Hi, I have a problem fitting the retaining clip/spring on the clutch cable at the pedal on a 1995 Daewoo 1.5I - can you help ??. Regards Simon
    Brigadier General:
  • 8,619 Answers
Hi Simon
Thanks for using FixYa. Please take a look at the brake and clutch system fir your car---
Click on the picture to zoom in.
Also see the steps for removal of the clutch, as the installation procedure is just reverse of removal---
  • The gearbox has to come out, get the front of the car as high as possible on axle stands.
  • Remove n/s plastic shield, then remove n/s wheel.
  • Remove driveshaft nut & split bottom ball joint then remove shaft from hub.
  • Now remove all bell housing bolts (there’s a 19mm bolt right at the top thats hidden under the alloy breather housing)you can leave the starter motor on.
  • Remove Speedo + clutch cables crank sensor wires (by Speedo cable) +disconnect gear linkage under car.
  • Support engine on trolley jack ,remove bolt from rear gearbox mounting,
  • Remove front gearbox mount complete, split o/s driveshaft from gearbox, lower engine slowly until gearbox will slide out.
  • Now remove 6 bolts on clutch cover & remove the drive plate.
  • Fitting is reverse of removal but make sure clutch drive plate is central to flywheel.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 30, 2009
Adjusting Kia rio handbrake cable
The brake drum does not fit due to the pressure in brake cylinders. Some of the cylinders are designed to keep a little pressure on, even when the pedal is released. The reason is that you will have instant reaction on pushing break pedal because there is no free space between drum and pads. You need to take clamp and push the pistons back in cylinder, but only that much so you can fit the drum. After the drum is tightened you must pump the brake pedal until you can fell that there is no free fall. The hand brake should be ok, but check it just to be shore. If there is need to tension the cable, it can be done under lever from outside the car (you must go under the car).
Apr 28, 2014 | 2002 Kia Rio
1997 Ford contour rear brake shoe replacment help.
Brake shoe removel:
Depress and turn the retainers for the hold-down springs and pins to remove them from each shoe. Slide the brake shoe assembly--including the shoes and springs--down so you can disengage the top ends of the shoes from the cylinder and tilt them to lift them past the retaining plate.
Unhook the lower retracting spring from the front brake shoe to disconnect it. Spread the shoes apart at the bottom to remove the adjusting screw, the screw's retracting spring and the adjuster lever. Remove the front brake shoe.
Pull the parking brake cable spring back with diagonal cutting pliers, grip the cable with the pliers without cutting it, unhook the cable from the parking brake lever and remove the rear brake shoe with the lever.
Disconnect the parking brake lever from the rear shoe by spreading the retaining clip with a screwdriver and removing the clip and its spring washer.
  • Step 4 Pull the parking brake cable spring back with diagonal cutting pliers, grip the cable with the pliers without cutting it, unhook the cable from the parking brake lever and remove the rear brake shoe with the lever.
  • Step 5 Disconnect the parking brake lever from the rear shoe by spreading the retaining clip with a screwdriver and removing the clip and its spring washer.
  • Read more: How to Change Rear Brakes on a 1997 Ford Taurus | eHow.com http://www.ehow.com/how_6123373_change-brakes-1997-ford-taurus.html#ixzz0u2xgUqun
  • Step 3 Unhook the lower retracting spring from the front brake shoe to disconnect it. Spread the shoes apart at the bottom to remove the adjusting screw, the screw's retracting spring and the adjuster lever. Remove the front brake shoe.
  • Read more: How to Change Rear Brakes on a 1997 Ford Taurus | eHow.com http://www.ehow.com/how_6123373_change-brakes-1997-ford-taurus.html#ixzz0u2xdByQ8
  • Step 2 Slide the brake shoe assembly--including the shoes and springs--down so you can disengage the top ends of the shoes from the cylinder and tilt them to lift them past the retaining plate.
  • Read more: How to Change Rear Brakes on a 1997 Ford Taurus | eHow.com http://www.ehow.com/how_6123373_change-brakes-1997-ford-taurus.html#ixzz0u2xVyUAt
    Jul 17, 2010 | 1995 Ford Contour
    Clutch pedal went loose heard a snap just before ford fusion 2003
    Hi
    It sounds like your clutch cable has snapped, Or the pedal lever has snapped, can you still get gears?
    if not then most likely thats the issue, clutch cable are fairly cheap about £30 ish fitted no more than £65
    Hope this helps. if not get back to me with more info.
    Regards
    Dan
    Feb 09, 2010 | 2004 Ford Fusion
    How to repair clutch pedal safety start switch on Ford Truck F550, 1999
    Clutch Pedal Position (CPP) Switch
    The clutch pedal position switch (CPP) is controlled by the clutch pedal. Depressing the clutch pedal manually closes the CPP switch and allows engine cranking. The CPP switch will also deactivate the speed control system.
