Question about Danby DWM5500 Front Load Washer
Noisey bearing when the washer is spinning it sounds like a wheel bearing is going out, and where do i find parts for this model
  • Anonymous May 01, 2008
    The bearings made noises as well. I disassembled the washer and I'm now looking for new bearings. Do you now were I can get them? Online?
    Karsten
  • 55 Answers
Sometimes an internal spring mount comes loose put it back no more noise. if still need bearing www.danby.com
Posted on Feb 11, 2009
Toyota hilux 1989 2-4pickup how to adjust front wheel bearings
Remove grease cap and split pin jack up the wheel and spin it and listen for noisey bearings if all ok tighten the large nut up and then undo it till it is just no movement in the wheel when you rock it in and out then fit castle and fit new split pin.
Dec 15, 2013 | 1989 to 1995 Toyota Pickup 4WD Front...
Washer is very noisey while on spin cycle like a bad wheel bearing on a car.. but no error codes?
Very sad to say but i imagine this will either be a trapped item such as bra wire caught in the drum or if it sounds like Gatwick airport when it spins it's probably your bearing...can be very expensive to repair. You cannot buy a seperate bearing you have to get hold of a rear tub and drum which depending on where you go could set you back £600ish pounds.
Nov 04, 2010 | Maytag Neptune MAH5500B Front Load Washer
Machine has become very noisey especially on the spinning programmes, is it time for a new one?
It could mean that either the bearings or the spider needs to be replaced. If you try to spin the wash basket by hand, does it turn smooth and quiet or do you hear a rumble sound? If it is noisy, it probally needs a bearing change. To change the bearing, the washer has to be taken completely appart to get access to the bearing. The parts cost are relatively inexpensive, but the labor costs is high due to the time to disassemble and reassemble the washer. If you are handy, and have the tools, you can buy the parts and do it yourself. You have to decide whether it is worth spending the time and money to fix or to purchase a new machine.
Jun 30, 2010 | Hotpoint First Edition WMA20 Front Load...
Washer will fill up with water but will only spin
is it noisey on spin? sounds like control board to me. try this , open door and turn steel bowl by hand, left then right. if u can turn the bowl in both directions it is not the bearings. please reply 4 more help.the bowl should turn free in both directions.
Apr 14, 2010 | LG WM-1832C Front Load Washer
Hotpoint aquarius WMF740 (1 year old) - noisey spin
its the drum bearings there worn out try opening the door and lifting the top of the drum with your fingers if there is any life and the drum drops back when you let it go its them bearings,, then spin the drum by hand is should grumble or growl,,,if it dont do any of this, it could be the "spider" broken off, its an ally part that holds the drum bearings and the drum up,
Mar 07, 2010 | Washing Machines
When my washer is on the last spin it is very loud, almost like it needs a muffler
You didn't say what model washer you have, but it sounds like you have a bad spin bearing. When bearing is bad it can be very noisey during spin, like a helicopter taking off. This means your washer needs a bearing and seals overhaul. This is generally a very expensive repair unless your washer is under some kind of warranty. The spin water seal has more than likely been slowly leaking, causing bearing to go bad.
Jan 31, 2010 | Washing Machines
Wheel bearings making funny noise
prop the wheel off the ground that has the noisey bearing involved. Turn the wheel by hand spinning it as fast as you can. You will hear different noises as it spins if bad. it could sound very smooth and when it hits a certain location the noise will come and go. If the sound is like scrapping metal instead check the inner brake caliper sheild. That could be bent instead causing this sound
Jan 24, 2010 | 2000 Saturn SL
Loud crunching noise when spinning really noisey
The bearings of the basket, are damage, maybe due to water leaking and getting rusted, or maybe the shocks are also wearing off. expensive fix on the drum basket.
Jan 17, 2010 | Hotpoint WMA58 Front Load Washer
Washing machine noisey on final spin
this isn't a problem usually every washing machine is very noisy on a final dry its normal
Oct 15, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Danby DWM5500 Front Load Washer Logo
157 people viewed this question
Top Danby Washing Machines Experts
shaun taylor
Samyfam
Samyfam
Mike
Are you a Danby Washing Machine Expert? Answer questions, earn points and help others
