Question about SanDisk Sansa e260 MP3 Player
Screen says "Disconnected" and won't turn off. or load
Can't load Snasa onto desktop of PC or turn off. Holding menu for 15 seconds doesn't reboot either!!
    President:
  • 803 Answers
Try these 3 resetting steps:
1. Push the "Power" switch downward into the "Hold" position.
2. Press and hold the "Menu" and "Record" buttons at the same time until the device resets.
3. Push the "Power" switch upward all the way to turn it back on.
OR
1. Grab a steady hold around the device.
2. Push the "Power" upward and hold it there until it powers off.
3. Power the device back on by releasing the power switch and then pushing it upward again.
OR
1. Unscrew the screws on the back of the device (or simply push the lid off if it is a model without screws.)
2. Take out the batteries from the slot and wait until the screen goes black.
3. Insert the batteries the same way they were mounted and attached the lid again.
4. Push the power switch upward to turn on the device.
Posted on Oct 01, 2009
Testimonial: "Bravo! A winner everytime. Thank you!"
My dell inspiron 2400 won`t come on .it does not show anything on screen.
You first need to check the screen is working, disconnect the VGA/DVI cable from the monitor, then turn it on do you get anything on screen at all?
If that works reconnect the cable and turn it on, now boot the PC, do you see anything at all on the monitor?
No then check the cable/swop with new one or check the graphics card.
Yes but goes off after a few seconds, reboot and press the F8 key as soon as you hear the first beep, this should bring up a start menu, try safe mode, if that works load and windows it might be the graphics driver (has this been updated?) if yes try roll back to previous driver or you could even try system restore back to a date you know it all worked.
May 19, 2014 | Dell Inspiron 530s Desktop Computer
Acer desktop with black screen and line blinking
I'm thinking from what you describe that you are just looking at the cursor blinking in the upper left corner of the screen.
You haven't said what you did or what you are trying to do, but I suggest you turn the computer off (just push the power button in for about 7 seconds) and then restart it after about 15 seconds. If it doesn't start, go through the process again but this time, after you turn it on, tap on the F8 key. Like tap---tap---tap and keep doing that until you get a black screen with a white menu on it. Use your arrow keys to select "repair your computer" that you will see if you are using windows 7.
This should repair you startup problem.
Mar 22, 2012 | Acer Aspire Z5600 (AZ5600U2092) 23 in PC...
My Magellan Maestro 5310 is stuck on the Magellan start up screen. the little power bar on the the bottom of screen comes up then thats it. It won;t begin to load the next screen. I have tried to reset...
Hello There, I have a Magellan myself, besides me knowing some things or two about GPS'S
Give this a try, seems to work for me and others most the time.
Try this for me to see if this works: Let me know. It needs to be rebooted. Turn off, by holding off button down. Then once it is completely off, then turn it on, BUT when you go to turn it on, keep on button depressed, all the way until it turns on and then some for about 15 seconds, now you just rebooted system. Let me know, if does work, please click on the thumbs up to showed your a happy customer. Thanks Mike
Jun 22, 2011 | Magellan Maestro 5310 Car GPS Receiver
How do i reboot my acer aspire? it has windows 7 and need help bad!!
To reboot just click on start which is little circle in bottom left and to the right of screen that pops up there will be shut down button that looks like little lock in red color. next to it is little arrow which if pressed it will give you option to reboot. Also you can power it down by choosing little red lock under start menu or by holding power button for about 15 seconds. Hope this helps.
Nov 04, 2010 | Computers & Internet
Dead? wont turn on
I had this happen to me on one occasion. Pressing the power button any number of times would not turn on the unit. Also, plugging in the car charger did not turn on the unit or charge it either.
I found that holding the power button for 10-15 seconds forced the unit to reboot, and it started just fine after that.
Since then, I've had an even more irritating issue, where holding the power button for 10-15 seconds would restart the unit, but it would freeze at the "loading maps." part. I ended up plugging the unit into my PC, which started it for purposes of data transfer. I then disconnected it from the PC and it restarted properly.
Try those out and see if you have any better luck.
Apr 16, 2010 | Garmin nuvi 260W GPS Receiver
No turn on gps garmin
I had this happen to me on one occasion with a nuvi 1300. Pressing the power button any number of times would not turn on the unit. Also, plugging in the car charger did not turn on the unit or charge it either.
Apr 14, 2010 | Garmin nuvi 765T GPS Receiver
Nuvi 750 will not turn on
Apr 14, 2010 | Garmin nuvi 750 GPS Receiver
Garmin 1300 worked an hour before yesterday then I turned it off and it won't turn back on, I didn't do anything to it, it just sat on my desk. It's not the battery, I tried plugging it several times and...
Apr 09, 2010 | Garmin nuvi 1300 Car GPS Receiver
My garmin is totally blank
I assume you mean the screen stays black and won't turn on.
Mar 14, 2010 | Garmin nuvi 1300 Car GPS Receiver
HP desktop computer will not load...
what os you are loading?
did you purchased it with bundled os/softwares?
Apr 01, 2008 | Computers & Internet
SanDisk Sansa e260 MP3 Player Logo
114 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
