Question about Bosch SHU9915UC Dishwasher
How do you turn off half load?
We cannot turn off "half load" button.
  • aaron Aug 07, 2013
    hi - did you ever figure this problem out? having the same right now.
My half load button will not stay pressed so cannot dry?
What make and model do you have?? Will it work with full load setting?
Sep 21, 2014 | Washing Machines
Can you do half loads with thesemachines?
If this modal has a half load button then yes of course if no button then should still be okay to use quick wash mode...good luck
Mar 24, 2011 | Bosch Washing Machines
No sign of life from the display half but the bottom reads life.
If you have already checked the connections from the screen to the PC, check that you have a power light on the screen. (Green or Amber). If no light, check power to screen. If it is amber, then the screen is not getting a signal from the PC - recheck connections. I would suggest you try and connect the pc to a different monitor to check whether it is the screen or the PC.
If it is the same on another Monitor or if the power button is green on the screen, then the pc is not sending information properly. Turn the pc off manually by holding the power button on the bottom half for about 10 seconds. All lights should go off from it. Now turn it back on again and see what happens.
If you see loading windows and then goes black, do the following:
Turn off the pc (bottom half). Turn back on and as soon as you pressed the button to turn on, start tapping the F8 key until you come to "Windows Advanced options" screen. use the arrow keys and go to Enable VGA mode. Press the return key twice. If it loads to windows, then fine. If not, then you may have a problem with the display adapter.
Hope that helps
Nov 11, 2010 | Computers & Internet
I have 2 buttons 0ne for half load one for super wash do the buttons have to be pushed in or out to use
I am only familiar with the half load button but that has to be depressed to operate so I would expect the super wash button to be the same.
Good luck.
Apr 25, 2010 | Tricity Bendix WDR1040W Front Load Washer...
How to Start And use ???
I have the 6040 model, and it has a number of buttons on the left, and a dial on the right.
if yours is the same, then you need to select a program using the buttons "Normal" for example, then turn the dial to just after the top A selection (I mean just after this, by a few mm, it clicks past the A slightly)
this will then do a pre-was, and the main wash you have selected.
The other buttons are fairly self explanatory, like half load for a half load, pre wash to only do a pre wash etc...
Hope the helps!
May 23, 2009 | Ariston Technologies Dishwashers
My dryer won't work
set middle dial to 120 (minutes), or 90 or 60 minutes.  press the start button in and the half load button in.  that should do it.
Oct 15, 2008 | Malber WD1000 Front Load Washer/Dryer
Hotpoint aquarius half load
you can only select half load if you wm has a half load button or switch found on the cosol panel
Feb 13, 2008 | Hotpoint Aquarius WD63 Front Load...
6kg Load Button
For a full load within 6kgs you dont do anything, just let it go thru the cycles. But when your load is half - you press the half load button. Good luck.
Mar 13, 2007 | Hoover AI130 Front Load Washer
Bosch SHU9915UC Dishwasher Logo
143 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
