Restek amplifier channels cut out sometimes
I have a Restek Fable amplifier, and sometimes the left or right channel cut out or get fuzzy. Turning up the volume (?) and then back down again seems to fix the problem. Does anyone have any idea how to troubleshoot this problem?
Much thanks,
HC
My Restek has the same problem.
Change the volume potentiometer. Use an 10KOhm Alps potentiometer and your problem should be solved.
Peter
Posted on Jan 04, 2011
Rear left channel makes my speaker pop cuts in and ou at certain settings
Swap left and right speakers. Does it stay with the speakers if so you have a blown or damaged speaker. If not then swap input cables only. If it stayed with the speaker you now know the amp has a bad channel and needs repair. If it swapped again you either have a bad cable or issue with your source unit.
Jul 26, 2016 | Kicker ZX650.4 Multi-Channel Amp - 480W ZX...
I have 4 speaker wires, black green red white speaker left + speaker right + speaker left - speaker right - which cable goes where?
4 speaker wires, black, green, red, white ;speaker left +speaker right +speaker left -speaker right. First see what pair of speaker wires go to left the channel of the amplifier. One of each speaker must be connected to each amplifierĀ“s channel, no matter of colors of the wires. Two wires for each speaker to each channel of the amplifier (rear panel + and -). Then you will have 4 wires connected to 2 stereo channels of your amplifier. Two wires for each speaker.
Sep 17, 2010 | AudioSource Amp Four 2-Channel Amplifier
Left channel goes on and off.
Well, if messing with the RCA cables affects the problem what does that suggest? Have you tried swapping the Left with the Right to see if it follows the cable or stays with the component?
Feb 23, 2010 | Creek 5350SE Amplifier
Front right speaker got wet, started cutting out. at the same time the rear right speaker started cutting. switched the rear speakers to opposite channels and this caused the right to work and left to cut....
the speaker getting wet will short it out. Shorting the output on any amp will ruin it. there is a right and left chanel with 2 outputs. Right chanel is damaged.
Sep 30, 2009 | Boston Acoustics GT-42 Car Audio Amplifier
The left channel in my Cambridge Azur 640 amplifier keeps cutting out. Wierdly I can often 'shock' it back to life by quickly turning up the volume a lot. Any ideas?
have the volume control cleaned by a spray of electronic contact cleaner. If the carbon coating material is already wiped-out due to use, have the part replaced
Aug 03, 2009 | Cambridge Audio Azur 640A Amplifier
The left channel of my stereo goes out sometimes
The most common cause of this is corrosion on the output speaker relay contacts. A simple test can confirm this: When the channel drops out, try turning up the volume. If the channel kicks in again, the relay contacts are the likely problem. The higher volume generates a higher voltage which essentially "jumps the gap" and restores contact.
Keep us posted.
Da n
Apr 26, 2009 | Kenwood Audio Players & Recorders
Right channel cutting out.
connect right channel speakers to amp left out if the problem fixed you will have a problem in amp itself.
if the problem remained you will have a problem in speaker itself test first with new cable and second with speaker cabinet,
Apr 14, 2009 | Audio Players & Recorders
Car system
if you have dual voice coils connect on each seporate sub negative left channel to possative right channel of the subwoofer same to other sub then conect the left possative and the right neggative to your box power terminal same to other sub then conect the two sub outs on your box left speaker positive to your positive left channel bridge then conect left speaker negative to the right speaker possative then connect your right speaker negative to your right channel negative brigdeg to your amp is single coil hook the box its self up the same way to your amp i have two dual voice cooil 12" hooked up to the same amp that way and it rocks without the power protecter turning on
Nov 09, 2008 | Pyle PLA2200 Car Audio Amplifier
Left Front Channel Goes in and Out
left channel there is a problem use a tester to locate the bad transistor
Sep 16, 2007 | Alpine MRV-F357 Car Audio Amplifier
493 people viewed this question
 Grubhead
Grubhead
