Question about Logitech 9311570403 Mouse
The wheel is not working as far as scrolling goes
    Problem Solver:
  • 6 Answers
Maybe u have yore toolbar to big at bottom just click it 2 hide it or youre fonts r on to large
Posted on Sep 30, 2009
Scrolling problem
your scroll wheel is most likely of track
Jul 14, 2013 | Dynex Wireless Optical Mouse
When i'm trying to use the scrolling wheel it just
go control panel --click on mouse right click to get properties
check compatibility tab
adjust scroll speed to suit
Dec 17, 2017 | Saitek GM3200 Mouse
MOUSE CAME APART INCLUDING SPRINGS HOW DO I PUT IT BACK TOGETHER
The Spring goes on the right side of the mouse wheel as it would be pointing at your computer. It supports the wheel to make it spring back when preasure is applied. Place the spring on the axle with the spring forming an spread out "A" (not a "V"). You will see that it falls nicely into the 2 little tower mounts. my real problem was with the other little piece of bent wire that fell out. This is the part that makes the snaping fealing as you scroll the wheel. This connects directly on the plastic part that is mounted on the scroll wheel. If you look at that plastic part you will see a small hole. One end goes in that hole & the other rounded end goes to the splines on the wheel itself. I hope this helps, it better that just saying go buy another.
Allen
Sep 19, 2009 | Dell OPTICAL MOUSE SILVER BLACK WITH...
Scroll mouse is choppy when I am trying to scroll. It sometimes even goes back up. Very irritating.
Try going into your Control Panel, go into the Mouse controls, and change the wheel scroll settings. There's a "lines to scroll" option that determines how much or little the wheel moves the page. Try changing this number up or down and see if the problem gets any better. Does the scroll wheel feel OK? is it sticky or hard to turn? is it smooth and loose?
May 18, 2009 | GE 97985 Mouse
Spring placement for scroll wheel
Found an answer with pictures on the site.
Mar 26, 2009 | Logitech Cordless TrackMan Wheel...
Scroller goes up when scrolling down
This works for all mice.
click the scroll button and movie it up and down for a while and it will work just fine.
i had the same problem with my acer mouse but when i looked at a forum for the mac os x mouse someone said this tip and it worked
Oct 27, 2008 | Dell U0636 Mouse
72214 manual
I have a Kensington Model K72214 Mouse. The dial does not work properly: instead of scrolling it spins. Also I am wondering where the on/off switch is on this.
Rich
Aug 25, 2008 | Kensington PocketMouse 72214
Exposure wheel does not seem to have the proper range.
the scroll button is already losing contact that why is not working properly..use a lighter fluid to the button then roll up and down untill the button is clean don't put to much fluid ok...
Aug 06, 2008 | Sony Handycam CCD-TRV68 Camcorder
TrackMan Wheel Trackball Spring - where does it go.
it's not really a spring -- it's just a twisted piece of wire. actually, it's what makes your little scroll wheel click when you turn it. place the scrool wheel in the little plastic bracket that holds it with the longest piece of axel (hollow side of wheel) in. then TURN THE BRACKET OVER. the wire goes on the BOTTOM, which is quite counterintuitive. you'll see how it goes -- the smallest end of the wire goes INSIDE the scroll wheel and the kinda squared end of the wire goes into a little hole in the bracket. you'll understand when you look closely at it. once the wire is installed, hold it in place when you turn the bracket/ball/wire assembly over. fit the legs on the bracket into the groves on the base of the trackball -- that's the side where the ball sits and the circuit board is. make sure the scroll wheel passes through the trackball cover when putting it all back together. VOILA! problem solved.
Jun 02, 2008 | Logitech Cordless TrackMan Optical...
Scroll Wheel does not work with some programs.
If you set the mouse wheel to one page at a time for the scroll wheel and install the FF add-on SmoothWheel the scroll wheel will work fine, you can even use the FF add-on to change the scroll amount even more (with the SmoothWheel add-on install in FF the "one page at a time" isn't really one page it goes by the add-ons rules, which is 1/7's page.
Feb 18, 2007 | HP (P2353AA) Mouse
Logitech 9311570403 Mouse Logo
167 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
