Question about Garmin Nuvi 255 GPS Receiver
Nuvi 255 battery replacement
Any guides how to open the Nuvi 255 up without damage? Seem to be no screws. Also which battery is needed?
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Please don't attempt this yourself. You risk cracking the case and damaging the LCD display. You need the right tools too. Please see this link for more information:http://www.sharc.net/gps_battery_repair.... I've received many units that were damaged from attempts to open them. - Jim
Remove the sticker on the back of the Nuvi 255 showing your serial number. Below it (I'm told) are two screws. Not sure the type. But if you feel your finger across the sticker on the back of the Nuvi 255, you can feel there are two depressions on either side that indicate to you that there are screws being covered by the sticker.
Mobile phone repair tools often come with a plastic prying tool, so if you need something to pry the plastic covers apart without damaging the edges of the casing, buying a mobile phone repair kit for a couple of bucks seems like cheap insurance. After you've unscrewed the Nuvi 255, you can use one of the plastic pry tools it contains.
It's such a sad state when companies design things without removable batteries, and they will never be rewarded by me for doing this.
Posted on Dec 05, 2009
Why has my garmin started to take long time to open
Norm, Garmin GPS takes long time to open. It could need software update, battery replacement, fault in a update/firmware, etc. I almost think the manufacturers of GPS devices make the to fail after a few years, to frustrate people to buy another. Some say to rest to factory defaults to make GPS work better/quicker. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
nvi 255 Was SLOW TO START Now VERY QUICK TO START After Replacing Battery
Garmin GPS Device Hard Reset
How To Restore Reset Garmin Nuvi gps to Factory settings
http://forums.gpsreview.net/discussion/21511/how-to-perform-a-hard-reset-master-rest-on-your-nuvi
Aug 23, 2016 | Garmin GPS
Tip
Download Nuvi 255 Manual Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W,...
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Have you lost your User's Manual or the Quickstart Guide for your Garmin Nuvi 255 or 255W GPS?
Would you like a digital copy for easy searching of terms and quick reference?
Both manuals are available in pdf format, just follow the photo links below:
I hope that helps.
on Apr 16, 2010 | Garmin NUVI 255 PERSONAL GPS Device
Tip
I hope that helps.
on Apr 16, 2010 | Garmin Nuvi 255 Car GPS Receiver
I recently ordered a replacememt battery for Nuvi 255w. I received a kit and new battery. How do I open it?
At the bottom of your device you find the label with all relevant data like type, serial number etc. This label can be easily removed by cautiously lifting one site and pulling it off. Under the label there are 2 screws which must be removed. Then you can open the case using the blade of a screw driver or a similar tool. Be cautious not to destroy the cable from the board to the screen. When the case is opened you'll find three small screws on the PCB which must also be removed. There are two connectors which can easily be removed: The cable to the speaker and more important the cable to the Li-ion battery. The battery is fixed by some clue in the case under the PCB. Replace it and reassemble the device. I hope this was helpful. Regards A. K.
Jun 17, 2010 | Garmin Nuvi 255 GPS Receiver
Juice spilled on a garmin nuvi 205
NO NO NO!!! There are hidden screws under the decal.... if you try to pry the case open without removing the screws you will crack the case. I've repaired literally hundreds of Nuvi's.
I would not recommend taking the unit apart as you risk damaging the unit. If the spill is around the LCD, the touchscreen & glass may need to be removed from the LCD and cleaned. It takes special care to separate the two without cracking them.
Also, you need to use the right cleaning agent or you will make the problem worse.
- Jim
SHARCNET-USA
Apr 27, 2010 | Garmin Nuvi 660 GPS Receiver
Tip
I hope that helps.
on Apr 16, 2010 | Garmin Nuvi 255 GPS Receiver
Can i use my nuvi 255 wt with my sanyo 2700 phone
Yes, you should be able to link your nuvi 255 as a BlueTooth hands-free speaker with your phone. Follow the instructions in the respective user guides.
Apr 14, 2010 | Garmin nuvi 255W GPS Receiver
Replace battery garmin 255
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Apr 04, 2009 | Garmin Nuvi 255 GPS Receiver
Garmin Nuvi 255 won't charge with the car charger.
You may need to replace the battery.
Feb 21, 2009 | Garmin Nuvi 255 GPS Receiver
Replacement battery for Garmin Nuvi 660
utube.png You-Tube video "S2KEu_if7wA" placeholder
I discovered a recently posted video showing how to change the Nuvi 660's battery. I purchased a battery from newpower99.com and they took care of me well. My little "surgery" went smoothly with their kit.
May 14, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 255 GPS Receiver Logo
936 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
