Question about ATSI Holdings Cognitive Del Sol Thermal Label Printer
LABEL ROLL AROUND ITSELF ON THE BOTTOM SMALL ROLLER AND SINCE THEN PRINT HAS BEEN VERY FAINT. CAN THIS BE FIXED
    Problem Solver:
  • 12 Answers
Need to remove platen roller. Recommend sending in for service.
Posted on Jan 08, 2010
I cannot retrieve FABRIC from inside machine. I was printing labels and now one is rolled around the roller inside.
About 1,350,000 results (0.86 seconds) Search Results
    [PDF]How To remove a stuck label from the LabelWriter? 1. the ...
    global.dymo.com/.../cRydqiFncuah2s6Pf5DxrozTFs...
    DYMO Corporation1. the labelwriter. 2. ... The cover is now completely removed. 7. lift up the innerguidance ... Make sure the rubber transport roller ... under the stuck labels with the cutter ... the front is completely in place. 31. Your LabelWriter is now ready to print.
    [PDF]Instructions & Troubleshooting - Pelikan Artline
    www.pelikanartline.co.nz/images/.../5InstructionsTroubleshooting.pdf
    Page 1 ... E Labels. F Platen Release Knob. G Ink Roller Loading Catch. H PrintHead. I String. Lift off the ... Determine whether the label roll is the ... on the roller inside the label ... Label Loading is now complete ... Index Bands all around.
    [PDF]Label Path Diagram - Primera
Jan 18, 2016 | Office Equipment & Supplies
Dymo LabelWriter 450 Twin Turbo - Until recently worked fine from both sides. Suddenly, no longer printing from left - prints half a label, then stops, then error message says Out of Paper, the blue light...
See if it still happens using a fresh label roll. From the Dymo 450 User Guide the common causes of poor print quality issues.
Poor print quality is most frequently caused by one of the following:
• An old roll of labels
• Labels made by a manufacturer other than DYMO
• Labels where the thermal coating has been compromised
• A dirty print head
First, make sure you are using DYMO-branded labels. Do not use third-party labels because the thermal coating on other labels has a different sensitivity than DYMO-branded labels. Also, the perforated holes between the labels made by other manufacturers are frequently not detectable by LabelWriter printers.
If the print quality becomes faint, small dots of white appear scattered through the printed characters, or light and dark patches of printing appear, you are probably using a faulty roll of labels. Try using a different roll from a fresh box. If the second roll prints correctly, the problem is with the first roll of labels.
Another possibility is that the LabelWriter print head needs cleaning. Every LabelWriter printer comes with a cleaning card. See "Caring for Your Printer" on page 17 for information about the
LabelWriter cleaning card.
Sep 13, 2013 | Dymo LabelWriter 400 Turbo Thermal Printer
When i select print I hear it running but label does not move. I changed batteries and I cleaned roller. Is the piece across from the roller suppose to move to guide the label thru?
The rubber roll is supposed to do it. Since it is clean, pull out some tape and try again. Otherwise, please contact our help desk. The numbers are at dymo.com.
Apr 09, 2011 | Dymo LetraTag QX50 Thermal Label Printer
Why does the label wrap around the bar every other label I print?
Try a different roll of labels. Clean with 100% alcahol
Apr 06, 2010 | Zebra Z4Mplus Label Printer
The print on my dymo letra tag is very faint, how to fix?
The first thing you should do is check the batteries. Because the LetraTag requires heat to generate thermal printing, not ink, the batteries need to be well charged. Also, there is a small brush fitted to the inside of the lid of the cartridge cover, that is for cleaning the print head and roller. Remove it, dampen the felt tip with a little rubbing alcohol, and gently clean the print head and roller. You should find this will improve the print quality 100%
Oct 28, 2009 | Dymo LetraTag QX50 Thermal Label Printer
Faint print after installing new roll of paper
Is it thermal paper?
Try pulling off about 12" of paper and reprinting. Sometimes the outter layers are damaged somehow.
Is the spring on the roller bar good?
Jul 21, 2009 | VeriFone Omni 3700
Out of paper error in Zebra 110XiIII plus
There is a small thumb screw under the paper guide that has an adjustable stop to hold the paper. If you load it correctly, you should have one on each side to guide the paper into the printer. Also, the machine has either a roller or a bar to hang the labels on, correct? The bar has an adjustable stop to keep the roll from moving around while you print. You may want to setup the media sensor about 1 cm from the left of the printer to make it less subject to this type of error. They come from the factory very close to the edge of the paper to allow for some card printers to work well out of the box. Most people use labels and this is not necessary. I hope I have given you some helpful information.
May 06, 2009 | Zebra 110Xi III Plus Thermal Printer
How to ink Casio FR 1211 Printing Calculator
I have a Casio FR-1211 Printing Calculator and I have the same problem. I removed the roller and tried inking the roller with "Sanford's Roll-On Stamp Pad Inker". It works beautifully ! I don't know how long it will last, but for now the print is dark and clear.
John
Apr 05, 2009 | Casio Office Equipment & Supplies
Installing a belt
1. Unplug the vacuum
2. Take the bottom cover over the brush off by removing the 3 screws
3. Switch the brush roll control lever to bare floor
4. Take the roller brush out
5. Put the belt around the small pulley from the motor
6. As you are putting the roller brush back in put the belt around the space on the roller brush - center the belt on that space - THE BELT WILL NOT BE TIGHT BUT THAT'S NORMAL
7. Reinstall the bottom cover with the 3 screws
THE BELT DOES NOT GO AROUND THE SILVER PULLEY CONNECTED TO THE BRUSH ROLL CONTROL LEVER
Dec 27, 2008 | Vacuums
67 people viewed this question
Top ATSI Holdings Office Equipment & Supplies Experts
jasbo
jasbo
Are you an ATSI Holdings Office Equipment and Supply Expert? Answer questions, earn points and help others
