Question about Radio Communications
I have a 1991 honda accord w/factory radio which is locked do to the anti theft device. I can't find the code or serial # on this it is a am/fm cassette combo please help
  • 4,944 Answers
First make sure that the code has not been noted somewhere within the car (underneath the ash tray, glove box , rear of sun visor etc)
To see if your code is available here for free then the radio will have to be removed from the dashboard (and if you are lucky, someone may have written the code on the casing ) .
If not then POST ANOTHER QUESTION
quoting the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on ANY LABELS ,BARCODES or STAMPED IN THE METAL CASING
note: Unfortunately not all radios can be decoded using the Serial Number
If not then try your Main Dealer ...........or take it into a Decode Service who will plug in a laptop to read/recode the memory chip (EEPROM). This takes a few minutes and shouldn`t be too expensive
Posted on Sep 30, 2009
2004 Accord with nav, radio code
take to a garage and get a diagnostics or buy a new raido i have one for sale ;-)
Apr 13, 2010 | 2005 Honda Accord
Hi there I have 1993 Honda accord EX-R Sedan with Original Stock Radio, which got the Anti-theft lock Code on it..I believe the Serial numbers are FAO31116B for the radio ..I don't have the Code for it to...
Honda indicated the following (since there are an almost infinite number of codes):
Once you have the audio unit serial number, you can call Auto Customer Service at (800) 999-1009 or have the dealer look up the radio code.
Hope this helps you.
Nov 11, 2009 | 1993 Honda Accord
The battery died on my 2001 eclipse, now the radio only says ''off''?
This is the anti-theft device on your factory radio. When the battery died, the radio thought it had been removed from your car and went into anti-theft mode. When you turned the car back on, the radio should have read "CODE" on the display, at which point you need to enter the factory anti-theft code. After 3 failed attempts at entering the code, it will simply read "OFF" and the radio is locked.
At this point:
- find your factory anti-theft code - it should be in your owner's manual, or you can contact a dealer to retrieve it
- turn the key to the ACC position (radio and accessories on, but engine is off)
- turn on the radio so the display reads "OFF"
- let the car sit for 1 hour
- radio will turn off automatically and reset
- turn the radio on again, and it should read "CODE"
- enter the factory anti-theft code
Make sure you have the code before starting the procedure. To enter the code, use the radio preset buttons. For example, if your code is "4321", hit Preset #1 button four times, Preset #2 three times, Preset #3 two times, and Preset #4 one time. Then hit the "Tape" or "CD" button. Radio should now be unlocked.
Sep 13, 2009 | 2001 Mitsubishi Eclipse
Need radio code for 2001 honda accord lx anti theft lock code to unlock radio
*** Please click the "Was this helpful" Yes thumbs up! ***
FREE and EASY methods to get your Honda radio UNLOCK CODE. (Dealerships usually charge)
Assuming you don't have the Anti-Theft Code and Serial Number that is found on the credit card sized Anti-Theft Radio Identification Card that comes with the vehicle at the time of purchase and is usually found in the glove compartment....
You have FREE options to retrieve that code by phone or on the internet BUT, the RADIO SERIAL NUMBER is REQUIRED (no matter what). (see bottom about removing ERROR E3)
***IF your Honda was made BEFORE 2001 the serial number MAY not be accessible without removing the radio from the vehicle.***
* TO GET THE SERIAL NUMBER (so that you can get the unlock code)
1. Get something to write with and on (you'll need it to write down the serial number)
2. Put the ingnition key in and turn it until your able to turn your radio on (accessories position).
3. Then turn your radio OFF by it's knob/button (but leave the ingition key in place).
4. Hold down the preset buttons 1 and 6 at the same time.
5. Turn the radio on while pressing down both the 1 and 6 buttons.(***IF your Honda doesn't have preset buttons on the radio then hold down the top part of the 'Seek/Skip' button AND the top part of the 'Change Disk' button instead.*** )
6. Write down the 4 numbers you see first and then 4 more that display. These eight numbers are the SERIAL NUMBER. This is NOT your CODE.
