Question about Lexmark X6170 All-In-One InkJet Printer
Lexmark X6170 stops printing at 99%, page comes out okay but other print jobs get backed up behind this. I open the menu and cancel the first one but it won't cancel. I have to reboot, which clears the print requests, then re do which again, stops at 99%. Help...... I don't have time to waste.
  • 2 more comments
  • JRS18 Jan 01, 2008
    I have the same problem - specifically where the printer is attached to a print server (D-Link - DP-301u). Before I installed the print server - everything worked fine.
    Any help is appreciated,
    Jon
  • Anonymous Jan 06, 2008
    When I run maybe three pages on the copier, the second and third page only copy part of the page????
  • Karmor
    Karmor Jan 12, 2008
    I *had* the same problem when I connected my x6170 to a Synology NAS with USB print manager. JSR18's solution to change the print processor in printer properties worked! Thanks.
  • Anonymous Apr 03, 2009
    Printer will work first print job round, but the "print completion" bar stops at 99% and the other jobs get stuck behind the first one (even though it already printed and technically should be complete).
I found the following post on AsusForum.NET that solved the problem for me - hope it helps -
"As I had printing problems with my Lexmark X6170, which I bought at the time because it looked a good deal, I started to work on a solution.
I think this problem is also applicable for a number of other printers. The symptom is that the spooler in windows displays a progress for 99%. If you want to delete the job from the queue, you could end up restarting the print spooler.
The solution is rather simple (it took me a while to find out though).
If you go to the properties for your printer and click on the tab <advanced> and on the button <print processor>, just select the [winprint] processor instead of the manufacturer processor (in my case lexmark...). In the right pane select one of the [NT EMF...] processors and this should do the trick.
ALSO disable the bidirectional support on the <ports> tab...
As I thought the problem lies in the signal which has to be send back from the printer to the processor that the job has finished. As there is now way for the printer to send back the signal over the same printing port (RAW/9100), the spooler still thinks the job hasn't finished.
I searched the technet site and found some notes where a similar problem is described. In the case a problem like this occurs (apparently only with printers which use their own software and need bidirectional support...) they (the dark side) advises to use a Microsoft driver instead...
Hope I could help somebody with a frustrating problem.
(ps. printer works fine, the lexmark software not.)"
Posted on Jan 03, 2008
This didn't work for me, it helped but still was't finishing large documents. I disabled AVG after reading something from another site and it worked perfectly, hope this helps someone else.
Posted on Sep 19, 2009
The solution worked! that's great.
Posted on Aug 30, 2008
I love you.
your solution worked. i was on the phone with tech support all day who pretty much gave up on me.
i was this close to going out and buying a new printer.
who thought something so simple would fix my problem.
thank you so much
Posted on Jul 01, 2008
Open task manager(XP SP2 windows) and delete lexbces.exe and the file srtuck at 99% will be removed. I'm also facing this problem and trying to update the driver. Hope it will work!!
Adam
I had this same problem with our Lexmark P4350. I went to the Lexmark website and stated the problem in the chat window. A tech sent me a patch for my computer, which after I downloaded it and the restarted my computer, seems to have fixed the problem.
Hope this helps.
Posted on Feb 26, 2010
  • mpniel May 19, 2011
    What kind of patch did you install?
Why is the light flashing on the right side
If the light flashing is the "light bulb like button" or the "Ready/Light" button, it means that either the printer is:
• The printer is busy receiving and processing data or printing.
• The printer is printing a directory, font list, menu settings pages, or Print Quality Test Pages.
If it's Busy:
• Wait for the message to clear.
• Press and release Cancel to cancel the print job.
• Press and hold Cancel to reset the printer.
If it's printing a directory, a font list, menu settings pages, or Print Quality Test Pages:
• Wait for the pages to print. The Busy message is displayed as the pages print. The Ready light is on when the
printing stops.
• Press and release Cancel to cancel printing.
Jul 31, 2012 | Lexmark E250dn Laser Printer
I have a Lexmark S504 wireless multifunction printer. I can print a test page but a can't print anything from any application. The Windows print page window comes up and if you click OK it appears to...
It could be a printer driver issue. Please follow the steps below to fix the problem.
First, clear the print queue from any stuck print jobs. You can do the steps mention - going to Services and stop the print spooler, delete the files in the spooler folder and then restart the service.
Second, delete the existing Lexmark Interpret S405 printer driver. On your computer, go to Start menu > Programs > Lexmark > Uninstall. After the uninstall process, reboot your pc when prompted.
Third, visit the Lexmark website to download and reinstall the Lexmark Interpret S405 printer driver. Select the version of your Windows operating system. Download and execute the file. Follow the instructions on your computer screen.
