Question about Panasonic KX-TG1033S Cordless Phone
My panasonic KX TC 1222JXB cordless phone not working according this message No Link To Base place on cradle and try again, Iam place it cradle but not ressolving this problem
leroyal
  • 2120 Answers
SOURCE: How to link 3 same model cordless phones to one base
Only if you have 2 phone lines.
Posted on Nov 06, 2008
SOURCE: cordless phone lost link to base
throw it
Posted on Oct 22, 2008
  • 4 Answers
SOURCE: Panasonic KX-TG2367 says "No link to base".
This worked for my mother's KX-TG2357:
We tried doing what it said in the manual on page 54. That didn't work! She then decided to just unplug everything. About 3-5 minutes later, plugged everything back in, and lo and behold, everything was working fine!!
Posted on Feb 08, 2009
RPFinney
  • 385 Answers
SOURCE: cordless phone not connecting to base. no dial tone.
switch the A/C mains off 5 minutes
or
Re-register them to the base,
This resolves the problem
Regards
Richard.
Posted on Apr 26, 2009
  • 37 Answers
SOURCE: Panasonic kx-tg5839al cordless phone on base set #1 button only works intermittently. Is there an easy fix for this (out of warranty)
No, the keypad is worn out. The electronic need to be replaced. Could be more costly to have repaired.
Posted on Apr 29, 2009
My Panasonic KX-TG5576 5.8 GHz Cordless Phone, I have it charged. The base phone is working fine. But when I try to use the cordless hand phone and try to use it,m it says: No link to the base, move...
Set the phone on the charging cradle and press the ON button while phone is in crade. You may need to use the speakerphone button to do this. Turning the phone on while in the charging cradle will resync your handset with its base. Try it! It should work!
Feb 01, 2011 | Panasonic KX-TG5576 5.8 GHz Cordless Phone
I have Panasonic KX-TG6051M cordless phone. I have been using it for years with no problems. I now get the message:"No link to base. Move closer to base, try again." I have read the user manual...
Hello! Have you re-registered the handsets? If not go to page 39...If you have re-registered the handsets...Pull the batteries for 1 hour...reinstall batteries...allow handsets to set in the cradle for 1 minute then test...
Guru...Saailer
Jan 01, 2011 | Panasonic KX-TG6051M Cordless Phone
I cannot use the cordless part of my panasonic KX-TC1221BXB. The following message is shown ''No link to base. Place on cradle and try again'' But even after placing back on the cradle, the same message is...
I couldn't find the exact manual for your phone but I would try to re-register the phone. Following are some instructions for similar models of your phone.
*To do this on a non-expandable cordless phone:
  • Press and hold the LOCATOR/INTERCOM button on the Base until a beep sounds.
  • Press and hold the FLASH/CALL WAIT button on the Handset until a beep is heard.
  • When registration is complete, a beep sounds from the handset.
  • Wait for 20 seconds after registration is complete to allow the handset to establish communications with the base.
If this fails to help: Remove the AC Adapter from the phone base or wall outlet for a few seconds and reconnect. It may also be necessary to remove the battery from the handset for a brief moment.
Mar 06, 2010 | Lands Phones
I have the below-mentioned problem with my Panasonic Cordless model KX-TG3531BX No link to base. Move closer to base, try again. Please contact me on 9879590311 or email me at ritu_vpatel@yahoo.com
place all handsets in the base unit for about 1 minute each. This links the handsets to the base. Sometimes the handsets lose their link to the base unit. If this doesn't work try to call Panasonic tech support for further information, the phones could be defective as well.
Aug 30, 2009 | Panasonic KX-TG5632 Phone
An error message is apearing on my handset,maybe a code is needed
Try this method:
Press locator button on base unit for 3 seconds. Now push flash button on handset for 3 seconds.
This MAY reregister phone to base unit. It did not work for me, more tests at http://www.panasonic.com/consumer_electronics/telephones/ts_guide1.asp
Mar 20, 2009 | Panasonic KX TG2258S Cordless Phone
My phone won't turn on
unplug it from the wall and wait for about 15minutes
Mar 13, 2009 | Panasonic KX-TG1033S Cordless Phone
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
No link to base move closer to base
Your getting this message because the radio portion of the handset or/and base is not communicating with each other. This can be temporary or fatal. You can try re-registering the handset(s) to the base by following the directions in the manual, its fairly easy to do for any model. If that does not work,and you have more than one handset not working with this problem, then it sounds as if your base needs repair or replacing.
Feb 04, 2008 | Panasonic KX-TG5632M Twin Cordless Phone
Panasonic cordless phone with answering machine model number Kx-TG2632 2.4 gigga range I miss place the book and I need help to adjust the volumn thank-you
The message on crystal reads"no link to base. Move closer to base, try again". I put in a new battery in each phone and not sure if they are charging. i keep getting the same message. What is the problem and how do I solve it?
Thanks
Dec 02, 2007 | Panasonic KX-TG2632W Phone
Panasonic KX-TG1033S Cordless Phone Logo
110 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
