Question about Mitsubishi WS-55819 55" Rear Projection Television
Recently, the color started going in and out.
A couple of weeks ago, it wouldn't turn on on the first try. It took a couple of attempts to turn it on. Now, it doesn't turn on at all.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 100 Answers
Sounds like the power switch has gone bad, Have a repairman look at it.
Don't try this yourself. There are components inside that tv that can kill you instantly if touched.
Posted on Sep 30, 2009
2007 Hummer H3 intermittent starting problem
run the fault codes to get an idea of the failing sensor
Nov 21, 2017 | Hummer H3 Cars & Trucks
Toyota Echo Won't Start
check starting system. as you said, you were be able to start when it push.
and if you notice when ignition is on the engine not cranking, starter is the sure problem.
May 27, 2013 | Cars & Trucks
1988 lxi honda accord battery drains overnight
Just a couple problems I've had. dome light left on due to faulty door open switch, spot light charger or equipment left plugged or wired to battery, lately I thought I had a bad battery but I just need to clean the terminal connections. One more thing if your car is running you can pull the negative cable off the battery. If the car dies your alternator could be the problem. If you have a light in the trunk or under the hood you could pull the bulb out to make sure you don't have a faulty switch turning them on. These are kind of simple and that is the way I start out.
Jul 04, 2017 | 2007 Honda Accord Sedan
2000 grand jeep cherokee limited 4.7 liter, v8, at first wouldn't start rplaced battery because dead and then replaced starter. ran ok for a couple days. last night started it and hard time with it...
Hi
Pop into to your local garage and have a diagnostic test carried out.
Listen to the advise given. It may save you lots of money, especially if you start the "guessing" game.
It does sound like a part may be blocked or failed though, but the sytem needs to be tested thoroughly first.
Good luck
Roger
Apr 24, 2017 | 2000 Jeep Grand Cherokee
Samsung 40" flat screen looses sound
this problem started on my LN-S4051D a couple of years ago. eventually the sound stopped working altogether. I then started using my surround sound speakers for the TV via optical out but soon that stopped working as well. I recently took the TV to a repair shop who said that the main board is bad and needs to be replaced. Labor plus parts was going to cost me $400. I said no thanks and paid for the estimate. Good luck.
Jun 27, 2010 | Samsung LN-S4051D 40 in. LCD Television
My 44in rca dlp picture is black and is making a humming sound
It sounds like to me theat the new lamp is faulty. If there is any pieces of glass in the lamp compartment, remove them so they will not travel and get wedged in places they should'nt be.
Hope this helps,
Skyassoc
Jun 16, 2009 | RCA Televison & Video
97 Jetta won't start
tyr disconnecting the temp sensor unit and try starting it
Jan 01, 2009 | 1997 Volkswagen Jetta
Samsung DLP HL-R5067 blinking lights
when is the wheel is broken doo you cleaned the glass around because if it not rotate tv not turning on it is a one of the posibilitis
Mar 02, 2017 | Samsung Televison & Video
Mitsubishi WS-55819 55" Rear Projection Television Logo
37 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
