Question about HP Compaq Presario SR2180NX (RK548AA#ABA) PC Desktop
Okay! Now I have a problem. On the SR2180NX (along with other SR21**NX Cases), there is a section below the hardware drive cage where there seems to be three slide hooks that may be used to attach another hard drive cage. I cannot figure out what the part number will be nor can I find anyone who sells hard drive cages that will fit properly in the Presario Case. I have four (4) SATA Ports, One (1) IDE Port for two (2) more IDE Drives and a Floppy Port for a Floppy Drive. There just isn't enough real estate to mount more hard drives unless I can find the cages that will fit behind the power button. I have checked HP, their list of Partners, Ebay... Does Anyone have any ideas where these hard drive cages can be found? Thanks! -Gregg
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    I'm thinking your best bet would be at a computer repair shop that has a bunch of old cases. Don't know your area but there are sops everywhere. You may also watch out for recycling programs that people drop off old hardware.
  • 272 Answers
If you can not find any, keep it on the floor of the case ;)
i had same problem, now , one of my hdd is not hooked on anything. Well, there can be found a cd-rom like HDD case, it should be found on any computer selle shops.
Posted on Oct 09, 2009
Trying to find a cheap HDMI graphics card to put in. Any suggestions? Also, is it necessary to upgrade the power source?
This particular computer has an PCI-E slot available for a graphics card upgrade (provided that it doesn't already have one in there).
You should be okay with not upgrading the power supply, unless you're looking to put a really beefy card in there.
Something simple, that'll have HDMI on it and will have no issue driving HD content would be best in the realm of a Geforce GT 720. It's $50 on NewEgg.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814487062
Hope this helps!
Aug 28, 2014 | HP Compaq Presario SR2180NX (RK548AA#ABA)...
Replacing a hard drive on Sony PCV-W501B with a
The Sony VAIO PCV-series is Sony's line of desktop computers. While they are not terribly difficult computers to disassemble, the parts can still be easily damaged in the process. Replacing hardware in a PCV typically means dismantling the computer.
Shut down the computer and disconnect all cables and devices. Position the computer with its back panel facing you. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Attach an electrostatic discharge (ESD) strap to your wrist. Connect its wire clip to your computer's outer casing. Locate the metal tab in the upper right corner of the back panel, securing the right access panel in place. Pull on the tab with one hand, and with your free hand grasp the side panel and pull it away from the computer until the inside of the computer is accessible. Place the computer tower horizontally on its left side. Locate the power supply attached to the back panel inside the computer. Disconnect the power supply cable from its connector on the motherboard. Locate the pull-tab on the right side of the power supply assembly. Lift up on the pull-tab, and then remove the power supply assembly from the computer. Locate the RAM modules near the center of the motherboard. The motherboard is where all the hardware connects with your computer. Spread the white, retaining latches on each side of either RAM module. Grasp each module and lift them out of their respective memory slots. Store the modules in a static-free plastic bag, if possible. Locate the hard drive attached to the drive cage on the computer's front panel. The drive cage holds the CD/DVD, floppy and hard drives. The hard drive is usually located beneath the CD/DVD drive inside the drive cage. Disconnect the two power and data cables from the back of the drive. Pull on the locking tab that holds the drive in place.
Grasp the drive and pull it out of the drive cage. Hope this helps.
Dec 22, 2012 | Computers & Internet
How to remove disk drive
The front of your computer is the Front Panel. The Front Panel needs to be removed, along with the Side Panel, to replace an optical disk drive. (CD/DVD drive)
Gateway Support > LX6810-01 Desktop PC > Main Support page,
http://support.gateway.com/us/en/product/default.aspx?tab=1&modelId=2308
In the list click on -> User Guides
In this list click on the blue -> Gateway Hardware Reference Guide
This is a Zip file. If you do not know how to 'unzip' a Zip file, please state in a Comment, and I will guide you.
Page 45: Opening the case
FIRST <-
A) Unplug the computer from power.
B) FOLLOW Anti-Static Precautions
Anti-Static Precautions:
Your body carries Static electricity.
Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static BEFORE reaching inside your computer.
Computer on a table, computer unplugged from power, computer case open.
