattage of bulbs to make sure they're the correct wattage. Still not working correctly, call 1-800-307-3267 (Minka Aire)
Sep 20, 2014 | Minka Aire Ceiling Fan
Minka Aire model f603 reverse switch?
Not sure what model of fan or manufacture you have. Says Hunter 52" & Minka aire F603. If it's the Minka , Then push the button on the lower part of the remote (6 o'clock). If that doesn't work then you might need a new receiver.
Jul 23, 2014 | Hunter 52" Ceiling Fan With Light And...
Minka Aire Ceiling Fan light wont come on
Probably needs a new remote receiver.Contact Minka Aire @ 1-800-307-3267
Apr 30, 2013 | Minka Aire Ceiling Fan
Some functions of switch stopped working
Sounds like you need a NEW RECEIVER. Call 1-800-307-3267(Minka Aire)
Feb 13, 2013 | Minka Aire Ceiling Fan
Mika aire remote fan
Not sure if this addresses your problem or not, but with my Minka Aire ceiling fans, the fan has to be moving in order to change the fan direction. Turn the fan on (any speed works), then push the reverse button. The fan will speed up to max, then you'll hear the gears switching. The fan will slow to a stop, change directions and get back up to speed in the new direction.
Oct 03, 2008 | Fanimation Bon Aire White Remote Control -...
Minka -Aire Brushed Nickel Remote Control Fan MIA F518-BN Logo
4,122 people viewed this question
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Are you a Minka Dryer Expert? Answer questions, earn points and help others
