Question about Sanyo SR-9510W Refrigerator
Aside from licensing is there a reason I cannot replace the freon in my Sanyo sr-9510w
  • 2,605 Answers
Hi, First check your unit's owners manual regarding the warranty as it pertains to the "sealed system" as this would fall under that, with the exception of a puncture inflicted by the consumer. Now, aside from licensing...Check your state laws. It is illegal to "recharge" a system knowing a leak exist's without first repairing such a thing, if indeed one does/did exist (I assume if it is in need of a "freon/refrigerant charge" it has leaked). I could be wrong, but I think it's against federal law in the U.S.A. to do so without a license. I know for certain it is illegal in the country I reside, Canada. Hope that helps. Good luck
Posted on Sep 30, 2009
Freon valve location on a sr-4433s sanyo compact refrigeraior
There are generally no service valves on refrigerators. Unlike car A/C refrigerators are designed NOT to leak so need no "recharge" If you are leaking freon you must have the leak fixed. A temporary service valve is attached after the repair is complete, charge is brought up to spec and then valve is removed and the tube it was connected to is soldered shut.
Dec 08, 2014 | Sanyo Refrigerators
I have a Sanyo Compact Refridgerator Model number SR-8k. I accidently punctured the rim of the ice tray area and gas came out. is there any way to fix it? Thank you, Rick Caldwell
not sure , but try you tube. put in your problem in the search bar and put you tube on the end and it should take you to a video with the problem you are having!! you tube is a life saver as well as a money saver!!!
Jan 29, 2014 | Sanyo Ref SR-8K S
Excess frost and condensation
Could be that it is not getting a good seal when the door is shut. Check for obstructions causing that and check the door seal to see if it needs to be replaced.
Mar 13, 2017 | Sanyo SR-9510W Refrigerator
Re: Sanyo SR4310W mini fridge freezer plate broken
Ok, I know I should not have done this but I did. I was impatient with the defrosting and stabbed my Sanyo SR3770s' evaporator with my Smith and Wesson switch blade knife. A very tiny hole, made a swooshing noise and now the fridge won't get cold. Can this be repaired for a minimal price? Perhaps just replacing the evaporator plate and reinstalling some freon, maybe, hopefully?
Let me know. Basically a brand new unit, hate to see it go to the dump!
Sandra
Jul 20, 2009 | Sanyo SR-4310 Compact Refrigerator
Glass shelve on bottom over grisper is broken Sanyo SR-9510W
You didn't say what size or model Sanyo you have, but the solution is easy. I have a Sanyo under the counter refrigerator in which the glass over the crisper is 1/8" thick frosted glass, 16" by 6 3/4" with the two back corners cut off diagonally. The frosting is simply to prevent you seeing through into the crisper below. It is maybe fifteen minutes work with a piece of window glass and a glass cutter to make a replacement. My full size refrigerator uses 1/4" glass since it is much larger and I have replaced it myself this way. If you don't have a glass cutter -- they are cheap and available in all harware stores -- you should be able to get any hardware store to make the cuts for you. They are accustomed to making custom cuts for people replacing their own windows. The have, and I use, what is known as an oil cutter which is a lot easier to use than the little hardened steel wheel cutters you will get if you buy a cheap one. Those work fine for straight cuts. Oil cutters make curver cuts equally easy to do.
Dec 07, 2008 | Sanyo SR-9510W Refrigerator
Sanyo Eclipse refrigerator (Model# SR-4433S)Has puncture hole in Freon Tray for freezer. Does anybody sell replacement part?
HI thanks for the question. if theres a puncture in the coils . scrap it way too expensive. sorry.
Oct 15, 2008 | Sanyo Refrigerators
Sanyo Mini Fridge
Same problem - When defrosting and moving away frost had a spray come from the left side of fridge. Can I repair - if a leak and how to add more freon?
May 03, 2008 | Sanyo SR-4910M Compact Refrigerator
Where to buy Sanyo SR-366 parts? I need a freezer door.
I will probably have one, I'll look to see if it can easily be removed.
Apr 03, 2008 | Sanyo SR-366 Compact Refrigerator
Freezer compartment on Sanyo SR-3660S
Nope. That's about $800 bucks in damage that only a licensed professional CFC tech could "possibly" repair with very specialized equipment. I'm afraid that was a fatal blow to your refrigerator.
Feb 04, 2007 | Sanyo SR-3770S Compact Refrigerator
Sanyo SR-9510W Refrigerator Logo
117 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
christian nielsen
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