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
IF you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
Looking at the Front of the computer the LEFT Side Panel removes.
There are two Philips head screws along the edge of the Side Panel, on the back. One towards the Top, one towards the Bottom.
These are removed.
The Side Panel is then slid back with the 'finger bump' on the panel, until it stops. Then the top is brought out, and the Side Panel removed.
Removing the Front Panel: Page 47
Look towards the inside, and towards the Front.
See the 3 black plastic tabs, sticking in slots of the metal framework?
One towards the Top, one in the Middle, and one towards the Bottom.
These tabs are gently squeezed in towards the inside. Towards the motherboard.
These tabs are formed out of the plastic of the Front Panel. They have a hook on the end. The hooked end catches on the side of the slot, in the metal framework of the computer case.
Once the hooked end is moved to the center of the slot, the tab is free.
Ease the Top tab in, then follow with the Middle tab. The Front panel should start to come off.
Now move the Bottom tab in.
The Front Panel will now swing towards the Right.
USE CARE as it is NOT stated, or shown, if the main wires are going to the Front Panel, OR the Front Panel is merely a cover.
You DO NOT want to pull the wires off of the Front Panel header, on the motherboard.
If the Front Panel has wires attached, and is not just a cover, use care, and set it to the side.
[The Front Panel header, is the area of contact pins on the motherboard, that the main wires from the Front Panel connect to ]
You will see two Philips head mounting screws, along the rail in the optical drive bay cage, that hold the optical drive in, that you wish to remove.
Remove these screws, keep track of them. (They like to roll off of the table, lol!)
Slide the drive forward a little, then holding onto the drive, remove the power cable, and data cable. If it is the main optical drive, (And you have two drives), you may also have to remove a small audio cable.
Now slide the drive out of the front.
Harddrive removal: Page 52
Remove the power cable, and the data cable.
[For a 4-pin standard Peripheral power cable, you just ease the connector out,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
BY THE CONNECTOR, and NOT the wires.
For a SATA power cable there may be a small lock tab on top, that you depress down with a thumbnail,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata ]
The Harddrive has a metal 'box' cage around it. The harddrive cage.
On the back of the cage, (Towards back of computer), there is a thumbscrew located at the top of the cage.
This thumbscrew is removed, and the Harddrive cage is slid out, towards the back of the computer.
Remove the screws that hold the Harddrive in the harddrive cage.
Then remove the Harddrive.
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 14, 2012 | Gateway LX6810-01 PC Desktop
Nissan nx serpintine belt
Below is the master help link provided to go through belt routing diagram:---Timing belt, drive belt, serpentine belt, accessory belt, fan belt, engine belt routing diagrams for all types of car models?
Click the link below: ----
http://carbeltrouting.blogspot.in/2012/02/timing-beltdrive-beltserpentine.html
----------This will help. Thanks
Mar 05, 2012 | 1993 Nissan NX
Remove hard drive
Step 1: Use the following steps to open the case:
  1. Unplug all cables except for the power. Write down each cable location if you do not already know where it connects.
  2. Unplug the power cable and with the power cable removed press the Power button on the front of the PC.
  5. On some cases, it may be necessary to remove the front of the PC so that you can remove the drive cage. If so, press in on the tabs that retain the front cover, there should three to four on each side of the cover and gently pull forward. It helps to have a friend help with this process. Carefully detach any cables that may also be attached to the front cover.c00376513.gif
Step 2: Disconnecting the cables
    If you are replacing a drive, use this section to find and unplug the IDE/Serial ATA or power cables.If you are adding an additional drive and the empty bay is part of a removable drive cage, use this section to find and unplug the cable to make the drive cage removal easier.If you are adding an additional drive into an empty drive bay on the chassis, skip this section and go to Step 5 .
