Question about Casio fx-300ES Calculator
When I try to compute a problem such as 6.11 + 6.11 instead of getting 12.22 i get a fraction
  • Casio Master
  • 7,993 Answers
If you call a simple addition a problem it is no wonder that everything seems so difficult.
When you calculate the sum 6.11 +6.11 , the calculator gives you a fraction reduced to it simplest terms, 611/50. The result is correct, but it happens that you want it expressed as a decimal rather than a fraction. To fix that all you have to do is to press the button [S<->D] above the red [DEL] key. It allows you to toggle the display format between fraction and decimal.
611/50 [S<->D] changes display to 12.22 and if you press the key again you go back to fraction
12.22 [S<->D] 611/50
Similarly, if you enter square root of 2 and it displays as a radical, you convert it to a decimal by pressing the key [S<->D].
The fraction and radical formats allow you to do exact claculations. But if you do not want to hear about that you can just press [SHIFT][MODE][2:LineIO] : Your calculator will do things the old way, but you will lose some important functionalities.
My suggestion is to set the default mode [MathIO] by pressing [SHIFT][MODE][MathIO] and to press the [S<->D] key to convert to decimal.
Hope it helps.
Posted on Oct 17, 2009
It is showing fractions instead of Decimals when i do equations like (4 divided by 9) it gives 4/9 instead of the decimal.
Calculation results will be displayed using
fractions, r, and ?. When you press CHANGE, the display will cycle
through the following display styles:
• Mixed fractions (with or without ?) ? improper fractions (with
or without ?) ? decimal numbers
• Proper fractions (with or without ?) ? decimal numbers.
Feb 03, 2011 | Sharp ELW535 Calculator
How do I get a fraction as an answer instead of a decimal?
The TI-83 can only convert a small range of numbers to a fraction. To try so, use the >Frac function on the MATH menu. Press MATH 1 to invoke it.
Oct 25, 2010 | Texas Instruments TI-83 Plus Calculator
When i add 12.3 + 12.3 I get the anwser in fraction form instead of decimal form.
If the result is already calculated and displayed, press the [S<=>D] key It will convert a fraction or radical to decimal. This is always possible. If the result is decimal it may be converted to a fraction or a radical (Not always possible).
If the expression to be evaluated is still in the command line and you have not pressed the [=] key, you can force the result to be displayed in decimal format by pressing [SHIFT][=] instead of just [=].
More permanently. If you do n o care for fractions and radicals, set the Input/Output mode to LineIO. To do do press [SHIFT][MODE] to access the (SETUP) screen and select [2:LineIO]
Jun 16, 2010 | Casio FX-115ES Scientific Calculator
How do i get a decimal on division instead of a fraction? in example when divide 100 by 3 it gives 100/3 instead 33.3
  1. If a fraction (or a radical) is already displayed press the [S<=>D] key to convert it into a decimal number.
  2. If you are entering an expression and want its result displayed as a decimal number, press the [SHIFT][=] key sequence instead of just [=].
  3. More permanent solution: If you do not want fractions nor radicals, configure the Input/Output to be LineIO. To do that, press [SHIFT][MODE] to access the (SETUP) then select the option [2:LineIO]
Jun 01, 2010 | Casio fx-300ES Calculator
Fractions appear when I divide; not decimals
you can also go press the 'mode' button, and go down until you're at 'Exact/Approx' and choose '3: Approximate'
Sep 10, 2008 | Texas Instruments TI-89 Calculator
Fraction problem
follow the following sequence of steps
mode>exact/approx and then select approx
Jun 05, 2008 | Texas Instruments TI-89 Calculator
Fractions
When performing the calculations, put the fractions in parentheses. Then once you get your answer, press 2nd and Math (above the times button). Then press F5, MORE, and F1. It will have Ans Frac>. Then hit Enter and it'll change it to a fraction.
Feb 03, 2008 | Texas Instruments TI-86 Calculator
Fraction problem
Go into MODE to the second page.  In Exact/Approximate, change it to Approx instead of Auto or Exact.  This will give you decimals instead of fractions.
Nov 17, 2007 | Texas Instruments TI-89 Calculator
Casio fx-300ES Calculator Logo
70 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
