Question about Samsung Digimax S500 Digital Camera
The end button doesn't work and i can't turn on my phone
My phone screen is black
The first thing to try is to pull the battery out and put it back in. If that doesn't work then I would contact your carrier (sounds like AT&T?) and see if the device is still under warranty. The phone number to their warranty department is 1-800-801-1101. With modern cell phones, especially touch screens, this issue is not really possible to fix on the consumer end without just replacing the device. If the warranty thing doesn't work out go in to your local store and see what they can do to help you.
May 20, 2012 | Samsung Galaxy S Infuse 4g Sghi997 Black...
How do you turn on a samsung character if the end button is broken?
well see EVERYTHING but my end call and back button doesn't work. Does any one no any other way of fixing this besides going some where and getting it replaced?
Mar 15, 2012 | Samsung Cell Phones
Trying to unlock google password and it want let me get out of it
leave the phone on take the battery out this should reboot the phone
Oct 07, 2011 | HTC EVO 4G Smartphone
Smartphone stuck in flight mode
Remove the battery then wait for a few seconds, andthen re-install it. After re-installing the battery, turn on the phone. If this doesn't work follow following steps to reset the phone. But this will erase all your personal data,downloads and settings. The phone will restore to factory default. So think twice before doing this.
  1. With the phone turned off, press and hold the HOME and BACK buttons, and then briefly press the END CALL/POWER button. The reset process will start after a few seconds.
  2. Wait for the phone to finish the reset process and then press MENU.
Oct 07, 2011 | HTC Hero Smartphone
The end button doesn't work can still push it but it doesn't respond (the phone accidentally got wet the other day if that had someting to do with it)
It probably has something to do with getting wet. If you can manage to open your your phone then I suggest you open it up and wipe clean it with a dry cloth. Just be sure to return the parts back properly.
Jun 19, 2011 | Cell Phones
My phone wont turn on
Try a battery pull.
If that doesn't work, try a Hard Reset.
Hard Reset
1. Power off phone
2. Use hardware keyboard
3. Press and hold the 'X' key and Power button until you see a screen with an exclamation point inside a triangle
4. Press and hold the Volume Up key then press the Camera button (I had to do this twice) to get menu screen (Linux back-end becomes VERY apparent here)
5. Using the D-pad, select one of the Wipe options (specifically Wipe Data/Factory Reset)
6. Confirm your selection and wait for it to complete
7. Reboot the device
if the problem still persists, your phone might have water damage and may need replacing.
May 30, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
Hang up
I had the same problem > HARD RESET worked. Press and hold the TALK and END buttons, and also press the RESET button [at the bottom of the phone], all of this in the same time.
Then release the RESET button but continue to press the TALK and END buttons, and a message will appear asking you if you really want to reset everything.
Nov 26, 2007 | HTC Touch P3450 Smartphone
Samsung Digimax S500 Digital Camera Logo
42 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
