Question about KitchenAid Dishwashers
KUDG25SH seems to have an electrical ghost. Goes
KUDG25SH seems to have an electrical ghost. Goes dead, as if a door switch, but does not really seem to be that. Comes back to electrical life for unknown reasons at unknown times. Maybe a funky relay or bad ground???
  • 8,197 Answers
I've seen this happen before, your control board is malfunctioning.
You have a 5 yr. warranty on your electronic controls, contact KitchenAid to come out if your dishwasher is under 5 yrs. old.
Good Luck
Posted on Sep 30, 2009
Microwave will not run a cook cycle. Touchpad functions until door is opened or start button is pressed. When door is opened display goes dark. When door shuts display lights all characters and then says...
BEFORE DOING ANYTHING DISCONNECT OVEN FROM POWER. I do NOT recommend doing repair by yourself, if you NOT are really very familiar with electric repair, or have at least basic training in electric device repair and maintenance.
"When door is opened display goes dark. When door shuts display lights all characters and then says "touch clock"."
Obviously, by opening door, oven gets disconnected form power line.
This is mostly caused by loose connections on wiring socket, and can be anywhere inside. Check security micro switch on door latch. This switch normally disables only running the oven when door is open, for security reasons. In your case, it seems that opening door disconnects oven from input power. Sometimes the switch is loose, or wires are not firmly pushed in the socket. If the power line wiring is loose, and by opening door looses contact with socket, it can touch metal housing inside, cause short, electric shock, serious even mortal injury and fire. This is dangerous high voltage switch, and to access it one must open oven from the back and take off the cover. I do not recommend doing it by your self.
Rem: Replacement micro switch is couple dollars.
Oct 24, 2014 | Microwave Ovens
Is my Coffee Machine dead?
Hi, you should check first the safety contacts (door open detection, brew group inserted detection) that will prevent your machine doing its initialization properly.
If all contacts are OK (check with a multimeter), it might be the electronics board has a failure. If the lights goes on, the power supply seems ok. Try ti figure-out which section is faulty.
Do you have any alarm light on ?
Hope that helps.
Aug 19, 2014 | Saeco Vienna Deluxe Automatic Coffee Maker...
I've a stoves efa600h electric oven and grill, and it's stopped working! It will switch on, and start up even as normal, but then after not very long (not long enough to cook oven chips) it's as if all...
There seems to be an overload switch in the stove and that is tripping out and resetting after the 10 minute interval. You need to find out if the overload switch is faulty and tripping out at a lower load, which is the more likely scenario, or if the stove is really overloading the switch. A snap amp meter around one of the cables will give you the stove current draw. Probab;y easier than doing that will be to replace the switch and see if that fixes the problem.
Feb 06, 2011 | Stoves Newhome ECH600MXa Electric Kitchen...
Sony Bravia with really bad ghosting
The little board on top attached to panel.
Jul 05, 2010 | Sony Bravia KDL-32ML130 32 in. LCD TV
Microwave went dead
Hi
If your microwave oven doesn't seem to work at all, check these: Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Apr 26, 2009 | Whirlpool MH7140XF Microwave Oven
Screen goes dull at times
The dulling picture really sounds like a lamp failing. You would need the sony lamp xl-2100u
The ghost image may be easier to fix, sometimes as lcds age you will get a slight shift in a color. deep in the sony menu there is a parameter (menu-setup-imageshift) that will give you 3 levels of correction, this may solve this issue.
Dec 04, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Car won"t start..acts like the battery is dead .
possibly the alternator. or even a bad connection on one of the wires
Jul 19, 2008 | 2000 Kia Sephia
Frigidaire ES340 clicking noise and display blinking when oven door opens
sounds like a bad door/light switch.it cant seem to tell if door is open -closed and clicking really fast betweeen the 2. replace the switch
Mar 02, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Broken water dispenser
hi tbag-1, you can check the solenoids at the rear of the refrigerator, one of those two is for the ice maker and the other one is for the water dispenser. check for continuity of the coil after you have pick which one is which. or you can check for presence of voltage if somebody is pressing on the switch at the front of the door.if there is no voltage, then the problem could be in the micro switch at the door. it is just a little bit hard to replace it.
i hope i was able to help
Feb 01, 2008 | Whirlpool GS6NBEXR Side by Side...
Dishwashers Logo
26 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
