Question about Microsoft Windows XP Home Edition
Stop: 0x0000007e how to fix this error on windows xp stop: 0x0000007e (0x0000005,0x000042ca,0xf895054c,0xf8950248)
    Sergeant:
    Champion:
  • 289 Answers
Upgrade to vista or windows 7, Xp is not supported by microsoft anymore (BUMMER)
Posted on Sep 30, 2009
How do I fix windows error update 8 to 8.1 0x80070003?
copied from windows website.
Windows Update error 0x80070003 Applies to Windows 8.1, Windows RT 8.1 If you receive Windows Update error 0x80070003 or 80070003 when you use Windows Update, try running the Windows Update Troubleshooter.
May 15, 2014 | Microsoft Windows 8 For Tablets
0x0000007e error in windows xp
this is a blue code. Go to microsoft.com and download the software for fix it. or go to the supplier computer and download too
God bless you
May 22, 2013 | Dell Inspiron 6400 Notebook
Aspire One netbook BSoD
Those error codes don't really mean very much to the general consumer, but blue screens of deaths are caused by bad RAM memory in your computer, not viruses. I'm going to take a guess that your computer is either several years old and/or it constantly get quite warm? Heat can shorten the life of computer components by quite a bit. You may need to get one of your RAM cards replaced to solve this issue.
There's a free program called Memtest86 that you can run to determine if this is the case. It will scan all your memory and look for bad sectors. You can download it here: http://www.memtest86.com/ and burn it to a CD. What it does is create a bootable CD that will execute the program as the computer turns on to scan all the memory. There are full instructions on their website. The process can take an hour or two depending on how much memory your computer has, and if it turns up any bad sectors then you know what your problem is.
A computer can run with bad sectors in the memory, but it makes it unstable that it will keep bluescreening, so if you have bad sectors in your memory it might be better just to replace the RAM. Luckily, this isn't too expensive. For instance, if your computer has 4GB of memory, it probably has 2 2GB RAM cards installed. You can get a 2GB replacement notebook memory for, I'd say $30 or $40. Installing RAM is very simple, and if you're willing to install it yourself, it won't cost you more than that.
Dec 06, 2012 | Acer Aspire One Netbook 8.9" Notebook
Windows xp sp3 stop error message 7e usb
Why not just pull it out instead of clicking on safely remove hardware? Try it and see if it works. Sounds like your usb drive is not windows 7 compatible. Or windows 7 has some driver issue which is not uncommon.
Jun 04, 2012 | Hitachi 1TB LifeStudio 35 Desk Plus...
Windows cannot connect to printer. Operation failed with error 0x0000007e.
This problem happens when you are trying to share printer between 32 bit (x86) and 64 bit (x64) Windows. The 32 bit driver not compatible for 64 bit operating system. At this situation you may get error message like this "Windows cannot connect to the printer Operation failed with error 0x0000007e".
But there is an alternate way to add printer from 32 bit Windows to 64 bit Windows.
Start >> Devices and Printers >>
Then Add Printer with the help of IP address of 32 bit Windows computer.
Detailed steps with screen shots are given in the following link.
[Solved] Operation failed with error 0x0000007e
Solved Operation failed with error 0x0000007e Share printer between 32...
Apr 11, 2012 | Xerox Office Equipment & Supplies
Blue screen and audio problem
Above error may occur due to insufficient hard disk space available for Windows XP. Make sure that you have sufficient hard disk space.
Computer BIOS might be incompatible with Windows XP or it might have to be updated.
A device driver or a system service might be damaged.
Apr 23, 2010 | Microsoft Windows XP Home Edition
I get a stop error message when I try to install windows like this stop: 0x0000007e pci.sys
the error that you are getting is caused when you use an old Windows XP CD without service pack 2 integrated. If you want to install XP on to the new system you must use an XP CD that has service pack 2 integrated.
Nov 16, 2009 | Dell Inspiron B130 Notebook
Windows BSOD on all restarts, even in Safe Mode and even if I start with video in VGA mode. Stop code is 0x0000007E plus four more codes in parentheses. During Safe Mode restart the last file to appear on...
7E is a memory issue or general driver fault. It's windows way of saying "i dunno it just died". If you have Dell diagnostics, run a full system check, to ensure the hardware is ok. If you get no errors, then you have a driver fault in windows. This is From Microsoft:
If the following conditions are true, the issue might be a hardware incompatibility with Windows XP because all the installed drivers are Windows XP drivers:
  • You receive the STOP 0x7E error when you first start the computer.
  • You receive the STOP 0x7E error after you run the Setup program.
  • You did not install any third-party drivers during the installation of Windows.
However, if you receive the STOP 0x7E error after you upgrade from Windows 2000 Professional, or if you recently added a new hardware device, this issue might be an incompatible driver or an incompatible hardware device.
Basically, the 7E error is a defective driver. You will likely have to get your computer recovered by a professional shop, or if you have nothing important on it, attempt to reformat and reinstall. It is unfair that Windows has borked your computer and they wont fix it. I hope I was able to at least point you in the right direction.
Oct 26, 2009 | Dell Inspiron 700M Notebook
Error code 53000:031e stop:0x0000007E COMPUTER WIIL NOT BOOT UP
hi there !
-boot to SAFE MODE
-restart the computer and press F8 and choose SAFE MODE then do the steps below
Windows Update Causing STOP Error 0x0000007E
-For now simple system restore should fix the issue, else uninstall this update by booting to safe mode.
-Uninstalling windows update KB973879 and hiding this update from available update is currently seem to be fixing the issue.
In case if removing update KB973879 doesn’t fix the issue, we need to remove remaining two updates KB970653 and KB972036.
cheers!
Oct 20, 2009 | Dell Latitude D510 Notebook
Microsoft Windows XP Home Edition Logo
375 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
