Question about Canon i850 InkJet Photo Printer
How to deep clean the canon i850 printer? I took the black ink cartridge out to replace. Bought a new one but did not put the cartridge in for 3 months. Stapl;es said I need to do a deep clean now. And next time do not leave the printer without a cartridge in it ever or it will dry up.
    Sergeant:
    Novelist:
  • 192 Answers
It's simple. Just use rubbing alcohol on a qtip. If you really want to do a deep clean, you can get a cleaner/degreaser. Look at Active Components website. It's safe on all rubber and electronic components.
Posted on Sep 30, 2009
My Printer prints a Colored Ink. But I type as a black Font Color.Then Black Ink Has full?? pls help me
Hi Carl Montero,
Your issue may be attributed to two possible points of failure. 1.) The Nozzle is clogged, 2.) the ink is already dry inside. You can try to clean the nozzle by doing the following steps. If it does not work, try to replace the cartridge with a new one.
FINE Cartridge Cleaning
1 Press [Menu] repeatedly until appears. 2 Use [ ] or [ ] to select . 3 Press [OK]. 1 Press [Maintenance] repeatedly until appears. 2 Press [Black] or [Color].
FINE Cartridge Deep Cleaning
Note If deep FINE Cartridge cleaning does not improve the print quality, contact a Canon service representative.
Jul 13, 2011 | Canon PIXMA MP150 All-In-One InkJet...
My Canon i850 printer has stopped responding to a
The Canon i850 uses cartridges of type BCI-3. according to Canon, the color cartridges are compatible to:
BJC-3000 Series, BJC 6000, i450, i550, i850 Series, MultiPASS F30, F50, F60, F80, MP 700 and MP 730, S400, S450, S500, S520, S530D, S600, S630, S630 Network and S750.
The black one will work in a few more models.
Feb 07, 2010 | Canon i850 InkJet Photo Printer
The black color doesn't print.
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Feb 05, 2010 | Canon i850 InkJet Photo Printer
My i850 printer has not been used for several years. I just tried to use it on a MacPro running OSX 10.5. It will not print black text but does print black test patterns (though often with vertical lines)....
The issue is your heads are dried up. Did you store the printer with ink cartridges installed? What tends to happen from prolonged periods of no use is the ink dries and hardens just under where the cartridge is seated.
You can try taking a Q-Tip with some rubbing Alcohol and clean the heads. You need to be very careful not to push down to hard or let the cotton get pulled into the head area.
Another option is to get a new printer - I've seen them as low as 35 bucks at Target
Feb 01, 2010 | Canon i850 InkJet Photo Printer
Canon i850 printing but pages are blank
I had the same problem after changing the black ink cartridge. I went to Control Panel of my computer, chose Printers, then Canon Inkjet. Chose Properties, then Maintenance, the Deep Cleaning. NOW my printer is working!!
Jun 16, 2009 | Canon i850 InkJet Photo Printer
My printer only prints pictures, no text.
Sounds like your black pigment (PGBK-5) cartridge has clogged up the printhead or similar.
You could try running a single Deep clean on the that colour alone (use Right click printer > printing preferences > maintenance tab > Deep Cleaning)
If that doesn't work you will probably need to either:
- clean the printhead (see this thread)
or
- replace the printhead/cartridge
Hope that helps.
Mar 09, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Black doesn't print
THE CARTRIDGE MAYBE NO GOOD OUT OF THE BOX.
PRINTER NEED TO BE CLEANED
I DONT THINK ITS A DRIVER PROBLEM
BUT YOU WANT SOME OTHER OPTIONS TYPE IN THE ADDRESS BAR:
CANON 850i INKJET PHOTO PRINT WILL NOT PRINT BLACK INK
ROD
Jan 11, 2009 | Canon i850 InkJet Photo Printer
Printer will not print black ink
Hi please try these steps:::
Right-click the printer icon, and then select 'Properties'.
2. Click the 'Maintenance' tab, and then click 'Deep Cleaning'.
3. Select 'All Colors', 'Black' or 'Color' for the print head to be cleaned.
4. Read the message displayed, and then click 'OK'. The power lamp blinks and print head deep cleaning starts. (Do not perform any other operations until print head deep cleaning is complete. Print head deep cleaning takes about 1 minute.)
IF ABOVE STEPS DOESN'T WORK TRY THESE STEPS BELOW
Check ink tank vent hole The ink tank requires air to flow through it so ink can move from the reservoir to the print heads.
  1. Confirm there is no orange tape across the top of the ink tank
  2. If the orange tape is as shown in Figure (1), it is properly removed.
    *BCI-3's shown in this example.
  3. If the orange tape is as shown in Figure (2), remove the remaining tape to the level shown in Figure (1).
  4. Make sure each ink tank is snapped into the printer.
    IF THESE STEPS DIDNOT WORK THEN YOUR PRINTER NEEDS REPAIR(You might need to change the printer head.)
Jun 09, 2008 | Canon i850 InkJet Photo Printer
Canon MP500 PGPK cartridge wont print
i have the same problem too. This is obviously a product defect. If Canon not fix it, i wont buy Canon printer anymore.
May 21, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon i850 InkJet Photo Printer Logo
204 people viewed this question
old marine
old marine
