Question about RCA Audio Players & Recorders
RCA ''professional series'' STAV 4090 Audio Video receiver. The receiver recently started displaying a generic ''amplifier error'' message on the LCD when attempting to play music on it through the AUX input (the only input we've used); when this happens it stops working. I don't know what is wrong with it.
Why wont the power come on? While the red stand by light is on.
Could be an open internal fuse or power supply failure
Dec 02, 2016 | RCA Audio Players & Recorders
Se apaga el rca stav-3970 audio video receiver automaticamente al encenderlo
If you wish to get some details; check the site linked here. Pull up older posts.
Jun 29, 2016 | Televison & Video
Rca receiver overload message
Power the unit off , Disconnect all the speakers ,power the unit back on and check to see if you get the same message, if so one or all of your speakers could be bad. This message appears when there is too much load on the output IC's,generally causes shutdown. Also try blowing the system out with canned air, And removing anything that prevents the unit from getting enough ventilation.
Feb 21, 2014 | RCA Stav-3870 Audio Video Stereo Receiver
RCA STAV 3990 Power comes on but relay will not
Hi,your amp is going into protection mode.You need to have the amp module repaired or replaced
Nov 03, 2013 | Audio Players & Recorders
Out amplifier part I need to bye but I lost of original
If it is radio Shack try there for a service manual or a parts list.
Jun 14, 2012 | RCA Radioshack 31-5003 Stav-3860 60-watt...
Were to buy remote control stav4090
RCA RECEIVER STAV-4090 REMOTE CONTROL TESTED - eBayhttp://cgi.ebay.com/RCA-RECEIVER-STAV-4090-REMOTE-CONTROL-TESTED_W0QQitemZ350325382341QQcmdZViewItemQQimsxZ20100309?IMSfp=TL100309199008r7940
also Amazon carries this as well,
Stina665
Mar 15, 2010 | Audio Players & Recorders
''Power off ''flashes ten times after the receiver is turned on.
Most often it will require an output IC, but I have seen it be a bad ground or a transistor in the protect circuit.
Oct 16, 2009 | Optimus Audio Players & Recorders
208 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
