Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
I need teh drivers where can i dl them - Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
  • 3,153 Answers
It should not need drivers unless used on windows 98 and even that may cause some problems with speed of transfer etc.
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Sep 30, 2009
Driver webcam samsung NP-RV413
i need the wapcam driver software sumsung rv413 netbook
May 15, 2012 | Samsung NP-RC410 Notebook
HI I NEED GA-K8VM800M MODAL SOUND AND VIDEO DRIVERS
hi
find your drivers from following link
http://www.gigabyte.com/products/product-page.aspx?pid=2318&dl=1#driver
Jan 15, 2011 | Intel Motherboard
I need vga driver
Hi, try the following site for your vga driver, you need to scroll down the page to pick your operating system:
http://www.easydriverpro.com/driver-update/motherboard/asus/k8n-dl/k8n-dl-windows-7.html
Oct 05, 2010 | ASUS K8N-DL Motherboard
I deleted my speakers and soundcard driver by accident, how do i get sound back on my computer?
http://hotfile.com/dl/28511519/c35110f/Open.CD.Drivers.Xp.vista.El_DocToR2.part1.rar.html
http://hotfile.com/dl/28511590/04a0925/Open.CD.Drivers.Xp.vista.El_DocToR2.part2.rar.html
http://hotfile.com/dl/28511631/0fdfc86/Open.CD.Drivers.Xp.vista.El_DocToR2.part3.rar.html
http://hotfile.com/dl/28511693/eccab5f/Open.CD.Drivers.Xp.vista.El_DocToR2.part4.rar.html
http://hotfile.com/dl/28511696/a56a488/Open.CD.Drivers.Xp.vista.El_DocToR2.part5.rar.html
there you go download all these link and then extract, there are 400,000 drivers, trust me your drivers will be in there, kinda of a big file but you didn't specify what your driver. There you go m8
Mar 20, 2010 | Acer Computers & Internet
I just need a 2430 dl driver for Imac!
You did not mention your operating system. Therefore I included all drivers for this product (2430 DL):
You will need to scroll to the heading that matches your operating system to download the correct driver.
Konica 2430 DL Driver Downloads
Mar 02, 2010 | Konica Minolta magicolor 2430 DL Laser...
Dl.exe
Assuming you are running MS Windows NT 4, then try the following as it is a known bug:-
http://support.microsoft.com/kb/245184
If not we can assume that you have tried installing/attching something recently of which the drivers have not been installed correctly for.
An example is the error for the following:-
http://support.microsoft.com/kb/104559
Suspect it is more likely teh second one. You do not have the coreeft driver for something you have attached/installed.
Jun 06, 2009 | Computers & Internet
2wire -Need Better DL Speed, HELP!!
The Ip is 192.168.1.254 this will get into yor modem info hope this helps please rate this
Apr 29, 2009 | Computers & Internet
Flash not discharging
its seems to me that the alignment of your flash setting in its cubicle has been disturbed, possibly by the camera being pressed in your bag. if you cant get it to operate normally, I suggest that you get it done professionally by Pentax.
The reason I am saying this, is cause firstly Pentax is good and branded camera. The settings and all teh mechanism's of this camera are very delicate and you will only damage something within it by forcing your flash out everytime you want to use it.
May 11, 2008 | Pentax *ist DL Digital Camera
Language problem
download english drivers from www.konicaminolta.eu
Aug 23, 2007 | Konica Minolta magicolor 2430 DL Laser...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
102 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
