Question about Cub Cadet Garden
My left side wheel unit does not run smooth and at the same speed as the right side. I have adjusted the linkage but it does not help
  • 472 Answers
SOUNDS LIKE IT NEEDS NEW WHEEL ON THAT SIDE I WOULD PUT 2 NEW ONES ON
Posted on Sep 30, 2009
How can I adjust linkage on my 2015 zero turn husqvarna mower
If you follow the control arms down to the Hydrostatic hydraulic pumps on either side with should be a bolt that will adjust the forward and reverse aligning of the arms. if you are adjusting the speed of either side, there should be a flow adjustment screw on the pumps as well. Usually backing the screw out will slow the movement of one wheel and adjusting the screw in will speed the movement up of one wheel. Each wheel is done individually.
Nov 10, 2016 | Husqvarna Garden
I have a yamaha 1981 pasola scooter and i sometimes starts but sometiimes doesnt. i.bought a ignition coil but it not that. what is the lil blak box that the coil wire connects to? cos thats the problem...
Instructions
  1. Spark Plug and Sensors
    • 1 Park the motorcycle on its center stand. Remove the spark plug-wire cap from the plug by hand. Loosen and remove the spark plug from the cylinder head with a spark plug wrench.
    • 2 Gap the spark plug to 0.026 inches with a spark plug gap gauge. Reinstall the plug tightly in the cylinder head with the plug wrench. Reattach the plug-wire cap by hand.
    • 3 Detach the wire lead at the fuel sensor on the right side of the cylinder head by hand. Loosen and remove the sensor with a metric wrench. Clean the inner end of the sensor with spray cleaner. Reinstall the sensor securely with the wrench. Reattach the wire lead.
    • 4 Detach the wire lead at the exhaust sensor at the underside of the muffler by hand. Loosen and remove the sensor with the metric wrench. Clean the inner end of the sensor with spray cleaner and reinstall the sensor securely. Reattach the wire lead.
    Throttle and Carburetor
    • 5 Take a position where you can observe the throttle linkage at the left side of the carburetor. Twist the throttle grip at the handlebars slowly as you observe the action of the linkage.
    • 6 Tighten the cable adjuster at the top of the carburetor with a metric wrench in small increments so the linkage responds immediately as you open the throttle.
    • 7 Start the engine and allow it to warm up for three minutes. Locate the smaller idle-adjustment screw and the larger fuel-air adjustment screw at the right side of the carburetor. Turn the idle-adjustment screw to the right one full turn with a screwdriver.
    • 8 Turn the fuel-air adjustment screw to the right or left with a screwdriver as you listen to the engine's speed. Turning it too far either way slows the engine's speed. Find the point where the engine idles at the fastest speed.
    • 9 Allow the engine to idle. Turn the idle-adjustment screw to the left one full turn.
Jan 14, 2013 | Motorcycles
The right wheel seems not to be working smoothly. When I try to drive straight it veers to the right slightly, like the left wheel has more more. It is also hard for the chair to turn left because the...
Hi Jack
Sounds Like all you need is for a technition to program you chair. They can do an adjustment to compensate the different strengths of each motor and make the chair run straight Also to improve the turning speed adjustments. Programer is a P&G PP1
Good Luck
mimobility
Apr 26, 2011 | Pride Jazzy 1103 Ultra Standard Power...
Steering wheel wabbles at low speed and left side sounds like wheel is wableing
jack up the the left side push and pull on the tire to see if it has play watch to see if it is in the wheel bearing or control arm or ball joints check for play in all of the linkage
Feb 19, 2010 | 1994 Dodge Caravan
I have a older model # 30 jiffy ice auger and i can not seem to keep it running consistanly. I was wandering what the carburator adjustments are. The low idle screw and the high idle screw where do I start...
Hello Randy. I can talk you through making adjustments to your Jiffy ice auger engine.
1. Read through the whole list before you start adjusting.
2. Close both jets GENTLY
3. Open the Low speed 1/4 turn
4. Open high speed jet 1 1/4 turn
5. Start engine.
6. Adjust low speed until idling smoothly.
7. Open her up wide open.
8. Adjust High speed until engine transitions smoothly from idle to high speed without bogging.
9. Shut engine off. Let it cool.
10. Once engine is cold. Fire it up and let it idle for 30 secs. Open it up wide open again. Adjust if necassary.
NOTE 1: The trick with the Jiffy's is to tune them during cold (ice fishing) weather.
NOTE 2: Low speed screw,the one on the left.
NOTE 3: High speed on the right.
Good luck ice fishing! Regards, Joe
Dec 31, 2009 | Sport & Outdoor - Others
I have a Pride Legnd..the scooter started loseing speed, I would adj the speed pot and the unit would stop, adjust back down and unit would run, but slow. I left the speed speed controller alone and unit...
hi, first you need to check the connections to the batteries then to the motor controller, and don't dismiss the speed pot, disconnect the speed pot and try a normal 5K pot inplace of it, if the scooters responds you find the problem just a case of getting the right speed pot. Check the freewheel switch, normally it located on the motor side.
Regards
GeWiz.
Dec 15, 2009 | Pride Mobility Victory 3 Wheel Electric...
I have a 1982 Oldsmobile 4door Cutlass it has a 3.8 liter V-6 with a 2 bbl carb....the car is idling OK but when you step on the throttle it starts to run rough and very poorly...to keep it moving you have...
SOUND LIKE YOU MISSING THE IDLE SPEED SOLENOID.I REMEMBER I HAD A 81 OLDS 260 V8.IT HAD THE 2 BARREL ROCHESTER.IT HAD THE IDLE SPEED SOLENOID MAKING CONTACT TO THE THROTTLE LEVER.
Aug 11, 2009 | Oldsmobile Cutlass Cars & Trucks
Girls Huffy 16" bike - back wheel does not spin freely. It tightens up after a few spins.
Try the bearings. Try a different wheel and rim. If its not the wheel then the crank bearings( ones the pedals are on) could be bad or the chain could be not set right.
Dec 24, 2008 | Huffy 16 In. Girls Dora The Explorer...
Poor printing
Ok,
found a (the?) solution deep down in the web, and it worked for me: The four cartridges are hinged in a big gear wheel left and right of the printer. The wheel is driven by two small gear wheels sitting on a shaft abovee. It can happen that the gears jump one or two tooth on one side, then the cartridges are no longer aligned with the transfer drum (you can see the different gap size from top).
Solution: Take out the cartridges, the drum kit and the fixing unit. Select the black cartridge. Undo the power cord. Undo the side panels (screw at the bottom, then hooks). Take off the rear top panel at the printed paper bay (there are screw driver signs left and right, lift there. Do not try to lift this panel from the back side). Take a close look at the gear wheel linkage of the top cover at the right side, you need to reasemble this afterwards. Take off the top cover. Now you can see the shaft with the small gear wheels driving the big ones that carry the cartridges. When the black cartridge is selected, the two little notches on the small wheels must align with a pale stripe on the big wheels. You can bend the big wheels a bit to move the gears towards each other. You can turn the wheels when you lift the electromagnetic lock on the top right side. Once aligned, put back the top cover in place (with the linkage on the right side). Then you can start a test run after cartridges, drumkit and fixing unit are back in place.
Hope this helps you!
TB
Oct 14, 2008 | HP LaserJet 2550n Printer
Garden Logo
116 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
