Question about Samsung SGH-U600
Ring time too short
My phone only rings about 6 times and then goes to orange answerphone, and i don't seem to be able to extend the ringing time or even turn off the answerphone service please help as i keep missing my calls.
  • Micki300 Oct 11, 2008
    My downloaded mega tone does not play long enough. How can I extend it to at least to equal the time of 4 or 5 rings before it goes to voice mail? I am using a samsung t429.
I have a Samsung Gleam and I'd like to add time to my ringing (about 10 seconds). Please advise.
Posted on Oct 11, 2008
I have the exact same problem
Posted on Aug 06, 2008
The phone will only ring for approx. 7 rings before the call is diverted to the answerphone, unfortunately this is standard and there is no way to increase the ring time however if you contact orange customer service they can remove the answerphone from your phone for you.
Posted on Mar 30, 2008
  • 425 Answers
Try resetting your phone to its factory settings...
Posted on Jan 02, 2008
Panasonic kx-tg8562eb when ringing the phone it rings then after 5 rings goes to answerphone as normal but phone itself not ringing in the house
check the plugs for good connection get a can of contact cleaner and spray when then unplug/ replug a few times
Apr 16, 2015 | Panasonic Lands Phones
Can I extend the ringing time when on answer phone?
check side of the base there might be a slide switch to change that or google make ,model, manual
Mar 15, 2015 | Lands Phones
Extend ring time
this feature is set by your carrier. Call customer service and ask them to extend rings to 6 - 8.
Jul 26, 2014 | Motorola Cell Phones
Re Panasonic KX-DT321 I have read the short instruction leaflet sent with the phone but can't make head or tail of how to set the answerphone to engage after a given number of rings. I work in a busy...
Start by dialing 500 on the intercom. If that gets you into the voice mail system, then you can dial *710x 500 # where x is 4 for No Answer and 5 is Busy/No Answer call forwarding. The number of rings before the forward is controlled by *713yy where yy is a time in seconds. Each ring cycle is about 6 seconds, so 24 would be a good number.
Leaving a message on your own phone? Dialing 500 gets you into your personal mailbox as an owner. Dialing #8 and your extension gets you into the VM system as a caller. (or it might be #6, I don't have my VM online today)
Of course, if you have an ESVM instead of the TVx system, then the procedure is entirely different.
Carl
Aug 06, 2011 | Panasonic KXDT321 Phone
How do i reduce the number of rings before the call goes to answerphone? The phone is ringing about 8 times before it switches to the answerphone and I would like this to be about 4 rings
usually there is a small slide switch on the side of the answering machine that you can use to control how many rings before it answers. if that is a new digital model you will likely have to go into the menu to set it up. often your choices are two, four or toll saver.
robert
Please take a moment to rate this solution thanks
Nov 10, 2009 | Nortel Lands Phones
Answerphone Question
Push Menu, Scroll to Initial Setting and push Select, go to Set Answering and push select, go to Ring Count and push select, you should be able to scroll up or down to the number of rings, in your case 6, and then push save
Mar 12, 2009 | Panasonic GigaRange KX-TG5432 Cordless...
Extending Ring Time
You can try the steps below:
A) The simplest method is to call your carrier and request a longer ring time, up to 30 seconds.
B) If you have a GSM based phone, some have had success by dialing this number from your phone: **61*XXXXXXXXXXX**30#
  • Replace XXXXXXXXXXX with the number of your carrier voice mail center (find it by looking at your Phone Dialer > Options > VoiceMail > Access Number. Put your access number in place of the Xs above.
For example, the T-Mobile voice mail access number is 18056377243, and thus the string to dial would be **61*18056377243**30#
  • Replace the 30 at the end of the string with your desired seconds. For most carriers, 30 seconds is the longest allowed.
  • NOTE: Has been reported this doesn't work for Rogers (8700r) . 6/17/2005. Morser
Sep 21, 2008 | RIM BlackBerry Pearl 8100
No ring on phone
check that you have master type socket
Jun 02, 2008 | Lands Phones
Samsung SGH-U600 Logo
408 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
