Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Got hot and turned off - Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
  • 736 Answers
Getting too hot is a sign that the air flow is restricted ... that could be a clogged filter, hose or air intake ... there is a thermal breaker in the moter that will shut the machine off if it gets too hot .. it will automatically reset in 5-10 minutes ... but you have to fix the lack of air flow to keep it running ..
Posted on Sep 30, 2009
    Problem Solver:
  • 6 Answers
Remove the air filter from the bagless chamber and clean it with water. Allow the filter to dry and then insert it back into the vacuum. This will increase the airflow in the vacuum and allow the motor to stay cool, also you will get much better suction.
Was using my cleaner it went off and now it won't turn back on
Many models have a thermal reset to turn off the vacuum if it gets hot. Better vacuums have a mechanical reset switch that you push to reset. Most vacuums have an automatic thermal cutoff built into the motor, if it gets too hot it shuts off the power and will reset itself when it cools back down. If it shut off due to getting too hot it indicates a clog somewhere or the filters are clogged or the bag is full.
Jan 22, 2017 | Vacuums
Miracle Mate Platinum. Why does it get hot & turn off?
Carmen,
Sounds like the motor is overheating possibly because of a clog or maybe a filter that needs to be cleaned. Make sure you have a new bag and clean all the filters and hopefully that will take care of your problem. Hope this helps!
Jun 04, 2015 | Vacuums
Setting water in right temp,after couple minutes hot water goes off
makes for a quick shower eh . but back to the problem what does the hot water do say in the kitchen sink .
Mar 14, 2015 | Alsons Delta" Handheld Showerhead - White
Haan sI70 unit gets hot but no steam is generated, so not hot enough. Anything I can do?
It sounds like the internal temp thermostat is detecting that its hot enough when its not, and cutting the power as its supposed to, but too early. It may not be worth time/effort/money changing this part, in case its a problem with another part. Its a bit desperate but you could turn it off and half fill it with cold water then shake it vigorously to see if washing the internal surfaces impoves things.
Dec 15, 2013 | Haan SI70 Multi Sanitizing Floor Steam Mop...
On a Kirby sentria the metal spool sticking out that goes into hose or power head becomes extremely hot and left burns marks on brush tube. It only gets hot when using power head. I checked all adjust
Check the brush roll to be sure it's spinning free too much drag can cause that to get hotter but usually it would break the belt. That spindle will get hot from the friction created by turning the belt and from the motor's heat. They'll just get hot, any brand that spindle will be hot after running it. It's just how it is.
Feb 05, 2013 | Kirby Vacuums
The machine is not turning on at all, what do i do?
first check electrical recpt make sure it hot and not tripped.
second if electrical recpt is hot check cord for continuity with meter.
if cord is fine check switch for continuity. usually one of these three things that cause a vacuum not to turn on.
Jan 08, 2013 | Bissell 6594 PowerForce Bagless Upright...
I think my maxima got too hot and shut down. Is there a fuse that I may of blown that I can check or is the motor probably fried ? Thanks, Teri
The motor has a shut off when it gets too hot. Wait 30 minutes to an hour to turn it back on. The airway is blocked, causing motor to get hot. Check filter, clean it out, check hose for clog.
Aug 28, 2010 | Eureka 4700A Maxima Bagless Upright Vacuum
Vacuum was running unusually hot recently and then
if it was running hot somethinghas melted together and now wont start must be torn apart to see what has failed most likely the vac motor impellar.
Jan 27, 2010 | Vacuums
HI, my motorized brush barely turns.It makes a hot rubber smell. I took apart and noticed the spindle the belt turns on discolored from heat. Cleaned it, but still no turning of the brush.The vac is a...
That means that the belt is stretched and it is slipping on the motor shaft, that is why it is hot and smells like burning rubber. You need to replace the belt. Here is the correct belt you need:
Hoover Windtunnel Canister Belt
Dec 24, 2009 | Hoover S3765-040 WindTunnel Bagless...
Wont turn on - Plug is hot - is there a reset on the motor
IF THE PLUG IS HOT YOU NEED A NEW PLUG- ALSO MAKE SURE THE OUTLET YOU ARE USING IS OK
Jul 10, 2009 | Dyson DC07 Full Gear Bagless Upright...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
388 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
