Question about Roland Computers & Internet
I bought a song vault dvd burner for my 2480vs and I can't get it to work. I have the cables needed and the terminator connected but I keep getting the internal disk drive burner but not the song vault to work. What do I have to change in the 2480?
I know this sounds stupid...but th songvault is a special drive created by some dude in oregon...email him!!!
go to the website and see if there is contact...
also ... email or post on vsplanet.com...honestlly you should get help, after you paid him for the item...
i know this sounds stupid, but i am going to Los angeles right now
to a studio and trying to get out my bands demos from th 2480...the cd drive is not writing them when i went there last....so now we are going to back them up or optimize it to see what we can do....i promise to help you later...and find the email of that dude who designed the songvault, if you can tell me what materials he sent you..i e. scsi cable...scsi to sata enclosure....sata hdd is it 120 gig harddrive etc...
626-833-4403 jay call me right now if you want...
breyenhead@hotmail.com
Posted on Oct 02, 2009
LG dvd external drive not recognized by computer
ERROR 43? Check your SATA connection.
HERE'S HOW I FIXED MINE.
(IE. Computer tries to install driver for BD burner, but ultimately fails, and gives the message. "Unsuccessful" and/or "Microsoft Windows stopped device. Error 43") The SATA CONNECTION on my BD burner's EXTERNAL CASE had gone bad.
TO TEST IT. I used a SATA/IDE to USB Adapter Cable I bought for about $10 on amazon.
  • I unscrewed the external case to get at the internal drive, and plugged the SATA adapter cable directly into the internal BD burner drive (bypassing the case assembly), and plugged the other end into my computer USB port.
    • PS My BD burner POWER was working OK, so I left the big white 4pin power adapter connected to the original external case.
VOILA! Both my laptop and my desktop PC recognized the LG BD burner again and assigned it a drive letter (like it used to do).
  • Now I either need to (1) Buy a NEW EXTERNAL case ($10 - $30), (2) install it as an internal drive (could get problematic if "ANYDVD" is installed) or (3) just leave it connected via the cheap adapter cable.
It's super EASY (& inexpensive) to TEST this before spending $$$$ on a new equipment.
Hope this helps someone. It had me miffed for a while there.
Jan 02, 2014 | LG GSA-2166D DVD RW Dual Layer Burner
I have an ATAPI DVD A DH16ABSH Dvd CD rom in my Gateway computer. It keeps on disappearing and reappearing in the computer. This computer was bought back in January. What makes it do this?
Sound like the Connectivity cable is either loose or there is a problem with your dvd rom burner check the cable that it connects to if it looks fine then contact or return the dvd rom burner for a different one
Jun 27, 2011 | Computers & Internet
My HP desk top is almost a year old. The dvd/cd burner is a real pain. Regardless which program CD are burned with they are indicated as successful burns, but in playing them the songs are chopped up,...
There probably is no way to fix this. If it is the problem, getting and installing a new cd drive is very simple. You can buy a new drive here: http://www.newegg.com/Store/SubCategory.aspx?SubCategory=600&name=Blu-Ray-Burners&Order=PRICE. To remove the old one, all you need to do is open up the side, unscrew the one or two screws holding it to the case and unplug the two cables that are attached to it. The install the new one, slide it in attach the cables and put the screws back in. It is as simple as that and should work just fine after that. If you don't need the Blu Ray part of the drive you can always save some money by buying one of these instead: http://www.newegg.com/Store/SubCategory.aspx?SubCategory=5&name=CD-DVD-Burners.
May 11, 2011 | HP Computers & Internet
Burn cds
Hi first thing go to
start
control panel
printers and other hardware
system (on left side)
hardware
device manager
DVD / CD rom drives
does it show up as a burner? DVD-RW or CD-RW
if not it may have a wrong driver installed If windows does not recognize it as a burner it will never work untill you get past the driver issue.
If the correct driver is installed
should be pretty simple there are many ways to burn
right click on a file and select SEND TO and send it to your burner usually drive D add all your files then select BURN FILES
or if they are media files you can use Windows Media Player
if all else fails track down a copy of Nero burning rom software or Roxio easy media creator.
Finally having said all that are you using the correct media?
if you try to burn files using a DVD on a non DVD burner it won't work.
also older burners were finicky and you had to watch your + and -'s
meaning if a DVD-R isn't working then try a DVD+R
if its an older burner you may consider upgrading it, a DVD burner can be bought on ebay or newegg for about $50 and its only a 2 cable install so its not to hard.
Another more extreme solution is to save all your files which you should be keeping in the "my documents" folder and do a system restore. (requires the factory restore disks)
This is very time intensive and can be VERY tricky but if the computer has been running for 3 plus years and is running slow it could probably use a fresh start and anything that has been corrupted over the years gets wiped away.
Hope that helps
Dec 29, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
How to connect the dam thing to a computer and what driver do i need for the canon dw-100 burner to work on the f computer
You must have got a cable to connect it and use any Writing software like nero to burn discs
Oct 24, 2009 | Canon DW 100 DVD-RW Burner
The Writer works slowly
i think your writer or burner is not in dma enabled mode.
you can search on net how tomake drives dma enabled. you can easily fint it .
if it doesn't work then you need to delete some keys in registry. you can follow the procedure foe deleting keys at url http://sniptools.com/vault/getting-back-to-dma-mode-in-windows-xp
then your dvd will work faster
Aug 29, 2009 | LG GMA-4020B Super-Multi...
How do I connect Burner to IDE cable?
Yeah its a SATA and you need a SaTa controller to put into your computer you cannot connect this via ide
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 23, 2009 | ASUS DRW-2014L1T DVD-RAM Burner
I bought iTunes card, bought the songs i wanted, but it wont work
Your CD Drive may be just a CD/DVD reader Drive may not be able to burn onto CD/DVD,s my dads laptop cant, he gets same error when he trys, so he had to use a different cd/dvd burner on a desktop.
If you have a desktop or laptop and you are 100% sure it can burn to CD/DVD,s then i reccomend you get a program called "ULTRA ISO" it is shareware but allows burning up to 300mb per cd for free before it asks you to pay so as long as you keep cd files below a total of 300mb you,d never have to pay. if its actually ITUNES which is reporting the error then your CD/DVD drive may require its own software before itunes will reconise it as CD/DVD burner drive. windows media player can report this type of error also.
Feb 07, 2009 | Classic Electronics MP6410 MP3 Player
HP DVD 740e wont burn Dual Layers anymore!
Try re-installing the software associated with the burner, so it installs the necessary drivers and files needed for the burner to work according to your needs.
Also check the connections and cables... sometimes moving it around causes the cables to loose some contacts.
Hope this helps...
Feb 26, 2008 | HP DVD 740VI 16X16 Dual Layer LightScribe...
Incompatible disk message
You need to read page 8 of the JVC CU-VD20 DVD Burner instruction manual:
Recommended DVD-R Vendor - JVC, TDK, Verbatim, SONY
Writing Speed for DVD-R is 8X maximum, this is the real issue as I first bought 16X TDKs and they did not work, so now I need to buy 8X.
That's a bummer as most stores only supply 16X now.
Nov 30, 2007 | JVC Everio Share Station DVD Burner Burner
Computers & Internet Logo
160 people viewed this question
Top Roland Computers & Internet Experts
Darren  Means
Darren Means
Stu Morris K
Gil Shultz
Are you a Roland Computer and Internet Expert? Answer questions, earn points and help others
