Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Problem with scaning and copying
I print from PC OK, but when i make a copy or scan i have black big line
  • 813 Answers
Try cleaning the bulb and the glass on your scanner and after that reinstall the scanning software and then check.
Posted on Sep 30, 2009
Hp m1536 scanning black
Replace CCD scanner head unit with flat cable...I think UR from india, you can get it in indian market..
Example image of scan head:
Aug 10, 2015 | HP LaserJet Pro M1536dnf Multifunction...
I have a new bizhub C224 when I print color is OK but when I copy color there is magenta lines or cyan lines and only in copy and the demo page is ok too
Problem with the scanner (Thing that move as it scans has the bright light and mirrors on it. Or the CCD that is the black device under the big glass on the right, get a tech out to clean and or replace
Dec 26, 2013 | Konica Minolta Bizhub C224 Color Copier...
HP PSC scans with black line
If printing is ok there're two things that could cause that defect when scanning/ copying:
-. If printer model has both ADF and cam glass and problem only occurs when using the ADF then you should check the ADF glass for something obstructing light path (tipex or other type of dirt)
-. If the printer only has cam for scanning then the problem is on the sensor itself (the "bar" that moves when you scan something inside the scanner). It's not usual that dirt enters the sensor as It's pretty hermetic so I would think that the sensor is damaged and will need to be replaced.
Hope this helps.
Jul 08, 2012 | Office Equipment & Supplies
When i print out a paper, there is a black line through the print out.
I am assuming your black line is printed (not smudged ink)...
If your printer is also scanner/copier, try copying a page (rather than printing from computer).
If it scans & prints ok, it could be communication/driver problem. Try reloading the drivers and see if it improves. If the black line is there when copying as well, there's probably not much you can do about it.
hope this helps
LC
www.inkbank.com.au
Nov 10, 2010 | Brother Office Equipment & Supplies
Broad dark line on right edge of copied papers
If you have the black line on copies and scans but printing from P.C is fine, then your scanner is broken.
Contact your printer manufacturer for a replacement or repair.
May 12, 2010 | Office Equipment & Supplies
Black line is present when copying document; not
This sounds as if you have some ink/contamination on the small scaning glass that sits to either the left or right of the main glass on the copier.(Depending on the model/make)As your original is scanned over this thin piece of glass the scanning device will see any spots and this will result in a black line down the page.Please clean the glass with a soft rag.
Oct 12, 2009 | Office Equipment & Supplies
Scanning/copying problem (Lexmark 6500 series x6575)
please just you scan the object to resuleasion in and dp is 600 to 12oo select and you scane object and aply print is dark is ok.
Sep 17, 2009 | Lexmark X5150 All-In-One InkJet Printer
HP OfficeJet J5780 Vertical Black Line Prints when copying or scaning only. Cleaned rollers and changed black ink cartrigde. Still problem.
Have you tried cleaning the document feeders Scan Glass? (small glass under doc feeder ~ 1" by 9") Most times there is dirt spot on this glass, causing a shadow on scans and copies.
Try copying from the large glass by lifting doc feeder / platen cover and manually placing original. If no line copying or scanning manually from large glass, then small scan glass is deffenitely the culprit. Hope this helps.
Sep 07, 2009 | HP Officejet 5780 Printer
Black line down the paper on copy mode. Ok in print mode.
There is most likely something on your scan glass that is blocking the scanner. Clean of both pieces of glass that are there when you flip open the ADF, or top cover. Try to copy again. If it is still there then there is either something on the scanner piece that moves back and forth to scan or one of your scan LEDs is burnt out and the scanner will have to be replaced.
Dec 17, 2008 | Brother MFC 7420 All-In-One Laser Printer
Copy mode
Is this happening when you print or when you scan? If when scaning you could have something on the scanner bed... If this is happening when you print, it could be the cartride is defective.
Jul 06, 2007 | HP Photosmart 2575 All-In-One InkJet...
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
47 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