  1. Find the hard drive. The hard drive usually sits under the CD and DVD drives and has a thin flat ribbon cable.
  2. Disconnect the IDE or Serial ATA cable and the power cable from the back of the drive. remember where each cable goes. IDE Serial ATA c00378000.jpg c00378001.jpg
c00564485.jpg Step 3: Removing the drive cage On many HP and Compaq PCs, drives are attached to drive cages. Often, the installation and removal instruction for the cages are located next to the drive cage or on the side panel. The following images are some examples of the types of drive cages that come on HP and Compaq PCs. For more detailed information information about a particular chassis, refer to the Hardware and Servicing guide or User Guide for your particular model of PC. Drive cage examples c00378002.gif c00378003.gif c00378004.gif c00378005.gif Step 4: Removing the drive
    If the drive is attached to the chassis or drive cage with screws, remove the screws and slide the drive out.If the drive is retained by a plastic latching system, lift the latch to slide the drive out.Set the old drive aside. If the drive is to be re-used, place it in an ESD safe container for storage.
Jun 30, 2010 | HP Pavilion 753n (P9852AR#ABA) PC Desktop
After iformat my compaq nx 7400 i can't install xp it showes my that my hard drive contian viurs
Try a Low level format. click the link below for a software to assist you:
http://www.softpedia.com/get/System/Hard-Disk-Utils/HDD-Low-Level-Format-Tool.shtml
You may also try formating the drive from a floppy disk, if needed. But that may require a little experience of DOS.
The formating done at the time of installation is a High level format, which may not be effective in all cases.
Mar 22, 2010 | HP Compaq Business Notebook nx7400
Physical installation of 2nd hdd
The document below gives instruction for installing, but the place and shape of the cabinet and hdd case may be different from you PC. You can use this as a refrence. Installing a hard disk drive Use the steps in this section to install a new hard drive into an empty drive bay. Step 1
If you are installing a new hard disk drive, make sure it is set to cable select. c01179815.jpg Step 2
Slide the hard disk drive into the hard drive cage. c01196498.jpg Step 3
Align the screw holes on the hard drive with the screw holes on the hard drive cage. c01179817.jpg NOTE: Make sure the connectors are at the top of the hard drive cage. c01179818.jpg Step 4
Replace the four screws (two on each side) to secure the hard drive to the hard drive cage. c01179813.jpg Step 5
Connect the power and data cables to the drive. The connectors are keyed and can be attached in only one way. c01179809.jpg Step 6
Insert the hard drive cage into the PC.
Align the four tabs on the side of the hard drive cage with... c01179819.jpg ... the four slots inside the PC. c01179820.jpg Align the three tabs on the side of the hard drive cage with ... c01179821.jpg ... the three slots on the front of the PC. c01179822.jpg Step 7
Slide the hard drive cage down until it snaps into place. c01196499.gif NOTE: Make sure the front tabs on the hard drive cage are correctly inserted into the slots on the front of the PC. c01196500.gif Step 8
Replace the two screws that secure the hard drive cage to the PC. c01179804.jpg Step 9
If you are adding another hard drive instead of replacing a hard drive, connect the SATA data cable for the new hard drive to the next available SATA connector on the mother board.
NOTE: The SATA data connectors on *********** board may look slightly different than the example. c01833532.gif Step 10
Replace the front panel and the side panel, and then reconnect the cables.
For more information about replacing the side panel and the front cover, refer to the HP support documents Removing the Front Cover and Opening the PC Case . c01179827.jpg Step 11
If using Windows, wait until Windows finds and configures the new drive. c00615034.gif
Regards,
Shrey
Oct 07, 2009 | Computers & Internet
Dell dimension 5150 ethernet problem reloaded windows xp home from a windows xp entertainment os. apear fine but not receiving.
Okay, so it seems you installed Microsoft Windows XP Home on a what was Media Center Edition installation, and the ethernet is no longer worker.
Please refer to dell.com's support section, enter your model, and download drivers that you need.
To find drivers you need, Go to start --> control panel and then go to (under classic view) system --> the hardware section, open up device manager, and then look for ones with a yellow big question mark, and get those drivers from dell's website. Burn these drivers to a CD on another computer, or use a USB flash drive if that does work.
Good luck.
Jul 16, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
HP 8570 C Medalion hard disk removal
The side panel of the case should be removable to gain access to the screws. I have also seen versions that the card cage itself is on a hinge, and swings out of the case (with the removal of a few screws) that then gives access to the drive screws.
Mar 25, 2008 | Computers & Internet
HP Compaq Presario SR2180NX (RK548AA#ABA) PC Desktop Logo
107 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