    303-14A: Electronic Engine Controls — Gasoline Engines 1999 F-Super Duty 250-550 Workshop Manual
    REMOVAL AND INSTALLATION Clutch Pedal Position (CPP) Switch Removal
    1. sxo~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Always disconnect the battery ground cable prior to working on the electronic engine controls.
      Disconnect the battery ground cable; refer to Section 414-01 .
    1. Disconnect electrical connector from clutch pedal position switch (CPP) (9A837).
    1. Release the clutch pedal position switch (CPP) (11A152) from the orientation clip.
    1. Remove the plastic retainer.
      1. Push the lock tabs together.
      1. Slide the plastic retainer off the clutch pedal position switch.
    1. Remove the clutch pedal position switch.
    Installation
    1. Follow the removal procedure in reverse order.
    Feb 06, 2010 | 1999 Ford Super Duty F 550
    Changing the clutch cable
    There are 2 types of cable used. Auto Adjust...and Manual Adjust. Either are easy to fit. Remove tray over foot=pedals will allow you to access one end of the cable. Here the cable simply hooks over the pedal linkage. Remove the outside plastic panel in front of windscreen to allow the cable to be installed. If the cable is the Manual Adjust type, loosen off the adjuster nuts at the clutch lever on the front / side of the gearbox and pull out cable.
    If car is fitted with Auto Adjust cable...A Plastic Retainer Strap will be installed on the cable at the gearbox end. This retainer should be latched into place before removal. If the cable is broken at present you need not bother with this retainer. A new cable comes with this retainer already fitted. Its simply a matter of fitting the cable in place at both ends and then releasing this retainer. Do NOT release this until the cable is fully installed at BOTH ends
    John
    Jan 20, 2010 | 1991 Volkswagen Golf
    P0734 and P0761 codes related to 4th gear ratio and solenoid c shift problem
    Its more than you think. 1. Inspect for a broken retaining clip by removing the valve body and then the valve body separator plate. Inspect the forward clutch control valve, spring, retaining clip, and valve body casting for damage (Figure 1).
    2. If the clip is broken and the forward clutch control valve and/or valve body casting is damaged, replace the main control. The retaining clip has just been revised to prevent the chance of breakage. The revised Retaining Clip (F8DZ-7F194-AA) has circular cutouts on the side of the clip in place of the square cutouts on the previous design level clip (Figure 2).
    3. Inspect the new main control (if required) before installing it and replace this retaining clip for the forward clutch control valve and spring if it's not the new design (Figure 2).
    4. Any time service is required on any AX4N transaxle main control, inspect the retaining clip for the forward clutch control valve to be sure it is the latest design level, and replace the retaining clip if it is not. The revised clip is larger and will remain centered in the valve body casting groove. too repair estimate..400-800 dollars...Hope this help..Big shops will hurt yo pockets
    Dec 16, 2009 | 1996 Ford Taurus
    How to fit clutch cable to golf gti 2.0i 1997 engine code agg
    Under the dash on top of the clutch pedal there will be a retainer clip holding the cable, remove that then a similar clip on the gearbox, you will have to undo a cable holder bracket to remove the cable, the cable will also have a gromet in the firewall that needs to be positioned correctly on assembly, adjust the cable accordingly with the adjuster on the gearbox once installed, good luck drive safely
    Dec 05, 2009 | 1997 Volkswagen Golf
    Info on do it tyour self clutch removal on 2001 mustang 3.8
    REMOVAL:
    1. Lift clutch pedal to uppermost position to disengage clutch and brake pedal pivot shaft.
    2. Push clutch and brake pedal pivot shaft forward and unhook clutch release lever cable from clutch and brake pedal pivot shaft and allow it to slowly swing rearward.
    3. Raise and support vehicle.
    4. Remove clutch release lever dust shield.
    5. Disconnect clutch release lever cable from clutch release shaft.
    6. Remove retaining clip, then clutch release lever cable from flywheel housing.
    7. Remove starter motor from flywheel housing, then engine rear plate to front lower flywheel housing bolts.
    8. Remove transmission.
    9. Remove flywheel housing back just far enough to clear clutch pressure plate, then remove housing.
    10. Remove clutch release shaft from flywheel housing by pulling it through window in flywheel housing until retainer spring disengages from pivot.
    11. Remove clutch release hub and bearing from clutch release shaft.
    12. Loosen six clutch pressure plate bolts evenly to release spring tension gradually and avoid distorting clutch pressure plate. If same clutch pressure plate is to be installed, mark plate and flywheel so pressure plate can be installed in its original position.
    13. Remove clutch pressure plate and clutch disc from flywheel.
    INSTALLATION:
    1. Position clutch disc and pressure plate assembly on flywheel, noting following:
      1. Three flywheel housing to block dowels on flywheel must be properly aligned with clutch pressure plate.
      2. Bent, damaged or missing flywheel housing to block dowels must be replaced.
      3. tart clutch pressure plate bolts but do not tighten.
