Hello, I have a Worcester 24i boiler, it has a round clock with a grey outer ring,that can be pushed in(the grey bits around the clock), I would like to know how to set the timer on this boiler, it's really important , because I have contracted pneumonia twice, the last time I got it was because I had not turned on the boiler( have been turning the heating on and off manually, if I forget to turn the heating on, i wake up to a cold house, which could put me back in hospital)thank you to anyone who can help
  • 3 Answers
When the grey bits are pushed in the boiler is set to come on for that 15 min incriment. Push they grey pins "in" for the required length of time you want the heating on and then set your manual on off switch to the middle position which will activate the clock to run through the set time sequence you have put in.
Posted on Oct 07, 2009
Thanks for the above, but on which setting do i have the thermostat at. basically the dial that is separate from the boiler (mine is in my living room).
thanks
Posted on Dec 29, 2009
Hi I have a 24i worcester boiler I have drained the heating to do some work but I need the hot water to still work.I spoke to Bosch and they said I need to put a loop in.I am not a plumber but can get
Hi Steve, I am not a plumber but have done a lot of DIY on my own heating system with Worcester Bosch combi boiler! I believe that you can have the hot water on without the heating system filled, just turn all the settings as for summer use and the thermostat right down so the heating is forced to stay off!
Nov 07, 2014 | Water Heaters
Worcester 24i instructions
I'm assuming your talking about the water pressure in the system?
Aug 27, 2014 | Heating & Cooling
Hello, I have a Worcester 24i boiler and the heating is working fine but the hot water will only stay hot for about a minute at a time in the kitchen sink, the shower is ok but only when the heating is on....
http://homeguides.sfgate.com/flush-out-tankless-hot-water-heater-53060.html
The link is to how to flush a tankless system.
This should be done once a year.
https://www.manualslib.com/manual/554372/Worcester-24i-Rsf.html?page=2#manual
This link is to the manual on the unit.
On my unit, it the hot water is running slow the unit turns off and the hot water goes cold, so for me its run the water on full.
Dec 21, 2017 | Water Heaters
Worcester 24i boiler..how do i re-ignite the pilot light??
Overheat thermostat has tripped. If a modern Worcester need to press reset on control panel.
If older style Worcester - Pull front cover off the boiler (just above control panel flap pull the cover from both sides forward to unclip and then lift upwards to remove cover) and you will see a little brown reset button - press this back down.
However the over heat thermostat trips for a reason - was the system running on low pressure? It could be the pump is sticking a bit (dirt in the system) which can be sorted easily by adding an additive (DIY packs available at Home-base) . Or it could be the pump has completely gone. If this is the case it will trip again as soon as the boiler clicks back on.
Apr 27, 2011 | Heating & Cooling
My worcester bosch 24i junior pressure keeps dropping if i have heating off for an hour i have to top up boiler and reset also when i have heating on the pressure jumps right up to over 4.0bar
When water is heated it expands. To deal with this all boilers are fitted with a small expansion vessel which is like a reservoir which holds the excess water.
This expansion vessel is like a balloon in a metal pot. When the water goes in the metal pot the baloon squashes a bit to make room for the extra volume of water. When it cools the balloon pushes the water back into the heating system.
What has happened is your expansion vessel no longer works. When the water heats up there is nowhere for it to go so the pressure jumps up to 4 bar. The Worcester boiler lets high pressure water escape (most boiler allow this to go through the safety valve at say 3.5 bar).
When the water cools the pressure drops very low as the volume of water contracts.
The problem is your expansion vessel - normally a little red painted metal cylinder inside the boiler.
Dec 22, 2010 | Bosch Water Heaters
Bosch Worcester 24i Boiler
Hello MisNicey!
soory to tell you that you stuff needed a serious troubleshooting in each parts and the repair tech or the service tech in your area can torubleshoot in person. since i am far from your location. melnavz
Mar 15, 2008 | Kitchen Ranges
Heating & Cooling Logo
1,358 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