After the reinstall process is successful, try to print again to verify that the problem is fixed.
Sep 07, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Prints one or to pages then stops. Have to reset computer to get it to work. No test doesn't work. It is like it runs out of memory.
Try to run a test for continuous print test page in diagnostics mode. To enter the Diagnostics mode:
1. Turn off the printer.
2. Open the front access door.
3. Turn on the printer while pressing and holding Cancel .
4. Close the front access door once the Error light displays. Print the menu page by pressing and holding Continue until all of the lights flash. Follow the instructions on
the menu page to access the menu items.
Continuously print pages containing cross lines, printer information, and margin settings. Press and hold until the Continue button lights flash to begin. Press Cancel to stop.
Make sure he selects the "Cont Prt Simplex Tray 1" option
If problem persists, contact Lexmark at 1-800-LEXMARK()1-800-539-6275.
Apr 21, 2010 | Lexmark E260dn Laser Printer
LexMark 3350 Printer often stops printing in mid multi-page
If printing is stopping in the middle its not the Problem with the driver
Check the Spooling Properties
Checked Printing Test Page
Jan 06, 2010 | Lexmark X3350 All-In-One InkJet Printer
Lexmark x6170 stopped printing text will only pint images
First, print a test page from the printer's menu and see if the black lines and text look okay on that. If there is no or poor black printing, you need to replace the black cartridges or try cleaning the cartridge's nozzle with rubbing alcohol. If that looks fine you need to check the printer's settings in its properties on the system lift of printers.
Oct 01, 2009 | Lexmark X6170 All-In-One InkJet Printer
Lexmark X6170 will only copy l/4 of page as a copier but copies full pages from the computer
check the properties and page settings before you print you may find your page settings are incorrect to what you want. Set to all pages, make sure print colour documents black is unckecked, make sure no other settings are telling it to print other than what you want. Post back if no good.
Sep 03, 2008 | Lexmark X6170 All-In-One InkJet Printer
X5150 and Vista print issue
I am posting this in hopes of helping others that are having issues with the Vista print spooler. In my case, I have an HP Pavilion laptop running Vista connected to a wireless hub. I also have a Minolta Konica 2300DL printer that is connected to the network via the wireless hub as well. Ever since obtaining this laptop, I have not been able to print to the printer other than stopping and starting the print spooler to obtain a single print 'job'. After about six months I found a post that contains the fix - I cannot take credit for it! Follow these instructions to get your printer to work:
1.) Go into control panel - I would suggest classic view as it is a little easier to navigate.
2.) Then go into User Accounts.
3.) From User Accounts go into Turn User Account Control On or Off
4.) UNCHECK Use User Account Control (UAC) to help protect your computer.
5.) At this point you will probably require a reboot.
Once this exercise is complete, you should be able to print. One more item off of my Honey DOO list!!!!!
Jul 24, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark 1650 Optra S printer will not cancel print jobs, HELP!
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:169:0:0
This is the primary page for troubleshooting this printer.
In regard to general issues regarding cancellation of print jobs, this is most often due to driver issues, or handling within the operating system. Please refer to http://support.lexmark.com/cgi-perl/knowledgebase.cgi
regarding general instructions to stop/restart print spool & print jobs.
If you are using the printer on a network, often the settings for the printer on the network will cause this issue, and the cancellation abailability to owners or users needs to be adjusted within the network / server system. If it is a standalone setup, the solution depends on the OS; however, generally you should be able to open the printer control (e.g., Control Panel > Printers > Lexmark 1650...) and delete the job listed in the queue.
You may also initiate an online chat with a Lexmark support tech at http://support.lexmark.com/static/229-1-0-71.html.
If you require additional assistance, please post back with further information; otherwise, thanks for rating FixYa!
May 28, 2008 | Office Equipment & Supplies
X6170 Prints only one page then freezes
drivers are most likely not up to date, especially if you used the old ones. Gotta go to lexmark, and get the latest Vista friendly driver. I recommend the highest quality one, with the most features(so that Vista won't spit it out again).
Feb 06, 2008 | Lexmark X6170 All-In-One InkJet Printer
Stops at 99% and trys to delete file - no other jobs will print
This is based on your operating system and should work for all versions of XP, I have not tested it on Vista.
Start, Run, type "services.msc"
Find "print spooler"
Click the stop/start icon (square with triangle at the top of the screen shot below)
Try to highlight your print job and clear it.
If it will not, power down your printer, power it back on (physical power) and try again.
Feb 03, 2008 | Lexmark X6170 All-In-One InkJet Printer
Lexmark X6170 All-In-One InkJet Printer Logo
5,678 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
