Question about SanDisk Sansa View 8GB MP3 Player - Black
Sansa view white screen
Screen went blank, no display. Can't charge it. End of life?
    President:
  • 803 Answers
Yep All you can maybe try is this:
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the SanDisk website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
Posted on Oct 01, 2009
My Kindle went blank with almost a white screen tho fully charged and now wont turn on at all. Have followed Amazon's suggestions but nothing works. Can you help?
Chances are your screen went defunct. Or it could be a problem with some other piece of hardware. You can try using the USB cord to plug it into the USB port on a laptop or desktop and see if the computer can read the files. If it can display and explore folders and files, chances are it's the screen (display) that went south. It it can't display and read folders and files chances are it's the memory or some other internal hardware that died. Sadly these things are cheaper to replace than to repair. I have a Kindle II with a faded out display. It works but the text is so light that it's barely readable so I retired it. I have a Kindle Touch that I dropped and the screen broke so I ended up getting a Kindle Paper White and I like it the best of them all.
Apr 22, 2015 | Amazon Kindle 1
My new uniden phone,xdect6145bt+h ,the display screen went blank what should i do?
You phone is completely discharged, it should be charged while charging some kind of icon should appear on screen indicating charging is in progress. If nothing appears then your phone's charging system has gone damaged and to be taken to technician.
May 15, 2014 | Lands Phones
30" apple cinema display suddenly went blank.
It's probably the backlight. If you look very closely, perhaps using a flashlight, you might be able to see that it is still working but just not being lit up from the back. In that case it may be worth fixing, but if not, then it's probably past its useful life.
One other thing you might try is a different power supply.
Feb 14, 2014 | Apple Cinema HD 30" LCD Monitor
The display screen is blank, phone still works. How to fix?
I am having the same problem with my KX-TGA234W. One day the screen just went blank, so I changed the battery, but it still is blank. I hope that someone can help both of us.
Apr 18, 2010 | Panasonic KX-TG5632 Phone
Booting up,but not coming on
try taking the batterey out for about thirty seconds(check for water damage while your in there) put battery back and that should fix it
Jul 26, 2009 | Acer DX900 Smartphone
Screen show no display/ only blank.
You could have a faulty inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jun 27, 2009 | HP Pavilion dv6000z Notebook
Blank Screen on Garmin C330
It took a nap...
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Dec 11, 2008 | Garmin StreetPilot C330 GPS Receiver
SanDisk Sansa View 8GB MP3 Player - Black Logo
200 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
