Question about Philips GoGear Flash MP3 Player
I unplugged to soon and erased everything and now when it turns on it give me a file system fail error and then it goes to wait for usb connection and just stays there
  • 210 Answers
For sure, the file system is corrupted and is the cause of your woes. The fix lies with the Philips Songbird software. If you do not have Songbird, download it for Windows or Mac here:http://www.usa.philips.com/c/mp3-media-player/22126/cat/en/#/difference/philipssongbird.
Once you have Songbird installed, launch it and select "Repair my Philips device" in the Tools menu. Select your device and follow the instructions specific to your device. For example, instructions for the GoGear Vibe are to disconnect the device, power it down completely, and hold the volume-up key during and after USB connection until the message window disappears.
If the repair utility endlessly indicates it is checking for updates, you are likely using an out-of-date version of Songbird - probably the one that came with your GoGear. If this describes your situation, launch Songbird and select "Check for updates" in the Help menu. This will at least get you upgraded to version 1.9 (currently), even though the latest version is 1.11 (currently).
Instructions that came with some older versions for connecting GoGear in repair mode were incomplete. They left out a crucial step of turning off the GoGear and waiting for it to power down completely before reconnecting in repair mode. Newer versions of Songbird include the ability to reformat the device, reset the device, and to get progress updates during synchronization.
If you've found this information helpful, please indicate as such.
Posted on Apr 04, 2013
Push the reset button then turned it on
Posted on Oct 02, 2009
IBM Travelstar usb 2.0 - when connected to pc get error msg - problem with drive need to scan - WILL scanning ERASE FILES THAT ARE STORED ON THE usb drive
the scan is just a program reading the files and folders either in the computer or storage device
normally it is done by the security program ( windows fire wall) or what ever program you have installed
it reports on any problems found and waits for your decision
if you run a system check, that is different as it will rectify any program faults as it goes not files or folders
it is always advisable to scan usb sticks when installing as that is a favourite way that hackers get into a computer
although the usb stick may be in your control all the time , downloads from your own computer can transfer a problem via usb stick
As for your concern---scanning will not change any files or folders but will report on any faults to you
Dec 31, 2016 | IBM Computers & Internet
Tip
Sony PS3 Hard Drive Corrupted or Asking for Restore
A Hard Drive error can be a common problem on the PS3 and this tip will outline how you can troubleshoot and hopefully resolve a hard drive problem. If your PS3 is showing signs that the hard drive is corrupted or is displaying a message asking you to restore the hard drive follow these steps carefully and you may well avoid an expensive repair or having to consign your hard drive to the bin.
Please note: Steps 8 and 9 involve erasing data from your Hard Drive. Therefore if at all possible please try to back up your data before commencing this procedure. You can do this through 'System Settings - Backup Utility' Follow the instructions given in this menu to back up information to an external storage device such as a USB Pen.
To begin the process of troubleshooting and resolving your Hard Drive error you must first put the unit into Safe Mode. Follow these steps carefully;
1) Turn off the PS3 by holding the power button on the front of the unit till it turns red.
2) Hold the power button until you hear the unit beep three times. This will take 15 to 20 seconds.
3) The unit will power off on the third beep and power light will turn red again.
4) Touch and hold the power button again as in step 2. The unit will beep three times except this time the third beep will sound like a quick double beep. As soon as you hear this release the power button.
5) You will see a message onscreen telling you to "Connect a controller using USB and then press the PS button".
6) Do as the message says i.e. connect the controller and press the PS button - you are now in Safe Mode.
7) Restore File System. From this point select "Restore File System" on the menu. The PS3 will attempt to repair damaged files on the hard drive. If this does not work move to step 8.
8) Rebuild Database. Enter Safe mode again as outlined and this time select "Rebuild Database". Be aware this mode will erase certain information from your hard drive which is not recoverable such as photo and message information. If this fails move to step 9.
9) Restore PS3 System. Again enter Safe Mode and select "Restore PS3 System". This will restore all defaults and completely formats the drive. Be aware this mode will erase all information from the hard drive.
If everyone of these steps fail and the PS3 is still showing symptoms of hard drive error you can be certain that the hard drive has failed and it will need to be replaced. However in a majority of cases these steps will resolve the issue.
on Mar 04, 2010 | Video Game Consoles & Games
Tip
PS3 Hard Drive Error or Restore Hard Drive
A Hard Drive error is a very common problem on the PS3 and this tip will outline how you can troubleshoot and hopefully resolve a hard drive problem. If your PS3 is showing signs that the hard drive is corrupted or is displaying a message asking you to restore the hard drive follow these steps carefully and you may well avoid an expensive repair or having to consign your hard drive to the bin.
Steps 8 and 9 involve erasing data from your Hard Drive so if at all possible please try to back up your data before commencing this procedure. To back up data go to 'System Settings - Backup Utility' Then follow the on screen instructions and back up the information to an external storage device such as a USB Pen.