7. Make sure your VIN (Vehicle Identification Number) is handy to get the unlock code. (can be found on your insurance card, driver's side door jam, small plate on dashboard by registration and inspection stickers, etc)
* TO GET THE UNLOCK CODE (using the radio Serial Number and VIN)
---Internet option:
1. Go to https://radio-navicode.honda.com/ (YES, it's run BY HONDA and IT'S FREE)
2. Follow on screen instructions (Serial Number and VIN required)
3. Type in the 5 digit code into your radio. This will unlock the radio and return it to a functional state.
-OR-
---Telephone option:
1. Call American Honda Customer Relations (800) 999-1009
2. When the automated message starts 'Press 3' for 'Radio and Navigation Codes'.
3. Tell the Customer Service Agent you need your radio code. (They will ask for your name, your radio's serial number, VIN, etc)
4. When they give you your radio unlock code--WRITE IT DOWN and KEEP IT SAFE!
5. Type in the 5 digit code into your radio. This will unlock the radio and return it to a functional state.
* REMOVING ERROR E3
****If you entered too many wrong codes and got an ERROR E3 message displaying you'll need to do an additional step for even the correct unlock code to work.****
Disconnect your negative battery terminal (or pull the radio fuse out if that's easier for you) for 30 seconds then reconnect it and then the radio will say "CODE" again and you can put in your correct unlock code.
So what happened to begin with?
See also: http://automobiles.honda.com/information/frequently-asked-questions.aspx?Question=2
If the power from your battery to the Honda radio is interrupted the Anti-Theft feature kicks in, the radio is rendered inoperable and the screen reads 'CODE'. You must enter in the Anti-Theft Radio Unlock Code (usually 5 digits) to make it operational again. You know that much by now.
Sep 09, 2009 | 2001 Honda Accord
I couldn't turn on radio cassette in my car (honda) because it has anti theft lock. Radio cassette Model:39100-SV2-A000, serial number: 724372, please help.
all the codes are different if it is a factory radio and you don't have the code in the owners manual you can go to the dealer with the vehicle and proof of ownership of the car and they will pull the code up for you to unlock the radio it is a theft that's why they need proof of ownership
Aug 28, 2009 | 1998 Honda Accord
Unlock radip code,1998 honda accord 4 door
if you do not have original anti-theft radio code you will need to remove radio and retrieve s/n off of radio. once you have that you can go into nearest honda dealer and with s/n they can give you correct radio code
Jun 05, 2009 | 1998 Honda Accord
Unlock code for 1991 Honda Accord Factory Radio
Pull the radio then call a Honda dealer with model, serial number & vin to your car. They will give you the code.
Apr 29, 2009 | 1991 Honda Accord
Got this number off the top the radioM1C402033 NEED THE CODE FOR 1917 HONDA ACCORD?The Vin is1HGCD5601VA172613
This is a Anti-theft feature. Take the Radio serial number, your Accords registration or another proof of ownership along with your photo ID that matches it to any Honda Dealership and they will give you your Radio code.
If you are not the owner or do not have proof that you are, your out of luck. Doing it for a friend or family member, they'll have to come with you. Do not bother calling it in, once again it is a ANTI-THEFT feature : )
Apr 20, 2009 | 1997 Honda Accord
Car radio
Found this on another site.
General Motors coded THEFTLOCK® radios have a backup unlocking code that can be accessed by a General Motors dealer or a Delco® radio repair center if the owner programmed security code is not available. Honda, Acura and Audi anti-theft radios are examples that will require radio removal to access the radio serial number that a dealer needs to obtain the factory security code. Sometimes the original dealer for a vehicle may keep records of the radio security code for factory-coded radios.
Sounds like you may have to remove the stereo so you can see the code on the back.
Then I would take it to a local dealer and prove its your vehicle and give them the serial number.
They should be able to decipher it for you.
Best of Luck.
Please RATE my solution BELOW.
Nov 25, 2007 | Car Audio & Video
Radio Communications Logo
49 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
