Question about Vivitar DVR-550 DV Camcorder
My Vivitar DVR840XHD don't recharge anymore when
My Vivitar DVR840XHD don't recharge anymore when connected wiith usb to my Pc
The owners manual says "unit will not charge w/ usb connected to the computer." "charge only with the supplied adapter".
Posted on Dec 01, 2009
How I can charge my batteries on my Vivitar Vivicam 8025 if I don't have a battery charger?
Yes, you may charge the battery through the USB connection. Bear in mind that not all computer USB ports put out enough current to charge batteries. You may also use an AC-powered USB charger, such as used for some cell phones.
Dec 13, 2012 | Vivitar ViviCam 8025 Digital Camera
Turn it on,don't know if it even works.
Hi There
I assume you found this camera and don't have any information about it.
Here is a link to download the manual.
http://www.retrevo.com/support/Vivitar-3710-Digital-Cameras-manual/id/200ag804/t/2/
If you don't have a cord to connect it to your computer, you can purchase one:
http://www.amazon.com/Vivitar-ViviCam-3710-USB-Cable/dp/B003HMVENA
Hope this helps!
Jul 26, 2011 | Vivitar ViviCam 3710 Digital Camera
No problems, just need to print the manual. Thanks
You can download a printable manual from the manufacturer's web site at
http://www.vivitar.com/files_products/31/DVR840XHD%20User%20Manual.pdf
Apr 24, 2011 | Vivitar DVR 840XHD Digital Video Recorder
Need the insruction manual for the vivitar dvr840xhd
Apr 10, 2011 | Vivitar DVR 840XHD Digital Video Recorder
How do you recharge camera battery? camera manual is not clear abot how to hook up battery charger or even where it is!
The easiest way is by using a standard USB cable...plug the small end of the USB cable into your camera (located under the headphone jack) then plug the larger end of the USB cable into your PC or laptop. Turn on your computer & this will charge up your Vivitar 550.
Dec 27, 2009 | Vivitar DVR-550 DV Camcorder
Vivitar DVR 545 - Is this going to work with my MacBook?
I have a VIvitar DVR 545 I can not find out how to recharge the rechargable battery
I just bought this camera and had the same problem.
How DO you charge the battery???!!!
Here goes:
Open the box the camera came in and you should find a little rectangualr black box and a 3-pin plug.
Ignore the other stuff unless you think you may need it (depends what country you're in and what your mains supply wall socket fittings are). Take a close look at the little rectangualr black box and you'll see a slot in it. That's where your battery goes! Remember the battery must be taken out of the camera and slotted into this box! Make sure you align the battery correctly to the litle pins inside the box.
The Vivitar DVR 545 uses a sort of mobile phone/cell phone battery.You must take the battery OUT of the camera. Now you have slotted the battery into the box you connect the 3-pin plug to the box and then insert the plug (attached to the box) into your wall mains supply socket. The box will light up and you'll see a red light. Once this light turns green your camera battery is charged!
RE-INSERT THE BATTERY INTO THE CAMERA.
The whole charging procedure for the DVR 545 is ridiculous but there it is! By the way one drawback about having to remove the battery from the camera to charge it is that you will lose all or most of your camera settings. remember to reset video and photo settings - resolution, flash etc., etc.
Also a word of caution:
The Vivitar DVR 550 is unusual in that the battery is charged using the USB port. If you also happen to have a DVR 550 do NOT attempt to charge the Vivitar 545 using the Vivitar DVR 550 USB charger cable!
You will destroy your DVR 545 in seconds!!!!
Jul 09, 2008 | Cameras
Charger will not fit anymore
If you got a USB cable with the unit, you can connect to your PC and recharge the battery that way. Just be sure to have the power switch turned ON. The screen on the player will indicate its connected and you should see the battery indicator in the lower right corner showing a charging condition (bar moving)
Feb 12, 2008 | Audio Players & Recorders
Vivitar DVR-550 DV Camcorder Logo
295 people viewed this question
Top Vivitar Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
 John
John
Are you a Vivitar Video Camera Expert? Answer questions, earn points and help others
