Question about Mitsubishi WS-65613 65" Rear Projection HDTV
I have a ws-65613 and the green light keeps flashing and it wont come on ive tried unpluging it hitting the reset button and nothing is working
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
ONLY 1 or 2 things can cause this problem----First thing to do is remove front speaker grill--it pulls out and secured with plastic pegs--behind it you will find an inspection plate---Notice the one or two pairs of wires coming from the front keyboardi have a ws-65613 and the green light keeps flashi - 2.gif of the set---remove the inspection plate and follow the wires to the right--you can unplug both plugs(most have two and they are marked with letters and different sizes so you cannot get them wrong)
The idea here is to remove the front keyboard with its reset button etc from the circuit---You will still be able to try to turn the set on with the remote---these sets have a Receiver(large metal box to the left as you look from the back) and if the power goes out the green light will blink for about 70 seconds and then go out---it is the Receiver booting up.
If disconnecting the keyboard allows the set to turn on--you have a bad reset switch and two choices---either operate the set only with the remote or to remove the front screen and get at the reset switch (it is tiny) and remove and or replace it.
If disconnecting the keyboard does not restore the set to operation---the receiver is bad---there are 4 or more caps and some pico fuses that can fail in that unit---Mitsubishi no longer sells or repairs these--if it is bad and not the caps there is a company you can send the unit to and have it repaired--if you need to know their name let me know---you can call them and get a quote for repairing the receiver.
SD Tech
Posted on Sep 30, 2009
65 INCH-MITSUBISHI TV WS-65908 WILL NOT POWER UP
same problem with mine.. i usaually hit the reset button if it continues you need to get it service. when i called for service i stik had warranty and they replaced a capaciter.. it would of cost atleast $500. GOOD LUCK
Jan 26, 2010 | Mitsubishi WS-65613 65" Rear Projection...
Can't turn on the TV. Green light keeps blinking.
You need to change the four capacitors C9B01,C9B02,C9B10,C9B11 all 1000 MFD 16 VOLT (on the DM board which is inside the metal shield standing upright on the left looking from the back of the set)The tops of the capacitors will look puffed out making them easy to find. This is your HD tuner digital board which is trying to reboot but can't - when the green light stops blinking after a minute,than you can power on your TV.
Aug 26, 2007 | Mitsubishi WS-65613 65" Rear Projection...
Mitsubishi WS-65613 tv green power light keeps blinking tv will not turn on
Unplug the unit for 5 minutes then plug it again. Turn it on. If it does not power up, press the SYSTEM RESET button on the front panel with a pointed object such as the point of a pencil or end tip of a paper clip. The green LED light will flash quickly for about a minute then stops. You may turn on the TV then. The changes you made most recently, before using
SYSTEM RESET, may be lost. Changes you made previously, however, are not lost.
Sep 11, 2009 | Mitsubishi WS-65613 65" Rear Projection...
My tv won't turn on, the timer keeps flashing
http://www.jyerdon.com/tv/
If it`s a 65513 mitsu, this will fix the flashing green light, most of the time, e-mail me with any questions, good luck
buranc@bellsouth.net
Dec 28, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Misubishi WS-65613 Flashing green reset light
do you have the service manual? also have you checked the diodes or protection fuses for the volts out of the loptr ( low output trans) , also check the volts on the trans for no volts , low volts , or voltage drop
let me know what tests and results you have , and if you dont have a schematic yet , this one should be about the same as yours , this is part 1 with 7 zip files http://www.eserviceinfo.com/downloadsm/31768/Mitsubishi_WS-55859.html
this is part 2 with 2 zip files http://www.eserviceinfo.com/downloadsm/37351/Mitsubishi_WS-55859,%20WS-65869,%20WS-55909,%20WS-65909,%20WS-73909.html
electech
Nov 26, 2008 | Mitsubishi WS-65613 65" Rear Projection...
It will not turn on.
i have the same problem with the ws-65613 ,what do i tell the repairmen or how do i fix it my self.
Nov 09, 2008 | Mitsubishi WS-55313 55" Rear Projection...
Blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Sep 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Ws 55513
The constant blinking green light means that the TV is not booting up. This is a common problem on this set.You need to remove the shield from the DM board (standing upright on the left where the DTV RF connector is)and inside you will see the four leaky capacitors (1000 MFD 16 VOLT)replace them,plug the TV in and wait 70 seconds for the blinking light to stop,then turn on the TV.The hard part will be removing the board from the TV(lots of screws and connectors,takes time)
Sep 22, 2007 | Mitsubishi WS-65613 65" Rear Projection...
I can't turn on the TV.
I had the same problem. Unplugged it, reset it, everything. I went to work the next morning and left the light blinking, came home from work and it was off. I turned it on and so far, so good. Just give it some time to reset internally
Mitsubishi WS-65613 65" Rear Projection HDTV Logo
292 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