      4. Avoid touching clutch disc face, dropping parts or contaminating parts with oil or grease.
      5. Align clutch disc using suitable alignment tool inserted in pilot bearing.
      6. To avoid clutch pressure plate distortion, alternately tighten bolts a few turns at a time, until they are all tight, then tighten to specifications.
    2. Install transmission to flywheel housing.
    3. Install engine rear plate to flywheel front lower housing bolts, then connect clutch release cable to flywheel housing and connect retaining clip.
    4. Connect clutch release lever cable to clutch release shaft, then install clutch release lever dust shield.
    5. Install starter motor.
    6. Lower vehicle, then install clutch release lever cable as follows:
      1. Lift clutch pedal to disengage clutch and brake pedal pivot shaft.
      2. Push clutch and brake pedal pivot shaft forward and hook end of clutch release lever cable over rear of clutch and brake pedal pivot shaft.
    7. Cycle clutch pedal several times to adjust clutch release lever cable
    Aug 08, 2009 | 2001 Ford Mustang
    I need to tear down my transmission in a 1988 Chevrolet Cavalier Z24 2.8L i am fixing the clutch and i need diagrams on how to take it apart and put it back together
    Below is process for removing and replacing the clutch assembly.
    Hope this helps, good luck.
    Regards,
    REMOVAL & INSTALLATION
    See Figures 1, 2 and 3
    0900c1528003be16.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 1: Exploded view of the clutch disc and cover assembly
    1. Disconnect the negative battery cable.
    2. If equipped with a cable clutch (1982-84 vehicles), disconnect the cable at the clutch release lever and transaxle, as outlined earlier in this section.
    3. For 1985-94 vehicles remove the sound insulator from inside the vehicle. Disconnect the clutch master cylinder pushrod from the clutch pedal.
    0900c1528003be17.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 2: Disconnect the clutch actuator (slave) cylinder line - 1995-96 vehicles
    1. Remove the transaxle, as outlined earlier in this section.
    2. Mark the pressure plate assembly and the flywheel so that they can be assembled in the same position. They were balanced as an assembly at the factory.
    3. Loosen the attaching bolts one turn at a time until spring tension is relieved.
    4. Support the pressure plate and remove the bolts. Remove the pressure plate and clutch disc. Do not disassemble the pressure plate assembly; replace it if defective.
    5. Inspect the flywheel, clutch disc, pressure plate, throwout bearing and the clutch fork and pivot shaft assembly for wear. Replace the parts as required. If the flywheel shows any signs of overheating, or if it is badly grooved or scored, it should be refaced or replaced.
    0900c1528003be18.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 3: You must follow the specified sequence when tightening the pressure plate retaining bolts
    To install:
    1. Clean the pressure plate and flywheel mating surfaces thoroughly.
    2. Position the clutch disc and pressure plate into the installed position, and support with a dummy shaft or clutch aligning tool, tool J 29074 or equivalent. The clutch plate is assembled with the damper springs offset toward the transaxle. One side of the factory supplied clutch disc is stamped "Flywheel Side".
    3. Install the pressure plate-to-flywheel bolts. Tighten them in the sequence shown in the accompanying figure, as follows:
      1. Tighten bolts 1,2,3, then 4,5,6 in the sequence shown to 12 ft. lbs. (16 Nm).
      2. Tighten bolts 1,2,3, then 4,5,6 in the sequence shown to 15-22 ft. lbs. (22-30 Nm) plus an additional 30° turn.
      3. Remove the clutch alignment tool.
    4. Lubricate the outside groove and the inside recess of the release bearing with high temperature grease. Wipe off any excess. Install the release bearing.
    5. Install the transaxle, as outlined earlier in this section.
    WARNING When adjusting the cruise control switch, do NOT exert an upward force on the clutch pedal pad of more than 20 lbs. (89 N) or damage to the master cylinder pushrod retaining ring may result.
    1. For 1985-94 vehicles, attach the clutch master cylinder pushrod to the clutch pedal and secure with the retaining clip. If equipped with cruise control, check the switch adjustment at the clutch pedal bracket. Install the sound insulator.
    2. If equipped with a cable clutch, attach the clutch cable at the transaxle and clutch release lever. Check the clutch operation by lifting the clutch pedal up to allow the mechanism to adjust the cable length. Depress the pedal slowly a few times to set the pawl into mesh with the quandrant teeth.
    ADJUSTMENTS
    All 1982-84 models have a self-adjusting clutch mechanism located on the clutch pedal, eliminating the need for periodic free play adjustments. The self-adjusting mechanism should be inspected periodically as follows:
    1. Depress the clutch pedal and look for the pawl on the self-adjusting mechanism to firmly engage the teeth on the ratchet.
    2. Release the clutch. The pawl should be lifted off of the teeth by the metal stop on the bracket.
    On 1985 and later models, the hydraulic clutch system provides automatic clutch adjustment. No adjustment of clutch linkage or pedal position is required.
    May 04, 2009 | Chevrolet Cavalier Cars & Trucks
    Computers & Internet Logo
    48 people viewed this question
    David Payne
    David Payne
