Question about Dell A525 Computer Speakers
I have dell speakers that i want to use wid an e machine
Will they work if so how do i set them up
  • 496 Answers
They should work as long as its not some custom plug as long as its a headphone plug then ust plug them into the little green port on the back of the pc and use them
Posted on Sep 30, 2009
How do I find driver for my speakers. Disc not available. They stopped working after MS update.
My daughter had the same trouble with her Dell computer. The guy who was reloading Windows found the additional drivers on the Dell website.
The Dell recovery disc supplied with a new machine already contain those drivers.
Feb 22, 2016 | Dell Audio Players & Recorders
Install dell wireless 5530
machine out of time. theres a mark on needle bar that aglins with the needle bar guide. when u have the needle in this position u have to loosen the hook ( 3 screws) and place the point of the hook just meeting the needle. before u try this try lowering the needle slightly.
Mar 17, 2014 | Juki Sewing Machines
There is no sound in my dell e198fp
Either is problem with speakers or with your software. So just right click on speaker icon in notification area and open playback devices and see if you can see your speaker. and then right click and then select test. If you cant see your speaker in the list, you probably have driver problems and u need to install all necessary audio drivers, if you can see it bt cant listen anything, there is a prob wid ur speakers.
Apr 14, 2013 | Dell E198FP 19" LCD Monitor
How do I splice my new SPE-6090 Alpine Speakers to my 200 honda civic stock wiring.
if the pioneers already had the wires in that where solid white&white wid a black stripe you can solid white as positive & white wid black stipe as negative same with other speaker except wires should be solid grey & grey with black stripe wich would be your negative if not the best way to go is wire the darkest factoy wire as negative & the lightest color as positive hope this was helpful
Mar 05, 2013 | Alpine SPE-6090 - 6"x9" 2-Way Car Speakers
When i write a message and then i try to send it,
check wid ur msg setings..jus contact ur customer care sentre abt it..try doin wid less words and actual meaning.mayb dn smthin wid d msg settings. go to menu..messages..settings and change.
complete d msg wd proper info..
Feb 10, 2010 | LG GW520 Cell Phone
Hello there, I have a Dell computer and trying to use HP speakers with it. Will this not work? I am not hearing a sound and my computer shows no device for speakers.
The HP speakers should work fine with your Dell.
Make sure that you have the speakers plugged into the correct port on the back of the Dell (This is typically a green colored port) Once the speakers ar plugged in to the correct port make sure that your sound is not muted.
Click on Start then on Settings or Control Panel.
Once you get to the Control Panel double click on the Sound Icon.
Verufy that the sound is not muted and you can also check the box to display your voulume settings on the task bar.
You may also want to check that your sound card in correctly installed.
Check these items and let me know if there was any change because there can be other items to check - These are just a few good jumping off points
Dec 28, 2008 | E-Machines eMachines Desktop PC
Unable to share printer
You need to go into the machine that manages the printer and allow the access denied machine access or to share printer. You may have to run the network setup wizard in order for the machines to recognize each other.
Jun 23, 2008 | Dell Inspiron 1501 Notebook
Dell Speakers A215
Try going to support.dell.com and entering your Service Tag. Then click on drivers and downloads and download and install the audio driver that they currently recommend for your machine. Sounds like a driver problem and something that wasn't set properly after the computer was reset.
Dec 18, 2007 | Dell A215 Computer Speakers
Both right speakers not working
Try to interchange the connections of left channel and the right channel. If there is sound now in the right channel and no sound in the left channel it means that you have problem in the sound card. Otherwise if the problem remains the same you have a defective speaker on your right speaker system but don't forget to take a second look on your speaker wiring.
Oct 22, 2006 | Dell 5650 Computer Speakers
Dell A525 Computer Speakers Logo
82 people viewed this question
Top Dell Audio Players & Recorders Experts
dochubert
dochubert
Level 1 Expert
Rick Davis
Rick Davis
Greg Cann
Greg Cann
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
