Question about Maytag MGR5729 Kitchen Range
Oven won't heat up but get heavy gas smell - Maytag MGR5729 Kitchen Range
It sonds like your otomatick liting unit has cwit you ned to get a now won and have it in stald or you hane a plogd berner tri the lithing sistom and lison for cliking if you dont herit loke and see if you can see the eniter ner the berner and then tri the liter if you dont see a spark you ned to replace it if you see a spark tri bloing out the berner with a air compreser and reatech it and then tri to lit it if that didint werc get a now berner
Posted on Sep 30, 2009
4 Suggested Answers
  • 833 Answers
SOURCE: Magic Chef Gas Oven - Heats up slowly and has intermittent gas smell
STOP USING THE OVEN IMMEDIATELY!!! You are not getting enough air to the burners to burn all the fuel. Not only will you have an explosion hazard, you'll have a carbon monoxide hazard either of which will KILL YOU. Read all of the info below before you begin.
You need to clean all the burners and inlets thoroughly. You probably used the oven for a lot of broiling of meats or it is quite old. The deposits are clogging the tubes which gauge the amount of air entering the burners or the burner holes themselves. The burner tubes are generally removable by removing one screw and giggling the units clear. Before taking anything apart, note carefully the positions of any mix plates and scribe small marks between the two surfaces. Use a heavy duty cleaner or WD-40 to loosen grime. Don't use abrasives like Comet. Then wash in mild detergent with hot water and dry. Be sure all burner openings are clear. After assembly, note the color of the flames. They should be about 90% blue along their length from the burner head. If they are not, you didn't finish the job cleanly or you have another problem. If the burners are old, rusty or have irregularly shaped flame holes, replace them.
Posted on Dec 03, 2007
SOURCE: Maytag Gas range
Had the same problem.... just replaced the ignitor in the bottom of the oven... worked like a charm. 10 minute fix
Posted on Oct 22, 2008
  • 8 Answers
SOURCE: Gas smell, oven not heating up
You gas oven uses a glowbar to both regulate and ignite the gas entering the oven. If this glowbar is faulty, it might let some gas into the oven but it is not hot enough to ignite the gas. That is why you are smelling gas. I would suggest to start by replacing the glowbar (and if this is not the solution, simply return the part for a refund). The part you are looking for can be found online here: http://www.partselect.com/PartDetail.aspx?Inventory=470129&SourceCode=1
It is quite easy to replace. Simply remove the free-standing pan on the bottom of the oven, unscrew the existing glowbar, remove the back cover from the stove and trace the two wires that belong to the glowbar and unplug them. Thread the two wires from the new glowbar through the opening and reconnect to the plugs at the back of the stove. Screw in the new glowbar and test. Most oven ignition problems are caused by faulty glowbard. Good luck.
Posted on Jul 30, 2009
Whirlpool super capacity 465
Call a gas engineer at once. Gas is extremely dangerous.
Jul 19, 2013 | Ovens
Gas range oven won't heat
remove ceramics from stovetop and take a clean soft brush (like an old toothbrush) and clean igniters . Replace ceramics carefully making sure everything is in it's right place and try igniting then.
Jan 24, 2013 | General Electric Kitchen Ranges
Have a maytag Stove Model# mgr5729adw oven stopped working and just before it did smelled gas. ignitor looks to be good no cracks.
Our Maytag MGR5729ADW recently started having a problem. Whenever the oven was turned on gas would flow but did not ignite. My wife thought she was baking, but I walked in the kitchen and smell a heavy gas smell. Bad igniter or not the gas control valve should never open unless there is ignition. Had we turned on the oven and left the house, there would have been a major problem.
After a little more checking I will probably replace the igniter and the gas control valve. The parts are not cheap but neither is a house.
Dec 30, 2012 | Kitchen Ranges
We smell heavy odor of gas as the oven comes to temperature. Why?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Aug 14, 2010 | Amana Kitchen Ranges
Our oven doesn't heat and smells like gas
This sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Feb 02, 2010 | Maytag Ovens
Oven works sporadically
IF YOU CAN SMELL GAS, TURN THE STOVE TAP OFF. Get it checked out immediatly.
Aug 03, 2009 | Whirlpool GS460 Gas Kitchen Range
Jun 27, 2009 | Tappan TGF657 Gas Kitchen Range
Get too much of a gas smell when Magic Chef oven prheats up.
gas does NOT take that long to heat up!!
Shut that thing off before you kill your family !!!
Take it back or call someone to fix it !
This is a ticking bomb you have,...
If You smell gas then you should call the city or 911 .
Jan 15, 2009 | Magic Chef 31000 Gas Kitchen Range
Kitchen Ranges Logo
131 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
