Question about Garden
Moves a little after cleaning changing filter and oil. No torque, will not go up hill, no power will stop for a twig on the ground. Originally just stopped. I cleaned filter and changed and no broken were found
  • twozn72979 Oct 06, 2009
    Model- Ariens 93601 Riding Tractor YT15040H Hydro made by Sullivan 036273 5118T3172 USA
  • dsakrison1
    dsakrison1 May 11, 2010
    Brand and model will help with diagnostics
    Sergeant:
    Champion:
  • 257 Answers
Not a expert just trying to help,,i am asuuming the motor is running fine sitting still,,just will not move forward or backward to well,,, check your drive belt to see if there is any problems like pulleys springs or belt worn,,,,hope this help you
Posted on Oct 04, 2009
  • 65 Answers
Sounds like either a drive belt, sheered off axle key, or failing transmission. this is assuming that the engine is running ok.
Posted on Oct 07, 2009
Before I replace my torque convert. (1999 ford expedition 5.4) Is there anything else I can do, for jerking when I speed up, or go up hill ?
the torque converter just supplied power into the transmission separate to the engine
it has little to do with gear changes or transmission problems
jerking may be the transmission jumping in and out of gear ratios because of
dirty oil
blocked filter
loss of fluid pressure from the pump
incorrectly adjust bands and clutch packs
over full or low on oil
talk with an accredited transmission specialist shop as all that I have suggested can be checked without removing the transmission and are relatively cheap to effect
if you have the capability, then run the fault codes as it may be faulty servos/solenoids or TCM
Aug 10, 2015 | Ford Cars & Trucks
My 1995 Chevy Corsica loses speed going up hill and takes a while to pickup speed when I have to stop then go...
How many miles are on the car? What kind of engine? What transmission? There are multiple reasons why a car can lose speed going up hill and then slow pick up in stop and go, start with the basics, air filter clean? Spark plugs good? new fuel filter? Oil change? tires pumped up to proper pressure? Transmission good? Post more and I will try to help
Aug 15, 2014 | Cars & Trucks
I have a Victa by Murray ride on with a hydrostatic trans. With no catcher its moves fwd and rev but not very quickly. It moves at the same speed whether at idle or full revs. With the catcher on or up a...
First check your drive belt, and the fluid level..
if they are good, make sure your linkage moves freely at the transmission. If it's been a while since you did a fluid change if at all, you might try changing the oil and filters on the transmission.
Jul 02, 2017 | John Deere Garden
Lawn mower does not like to go up small hills, is there a filter or a place to check the fluid level
It probably doesn't have a factory filter, but I feel ALL small engines should have. The only fluids to check would be the engine oil and maybe the tranmission lube in the little gearbox (if it is self propelled). I don't know how STEEP the hills you mention are, but if too steep, gas flow and oil cirulation will be affected. Try going up the hill at an angle to reduce the problem.
If there is no dipstick tube on the engine to check the oil level, then look for a little yellow cap at the bottom of the engine right above the deck. It is threaded and twists on and off the engine. I think it is made of nylon.Your oil should always be clean, never black. When it starts getting dirty, change it. Most small lawn mowers hold 20 ounces of engine oil (about 2/3 of a quart).
Jun 13, 2011 | Ariens Lawn Mower Universal Solenoid...
1993 buick le sabre transmission problems AS i AM DRIVING GOING UP HILL THE CAR LOOSES TRACTION
Check first the fluid of your transmission. If this is an automatic you may need to put in additional transmission oil or have the filter and oil changed. It could also be a problem with the torque converter. Check also if the car has a delay in moving once you step on the gas. These are the signs that either a problem with a fluid or torque converter.
For manual transmission, you disk may be slipping of you also notice a delay in power. Have the clutch disk inspected.
Apr 16, 2011 | 1993 Buick LeSabre
When coming to complete stop, I feel some vibration. what could it be. going up hill notice a little hesitation.
Up hill
Bad Ignition Coils
EGR Valve going bad
At a stop and hesitation
Clean MAF and Throttle Plate
CRC MAF Cleaner
CRC Throttle Body Cleaner
You can't leave spark plugs in there over 60,000 miles
Change fuel filter every 3 years along with the plugs
Nov 09, 2010 | 2007 Ford Expedition EL XLT
1987 Subaru GL 4WD - Oil soaked air filter causing car to stutter
Internal engine wear, leaking piston rings, seals, gaskets etc. Time for an engine over-haul.
May 13, 2009 | 1987 Subaru Gl 4WD
Lacks power going up hills
has the fuel filter ever been changed :) this sounds like low fuel pressure.
Dec 24, 2008 | 1993 Subaru Legacy
Engine light flashes when going up hill.
sometimes when you are going up hill your check engine light or your oil light will come on because all of the oil is at the back of your oil pan.
Dec 02, 2008 | 1996 Pontiac Grand Am
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