4) Touch and hold the power button again as in step 2. The unit will beep three times except this time the third beep will sound like a quick double beep. As soon as you hear this double beep release the power button.
6) Do as the message says i.e. connect the controller and press the PS button - you are now in Safe Mode and the hard drive repair can begin.
8) Rebuild Database. Enter Safe mode again as outlined and this time select "Rebuild Database". Be aware this mode will erase some information from your hard drive which is not recoverable such as photo and message information. If this fails move to step 9.
Many thanks for viewing this Tip and I hope it has been helpful to you.
on Dec 06, 2009 | Video Game Consoles & Games
What do I do when it reads 'Communication Error' on my Canon S90 camera screen?
This happens when you connect your camero to your PC. Try plugging into another usb port if doesnt work Uninstall the Canon Software on your PC unplug the camera then restart your PC. When the PC is ready then plug in your camera to the PC. Wait until you see the Removable Icon on the System Tray. Now go to My Computer then check if you will be able to access your files. If everything fails try to use a card reader
Thanks for using Fixya
Aug 01, 2010 | Canon PowerShot S90 Digital Camera
Cannot print . Ink system has failed. Unable to copy, receive faxes, or print. Error:Oxc18a0106
Try the following steps to remove HP Printer Error Code 0xc18a0001 :
1. Without turning off the printer, unplug the USB cable.
2. Remove the cartridges.
3. Wait until the message "Insert cartridge" appears.
4. Unplug the power cord.
5. Wait 60 seconds.
6. Reconnect the power cable. If the printer does not turn on automatically, press "On button".
7. Reinsert the cartridges and close the lid.
8. If the printer has a page of calibration accept.
9. Reconnect the USB cable and remake an impression.
10. If the problem persists, the machine must be repaired.
Jul 22, 2010 | HP Photosmart 3310 Printer
Tip
Sony PS3 Playstation Hard Drive Corrupted or Asking for Restore
on Dec 04, 2009 | Video Game Consoles & Games
I erased all the songs from this mp3 play to put new ones on after erasing the songs the play won't be picked up by pc and am unable to put new songs onto mp3 plaey the players just displays please wait...
yes...unplug from pc shut mp3 off for a minute...plug it to pc (did it come on turn it on)...please get into the habit of disconnecting any usb connection with the safety disconnect...(green icon in task bar when usb is connected)...since you already deleted all files (format it now) start fresh...now you are able to put your songs on it...but to disconnect do not....do not just unplug the usb
Jun 20, 2010 | RCA M2000 MP3 Player
Cannot format my MY Passport HDD 250GB...Showing ERROR in Erase!
You shall once more format the HDD but this time don't opt for quick format. This time select create a MS Dos bootable. Once you have formatted and if success it will work. You have 90% chances it will work. If it doesn't comment back will give you another option to make it work.
May 09, 2010 | Western Digital WD Passport 250GB Portable...
New songs= black screen
try to remove the battery, wait 30 seconds and replace it
this should reset your sansa,
a real hard reset isn't possible,
you can format it though
warning, this removes everything
To format your Sansa E200 series MP3 player:
1. Open "My Computer."
2. With the player plugged into the USB port, right-click on the player (if in MTP mode) or the drive letter for your player (if in MSC mode) and select "Format" from the right-click menu.
3. Press "Start."
4. You will receive a warning that the format process will erase all data on your device.
IMPORTANT: Make sure you have backed up all of your data from the device before continuing with the format. Procedure will erase everything off the player. Agree to the warning.
5. The format will complete. Close the format window and your player should be ready to use.
After the format, please install the latest firmware update for your player. Please visit the following link to download and upload the Firmware on your Sansa E200:
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00...
PLEASE NOTE: All files will be deleted. Backup your files. Your MP3 player must be in MSC mode before installing the Firmware update.
To set your player in MSC mode, please do the following:
1. When the player is turned on, press the “Menu” button.
2. Navigate to the “Settings” menu.
3. Navigate to “USB”.
4. Under the “USB” menu, go to “MSC”.
After changing the player to MSC mode, reconnect it to your computer. The screen on the MP3 player should read “USB Connected” and "MSC”
You can now complete the Firmware update download from SanDisk.com on your device.
Installation Instructions:
1. Unplug any other USB flash drives that's connected to any of your USB ports.
2. Download the firmware to your PC
3. Plug in your e200
4. Double-click on the downloaded firmware (e200fw01.00.12.exe) and follow instructions
5. Unplug your e200
6. Device will do it's own update process and will restart.
The device should be ready to be used again.
Dec 16, 2007 | Audio Players & Recorders
My sansa e280 shows error!!!!help here
Go to Device Manager, and click on each usb port indivdually, and then click on update drivers.
If that fails:
Go ahead and do this, in case the DB is corrupted:
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Nov 25, 2007 | SanDisk Sansa E280 MP3 Player
Philips GoGear Flash MP3 Player Logo
101 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
