Question about Olympus FE-100 Digital Camera
Olympus FE-100 will not turn on at all
My Olympus fe-100 will not turn on at all, i have tryed with fresh batteries, plug it to the USB port with it's cable and nothing at all
thanks.
I put the memory card in and on some of my photos it shows the pictures and others it says picture error. Also, when I go to view all pictures, it doesn't show them, they're just blank black boxes.
Posted on Dec 28, 2010
Is it possible to charge my olympus fe-46 from my computer?
In a convoluted way. The FE-46 uses standard AA batteries. You may use either disposable alkaline or lithium batteries, or rechargeables. If you use rechargeables then you must charge them outside the camera. There are chargers that run from a computer USB port, and there are even AA batteries that plug into a USB port. However, you canNOT charge the batteries by connecting your camera to your computer.
Jul 29, 2011 | Olympus FE-46 Digital Camera
I lost the battery charger of my olympus fe-320. Can i charge it using the usb port ?
No, you cannot charge the battery in the camera via the USB port. You need to use the LI-40C or LI-41C charger or equivalent.
One source for a replacement charger (along with a battery and a camera case) is
http://www.overstock.com/Electronics/rooCASE-Olympus-Black-Nylon-Case-and-LI40B-42B-Battery-Kit/5285636/product.html
Jun 23, 2011 | Olympus FE-320 Digital Camera
I have an Olympus FE-330 camera. When I try to transfer using the Olympus Master 2 (recently installed) it says 'software unable to locate an Olympus Digital Camera connected to a USB port' I...
Check the LCD screen of the camera. You should get a message when you first plug it in to select the usb type. highlight PC and press ok. The screen should display one moment please then go off. Then the camera should be recognized by the computer.
Jun 15, 2011 | Olympus FE-330 Digital Camera
Olympus fe 4000 - when plugged into the computer doesnt work
Is the computer or the camera telling you the battery is bad? If it's the computer, you might have some bad pins on the camera, or your usb cable may have a problem with it. If the camera is reporting this on it's screen, not sure what the problem is there. I would instead, just transfer the pictures to the computer via a card reader through the USB port. Check your printer- many printers these days have memory card slots on them, and you can transfer pics to the computer through them.
Apr 12, 2010 | Olympus FE-230 Digital Camera
Olympus FE-20 isn't noticed by computers
Make sure the camera is on and the batteries are fresh before you connect to your computer.
Not all usb plugs are the same. You may need a specific one for your camera.
Also you may try taking the sd card to a photo shop like Walmart. They may print the picture for you.
Dec 20, 2009 | Olympus FE-20 Digital Camera
My olymous f2-20 has fresh battery and won't turn
The reset is in the setup menu but since you can't turn it on, that's useless. Are you sure the battery is inserted correctly? Try cleaning the battery contacts in the camera with a cotton swab lightly dampened with rubbing alcohol.
Aug 15, 2009 | Olympus FE-20 Digital Camera
My laptop pc cannot find my olympus fe 5010.
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Aug 11, 2009 | Olympus FE-210 Digital Camera
Computer won't recognize Olympus FE-340 when USB is plugged in
some computers just seem to do that, it happened on me before. if you have a card reader just put the card into that and read the pictures from that.or just try a differant port if you havent allready
Mar 24, 2009 | Olympus FE-340 Digital Camera
Need a driver for FE-190
need a driver or cd to download my pic on my computer olympus FE 190
Mar 30, 2008 | Olympus FE-190 Digital Camera
FE 280 Olympus
I've seen this on some users, did you try a different USB port?
does anything happen when you plug the camera in when it's on? a beep? a window pop up?
Jan 04, 2008 | Olympus FE-280 Digital Camera
Olympus FE-100 Digital Camera Logo
441 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
