Question about Danby DCD5505W Electric Dryer
Running with no heat
HI!! I have problem with Danby dryer ( the model is number DCD5505W-1)? My Dayby dryer is running with no heat? Could you help? Thank you!!
    President:
  • 1,776 Answers
Check for a blown thermal fuse or a faulty heating element. Both components should be located inside the rear of the dryer. The thermal fuse is about an inch long and is usually attached to or near the exhaust duct. Both components can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity will indicate a faulty component. Really sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 30, 2009
  • modestmaus Aug 28, 2010
    I had the same problem - no heat. After opening the back panel, I noticed a RED reset button. After pushing it and plugging the unit back in, it worked again. So, you may want to try this solution first before buying replacement parts. Good luck.
  • Donna Meyers
    Donna Meyers Jan 24, 2017
    Where do I find the reset button on Danby Dryer Model DCD5505W-1?
The handle broke on mine as well, I ordered a new handle for it.
Posted on Jan 08, 2012
I have a Danby Clothes Dryer Model #DCD5505W-1. The dryer works but will not heat. Is there a reset button? If so, where is it located?
More than likely the heating element has burned out or the control circuit board. There is no such switch as a reset.
Jan 24, 2017 | Danby Dryers
Danby dcd5505w clothes dryer is not heating
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 21, 2010 | Danby DCD5505W Electric Dryer
My Danby dryer has no heat after a bad electrical storm that surged many of my appliacances
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 04, 2010 | Danby DCD5505W Electric Dryer
Drum runs but there is no heat
heatman101
Apr 07, 2010 | Danby DCD5505W Electric Dryer
Danby Dryer too hot
First of all, check to see if you have a hose going outside that is fully clear of lint from beginning to end. then check to see if your heat is staying the same on a empty load run machine empty, then turn your thermostat to cool after it heats up and see if the temp went down to see if working properly.
Jun 02, 2009 | Danby DCD5505W Electric Dryer
Dryer belt PH 1930 for danby model dcd5505w-1
Call Danby Customer Service at 1-800-263-2629; The part costs $25 or so plus another $7 shipping. Better than getting it through a distributor, I was given a price of $40 through a local place.
Oct 30, 2008 | Danby DCD5505W Electric Dryer
Hello....
I needed to replace my belt. I called the Danby Customer Service number 1-800-263-2629. I called early in the morning and got straight through. I received wonderful, prompt friendly service.
The belt cost $25.19 plus postage and handling.
Joe
Jan 16, 2008 | Danby DCD5505W Electric Dryer
Door Handle Broken
yes contact your local appliance dealer or if you have the manuals that came with this dryer contact the manufactuer by the listing on thier literature.
Or do a web seach LIke :DANBY DCD5505W DRYER PARTS
Jan 15, 2008 | Danby DCD5505W Electric Dryer
Danby DCD5505W Electric Dryer Logo
622 people viewed this question
Top Danby Dryers Experts
Tim Whalen
SHARCNET-USA
SHARCNET-USA
Are you a Danby Dryer Expert? Answer questions, earn points and help others
