Question about K-Tec Kitchenetics K2 Stand Mixer
K-Tec My mixer will turn on and begin to work and then when I stop it and try to turn it back on again it won't turn on.
    Problem Solver:
  • 10 Answers
The company handles these as Blendtec now. The web site is at http://www.blendtec.com/default.aspx Maybe this will help:
Customer service and sales are available from 8:00 am to 5:30 pm (MST) M-F.
Phone
Toll Free: 800-253-6383
Local: 801-222-0888
Fax: 801-805-8585
Posted on Feb 09, 2008
Kitchenaid kp26m1xer won't turn on
If the mixer died completely and no noise at all comes from the machine you need one of three things.
1. New brushes2. new speed control switch3. a new motor.
The KP26 is a 6 quart mixer of the new design, post 2002, it is easy to work on and relatively inexpensive for parts if it turns out to be the motor that will be about $100.00, the speed control about 30.00, the brushes on this mixer cannot be replaced you have to install a new motor, sry about that. Hope this helps let us know. But first check that the electric outlet you are working from has not tripped the breaker on the circuit too. I know I know it's silly to say but check the outlet first before you spend a dime on anything.
Mar 11, 2013 | KitchenAid 32685 Mixer
Kitchenaid mixer 600 won't turn on
bread is very tuff on mixers. always buy the strongest mixer that you can afford. im guessing the field in the motor fried.
Feb 07, 2013 | KitchenAid Kitchen Aid KP26M1X 6 Quart...
Won't Turn On
There could be several problems some painful some not so much, the simplest one is bad wall plug or bad plug wire, the hardest is that the motor burned out, but i don't think so. The most likely solution is the speed control switch. There are three scres on the switch in an inverted triangle shape/form. The one on the bottom has probable been turned just enough to stop your mixer from working. The speed control switch that you use pushes against the screw every time you turn your mixer on eventually it can turn by pressure and it will shut your mixer off with just a 1/16th inch turn. It is a very simple fix.
Where is the speed control switch? Glad you asked. It is in the rear of the machine. There is a round bubble shaped cover at the rear of the mixer called the end cover, it has one screw (Phillips head) on the top. Take that screw out, then grasp the cover and lift up and away from the mixer. Be careful there are two fragile hooks on the cover that can break if you twist it left or right, just lift up and pull away. when you have removed the cover you will see a black and copper plate staring back at you (it might be all dusty with flower and food particles) look for the adjusting screws at the top left and right corners and one at the bottom center of the plate. The one at the bottom center is the culprit. Take a Phillips head screwdriver and turn it left an eighth of a turn and turn the machine on, if it doesn't work leave the machine on and turn the screw in the opposite direction . ill bet a steak that the mixer starts. if it does you need to replace the speed control plate or take the screw out and put some lock tight on it. BUT!!!! when you do this you will have to completely re-tune the speed of the machine. So if it starts just leave it and you may have to do this once or twice again in the next ten or twelve years. Let us know if this fixed the problem. there are several other possible causes that could make the mixer stop but they are more painful.
Nov 18, 2012 | KitchenAid K45SS Classic Stand Mixer
Black and Decker Spatula Smart Hand Mixer
1990? Dump it and purchase a new one
Mar 17, 2017 | Food Mixers
My 6qt Kitchenaid stand mixer started making a grinding noise and beater bar keeps stopping. When I put it gently with my finger, it begins turning, only to stop again and make that grinding noise. It is...
They seem to have a plastic gear built in as protection for overloading (prob). When the machine counters to much resistance that gear will strip its teeth causing the machine to not be able to turn, that it what seems to be the grinding problem. If it is not the plastic gear then it another gear that is "stripped(of its "teeth") I hope your problem is not a severe, but if your mixer is "locked up" then at least you found the problem.
Jan 12, 2010 | KitchenAid KSM150PS Artisan Series Stand...
K-tec Kitchen Champ 2000 manual information needed
Type into the search box above. Blendtec and it will return with nimerouus appliance sites. Some sites carry all sorts of brands and parts including manuals _Good Luck_ Ned
Oct 31, 2009 | Food Mixers
Kitchenaid Classic -Mixer Head wobbles or shakes back and forth
Lay the mixer on its side and look up through the base. You willnotice a small set screw. This holds the pin tight. If the set screw gets loose the pin willl begin to move out and the head will wobble. Simply tighten the set screw. I just did this to my Kitchenaid mixer 10 minutes ago and it now works fine.
Oct 29, 2008 | Food Mixers
Need new beaters for my k-tec champ mixer....
Phone
Local: 801-222-0888
Fax: 801-805-8585
Nov 15, 2007 | K-Tec Kitchenetics K2 Stand Mixer
K-Tec Kitchenetics K2 Stand Mixer Logo
145 people viewed this question
Top K-Tec Food Mixers Experts
Oscar Netto
Oscar Netto
Marvin
Marvin
Are you a K-Tec Food Mixer Expert? Answer questions, earn points and help others
