Question about Baby Lock BL1556
My babylock makes a clanking noise and the yellow right needle thread breaks when I try to sew. Happened suddenly while sewing thick fabric.
As I was required to pay for your advise which may not have worked anyway I opted to take my machine to be serviced. Thank you
Posted on Oct 04, 2009
Iam sewing seats. but the threed stared braking at the needle & it want saw.
Most likely, it has to do with incompatibility of the needle, thread, and fabric. The force of the needle penetrating the fabric multiple times is actually causing the thread to (wear &) fray and eventually break. There are needles with larger grooves that tend to protect the thread during stitching. Some may recommend a Top Stitch Needle (Home Machine Needles Superior Threads Why Topstitch? The Topstitch needle is the most common needle type used and recommended by professionals and educators. We recommend the Topstitch for piecing, quilting, embroidery, appliqu?, and construction. These needles are available in four sizes to accommodate all thread types, including metallic threads. The Topstitch needle has a larger eye and deeper groove. It is often referred as the MAGIC NEEDLE. It really does make a difference in your sewing experience.)
Why Use Topstitching Needle
Also, if the thread is a tight fit through the needle eye, it will also tear the thread. Make sure that the thread will slip easily through the eye. Go to a larger needle, instead of 90, try a 100.
Be sure to use a brand-new needle.
All About Needles
The Parts of Sewing Machine Needle
You may also consider changing the type of thread you are using. Go with a stronger thread, ie polyester, rather than cotton. Cotton will shred and break easier.
You will probably need to re-adjust the thread tension. If it is too tight, it will also break the thread. If you are using a heavier weight of thread, you will need to adjust both the upper and bobbin tension to accommodate the heavier thread.
Bobbin Tension How and Why Tension is Adjusted
If you sewing fabric that is sticky, ie vinyl, oilcloth, you should try to use a roller presser foot, a teflon presser foot, or a walking foot to help the fabric move with the feed dogs.
Sewing Heavy Fabric with NON Heavy Duty Sewing Machine SEWING IN GENERAL
Tips
Sewing through many thick layers of fabric Sactin
http://www.kollabora.com/q-a/sewing-denim-and-thick-fabric
14 Fantastic Sewing Tricks and Tips Making the World Cuter
How to Sew Upholstery DoItYourself com
Apr 22, 2016 | Sewing Machines
Need to now where to put tentions to sew sweat pants.
use a couple of pieces of waste material the same as the sweat pants material and sew about an inch long
adjust the needle tension and do it again
repeat the exercise until the top and bottom thread joint at the middle of the two pieces of the material
tension settings on the machine are a loose guide as the thread thickness, material thickness and needle size all have a bearing in the tensions of the thread
so practice and adjust prior to sewing is the way to go
Nov 07, 2015 | Sewing Machines
My sewing machine needle (very new one) keeps jamming every couple of turns of the needle - and the thread is very loose and loopy on the fabric. It makes a jarring noise
not quite sure how needle is jamming. I have had them break, had thread ball up underneath and caused needle to jam. Question is the needle in the right way, ie the flat side in as per manual, generally the flat side faces away from you. Sounds like your tension is not quite right if the thread is looping. Loops on bottom, bobbin tension, on top sewing machine tension
Dec 08, 2014 | Sewing Machines
Thread breakage
Before you do anything try lengthening your stitches. Then if that doesn't work.. make sure your needle if fully seated in it's holder and is the correct needle for your machine and application.
Try to remember that there is no such thing as a "universal needle" In your instruction manual, there should be a chart that suggest needle and thread combos for different types of fabric.
Then make a note in the manual when you find the right combo for your application.
Aug 05, 2012 | Sewing Machines
My thread keeps breaking when I sew over a seam, I have replaced the needle, tried a different cotton, & replaced the bobbin case & it still keeps breaking any suggestions?
Hi
You seem to have done everything as correctly as expected.
There are some minor things that could be disturbing yet.
Make sure that needle is exacly correct in her place and that the thread isthread from the correct side. One thing I knowworks wellwhen sewing thick parts is to hold the fabric in such a way that it is a bit streched under the needle and to let the machine go slowly over the thick bits.
Hope this will be of some help
Kolbrun
Mar 08, 2012 | Janome Memory Craft 9000 Computerized...
My Fashion Mate 6160 beeped and stopped sewing & automatic threader doesnt work
if the machine still sews a straight stitch on top of fabric & also on bottom then it should be fine..
it's possible that the thick fabric, needle, & thread were not a compatable combination.
but also some sewing machine are not made to sew thick or heavy
fabric
but having the machine serviced would be a good idea & help to know why the needle thread is not working
Jan 17, 2012 | Sewing Machines
Top thread from spool somehow gets out of the needle when sewing. Sometimes top thread breaks; other times it just escapes the needle. I redid threading from top and from bobbin to see if that would fix....
Try loosening the tension and pulling a longer string of thread. Also, if the needle is not at the highest point, when you start sewing, the thread will pull out.
May 27, 2011 | Brother LX3125 Sewing Machine
Tension adjustments- bobbin metal or plastic-needle size- for sewing on jean cloth
Most machines can sew on jeans fabric, but you may need to go slowly or even hand-turn the needle when crossing thick seams to keep from bending or breaking your needle.
Bobbin: It won't matter if you use plastic or metal bobbins.
Needle: You should use a heavier needle - you can purchase 'jeans' needles, or use the heaviest sharp or universal needle you have.
Tension: For tension adjustment, you can follow the guidelines in your sewing machine manual but you'll also need to adjust the tension based on sewing on scraps of the fabric. If you are sewing light-weight denim, the settings are pretty much the default/normal settings. As you increase the weight/thickness of the fabric and seams to cross, you'll need to loosen your pressure foot tension. If you use decorative 'jeans' thread or topstitching thread, you'll need to loosen your needle tension.
*Always test on scrap fabric to make sure the stitches are forming properly. It is best to make small adjustments to your tension settings, then test, then adjust and test, until it is right. If you sew that weight of fabric often, make note of your tension settings inside your machine manual to save you some time the next time you sew.
I hope this helps.
Apr 01, 2011 | Brother XL-5130 Mechanical Sewing Machine
Skipping stitches and upper thread breaking on JCPenney 6600
Here are a few things to try.
* Raise your feed dogs if your machine has this feature.
* When you start to sew a seam, hold the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
* Your fabric may require a different needle. Generally, heavier fabrics require larger needles and thinner fabrics, smaller needles. You may also need a larger needle if you're sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for woven (or a universal needle for either). And make sure your needle is appropriate for the type of thread you're using.
* Adjust the pressure of your pressure foot, it may be too light for your fabric.
* If your upper thread and bobbin threads are different types, try using the same thread for both. And use a good quality, brand name thread.
* Change your needle plate. Try switching to a needle plate with a smaller hole (a straight stitch needle plate).
Important Note: If you change your needle plate, check to make sure your needle aligns perfectly with this smaller hole before starting to sew. A misaligned needle could hit the plate and break, which could be dangerous. And make sure to change your needle plate back for zigzag and other wide stitches.
I hope this helps.
Mar 14, 2010 | Singer 5062 Mechanical Sewing Machine
Similar issue with bunching on the bottom side of vinyl
when sewing thick fabrics and when using thick threads you will usually need to tighten top tension - on most machines to maximum in order for the machine to pull the thread up into the fabric. you must also use a needle which will slide along the thread when thread is through eye of needle (take needle out of machine, put thread through eye and see if needle will pass freely along thread - if not, use a larger needle)
scott.
Jul 11, 2009 | Bernina Activa 130
Sewing Machines Logo
133 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
