Question about HP Pavilion dv9000z Notebook
I dropped my laptop (Hp dv9308nr). When i press the power button it would turn on but the screen stays blank. It had worked right after i dropped it but the next day i got nothing.
  • razmole Sep 30, 2009
    i did that but still nothing. the screen won't reach the bios
    where is the ribbon and how do i get to it
HP has tape holding the ribbon on the back of the lcd screen. I have had alot of issues with the tape comming off or releasing the ribbon. try resitting the ribbon
Posted on Sep 30, 2009
  • cokeandcandy Sep 30, 2009
    you have to open the laptop, just the screen screws, iehttp://www.insidemylaptop.com/images/pav...
    here is the sit that can help you open the laptophttp://images.google.com/imgres?imgurl=h...
  • 496 Answers
Could be the hard drive has gone bad or damaged from the drop try removing it and see if it boots if it does then its the hard drive if not then it could be the memory check it and see if its loose remove it and try and boot if you can then its the memory
    Guru:
  • 1,049 Answers
There is also the possibly you damaged the port for the power adapter in the back of the laptop and that it is no longer charging the battery, in that case you would have run until the battery died. If you were in suspend mode overnight, you would not have gotten a message indicating low power.
My hp laptop is blank screen when turned on
This sort of problems happens some times due to the collection of static electricity in the motherboard. to solve this you have to :-
1) shut down the laptop
2) take out the power adaptor
3) take out the battery
4) press out the power button for one minute.
5) put in the battery and the adaptor and try to switch it on.
if it doesnt work switch on the laptop and as soon as it is on tap the F10 button repeatedly. you will enter the bios screen press F9 to set it default. then press F10 to exit.. You will have to use the four arrow keys to select the options and enter to choose it.
Sep 26, 2014 | HP Computers & Internet
My hp G60-635DX screen is blank . When i turn it on i cant see anything its just blank screen. I can hear it turn on and if i was to type in my password it would go through and start up jist my screen is...
Try This and see if it resets the whole system
This works for a Sony Laptop.
Remove AC power
Remove Battery
Press the power on button for 30 seconds the release.
Install the battery
Providing that the battery has a sufficient charge, it should turn on. Mine did, and a Sony Technician provided the tip.
Good Luck
Jul 21, 2011 | HP Computers & Internet
My laptop went to hibernate and I cannot wake it from that mode. I only have a blank screen.
you have to press the power button once to get it out of hibernation. If nothing else works you can do one of two things:
1] Press and HOLD the power button for about 5 seconds or until you hear the laptop turn off. Then turn it back on again by pressing the power button momentarily.
2] You can DISABLE hibernation. To do this - follow these steps,
  • right-click the desktop and click on and click on "properties".
  • click the screen saver tab.
  • click the power settings button
  • in the power options properties dialog box click the hibernate tab.
  • uncheck the enable hibernation check box.
  • click OK then click OK again
Hope that helps
Good Luck
Feb 07, 2011 | HP Compaq Presario V3000T Notebook
Pavilion dv9308nr PC Notebook: hp dv9308nr wont power on all the time... works if...
Due to regular use of the notebook, some static charges tend to stay in the computer, and sometimes results in not allowing the computer to function properly.
Please follow the power drain procedure to confirm the same:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30seconds to 1 minute.
4. Put the Battery in.
5. Reconnect the AC adapter.
6. Turn on the Notebook power.
7. Restart the Notebook.
If the Notebook boots up you may fix the battery back. Try restarting the computer only with the AC power, without the battery & vice-versa. If the issue still persists then I request you to reset the memory modules, as sometimes the memory module connection get loose.
May 17, 2010 | HP Pavilion dv9308nr Notebook
Blank screen
remove the battery and adapter. press power button for 30 sec. then connect the adapter. press power button. if this didnt work. you need to ask for an help of a local tech to check for the video card and cable.
Mar 06, 2010 | HP Compaq Presario V6000T 15.4" Notebook...
My laptop turns on, but the screen stays blank.
1. Make usre you charge ur laptop for max 1-2 hours.That increase ur laptop life.
2. Take out the battary,Press and hold the power button for 1 min.Put the battary back and turn on.
Oct 06, 2009 | HP Pavilion DV6700T Notebook PC
My laptop comes on but the screen stays blank??
Unplug the power, remove the battery and then hold the power button for 30 to 60 seconds. Then reattach the power and attempt a boot. It worked for me! Just shutdown, put the battery back in you're good to go. Worked for me so definitely worth a try.
Good luck
~Phil
Jan 09, 2009 | Computers & Internet
The hp altec lansing laptop wont turn on, you press the power button and you get this flashing electric looking icon that comes on and it's pluged into the wall. what could be the problem?
my hp altec lansing laptop doesn't opwer on, the button lights up for 1 second and then shuts down,nothing happens to the screen, it stays blank
Aug 27, 2008 | Sony VAIO R505JL Notebook
Blank screen
the power is supposed to stay on when that little plastic button is pressed(screen switch)the screen switch activates hibernate and power saving;if you press the power button a screen will open informing you what programs are currently working.by shutting down you have caused an illegal command.
hopefully if you restart in safemode then shut down correctly and restart every thing should be ok.
Mar 03, 2008 | Dell Inspiron 700M Notebook
Blank LCD on the camera
The camera turns on but the screen stays blank and I press any button and do not do anything no zoom no nothing and I press the menu button but neither nothing shows up just the blank screen
Jan 16, 2007 | HP Photosmart 620 Digital Camera
HP Pavilion dv9000z Notebook Logo
331 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
