Several years ago I purchased 2 Split-Type Room Air Conditioners--Models RSW-17 (Indoor Unit)/ROW-17 (Outdoor Unit) and RSW-12S (Indoor Unit)/ROW-12S (Outdoor Unit). The airconditioners themselves are fine, however,the Remote Controls for both these units, Model AR-DJ15, have gone bad and may not be repairable. How/where can I purchase replacement remote units? Alternatively, where/how can I send my remote units for repair? Chester D. Copemann eldogo2@gmail.com or chester.copemann@ceridian.com. 340.773.5113 (W), 340.773.5163 (Fax).
    President:
  • 3,433 Answers
Type in the mfg. name in the search bar and see if you can find resources.
Posted on Sep 30, 2009
I have a Haier split type room air conditioner HSU-30HEA03/R2(DB) when I turn it on the display shows E7 what does this mean please.
that mean Communication fault between indoor and
outdoor units. Some wire is cut. check wires from indoor to out door unit. Open indoor unit and check cleme open outdoor unit and check it too
Nov 24, 2017 | Haier Heating & Cooling
WHAT IS REFRIGERANT SUCTION PRESSURE OF MY 1 TON SPLIT AC?
R22= 70-80psig
R410a=120-130psig
Depending on many variables such as blower speed, coils clean, indoor/outdoor temps.
Aug 05, 2015 | AMVENT 18000 Btu 1.5 Ton Ductless Mini...
We have a Misubishi mini split ducted heat pump. The thermostat is saying no signal What to do?
Try cycling the power supply to the outdoor unit. The indoor unit is powered off of the outdoor unit and the wireless signal to the room sensor originates in the indoor unit. Something may have disrupted the output signal to the room sensor and a quick reset MAY do the trick.
Jul 23, 2015 | Heating & Cooling
Out door is not working
Check for communication from indoor to out door.Check power in out door unit. If not, check the following.
Keep cool mode and temp setting minimum 3 degree less than room temp.
Check indoor unit return air sensor. Disconnect sensor from PCB and measure resistance. 8 kOhm at 30C and 13 kOhm at 20C if not replace air sensor
Check Indoor Pipe Sensor Disconnect from PCB and measure resistance. Pipe sensor = 5kOhm at 25C. If not replace pipe sensor.
Thanks and hope helpful?
Feb 04, 2011 | LG LS-L1210CL Mini Split Air Conditioner
My split type ACU .the indoor lights are blinking and the fan motor did not function and also the outdoor unit
You didn't mention what error code it shows. But with your statement, please rotate manually your blower motor. If hard replace bearing or motor. If It rotates freely. replace room and coil sensor in indoor unit.
Jan 02, 2011 | Samsung Heating & Cooling
Lg split indoor fan runs non stop
Hello Hamid,
The unit is designed to run the indoor fanmotors continuously when in cooling mode on both indoor units (evaporators). The reason is that this circulates the air and the temperature thermistor or sensor is able to sense return air temperature and in turn start or stop the outdoor unit and compressor as required according to the setpoint temperature. The reason for either unit not reaching setpoint temperature can be a couple of reasons. A) Incorrect design - the unit may be too small for the application. You can calculate this roughly at 650BTU per square meter of room in a relatively warm ambient climate. Or secondly B) The outdoor unit has leaked and is short of refrigerant. You can check this when the outdoor unit is running by feeling the thicker copper tube on the right hand side of the unit. This should be cool to cold. If no temperature difference is felt, it is short of refrigerant. Hope this helps you. Goodbye
Aug 11, 2008 | LG LS-L1210CL Mini Split Air Conditioner
Fujitsu split level
Check for errors like blinking indoor light if present. Reset the error by disconnecting power supply from the unit for 10 sec. and "on" the unit. If the error persist, some parts of the unit may be defective and need to replace. Like room air thermistor, coil thermistor in the indoor side or the relay board. Some safety device in the outdoor may give in, some outdoor parts may be defective. You need a qualified technician for the this problem.
May 17, 2008 | Fujitsu 24C1 Air Conditioner
Mitshubishi split muh-18nvand inside msh-18nv
-Start the unit.
-Press EMERGENCY OPERATION switch.3-minute time delay works.Test run operation operates for 30 minutes.
-Check voltage to terminal block of outdoor unit.Is there 12V DC between 2-1?
-If voltage is presenet check the wiring, compressor contactor outdoor fan motor and compressor.
-If no voltage check voltage to terminal block of indoor unit.Is there 12V DC between 2-1?
-If if voltage is present re-connect the continuity of indoor and outdoor unit connection.
-If no voltage replace the indoor electronic control P.C.
board.
-But also check the coil thermistor sensor and room air thermistor if this two is out of range it can cause the tripping of out door unit. It has the resistance of 8 to 10 k ohms at 25 deg c temp.
Jan 04, 2008 | Heating & Cooling
Heating & Cooling Logo
102 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
