Question about LG DLE5955 Dryer
How do you dimantle cabinet to access heating element and safety therm? dle5955
    Sergeant:
    Champion:
  • 289 Answers
Unplug the dryer,remove the three screws at the bottom panal,remove panal and the element is on the right.the safety themastate is on left side on outside of body of heating element.
Posted on Dec 26, 2009
How to change dishwasher heating element
Remove the dishwasher from the cabinet after disconnecting the water,power and drain. turn upside down to access the nuts that hold the element in. also replace the gaskets on the element or it will leak.
Mar 29, 2014 | Whirlpool Dishwashers
Tip
How to Replace Heating Element from a Maytag Dryer?
The procedure is as follows:--- 1) First of all unplug the dryer from electric outlet for safety reasons.
2) Locate the vent hose on the rear of the dryer and disconnect this hose from dryer unit.
3) The hose is mostly fixed in a metal clamp and the metal clamp is fixed by the screw. Loosen the screw and remove the clamp and remove the hose.
4) The heating element is located in the cabinet.
5) In some models the cabinet is located at the rear of the dryer. And in some model its located in the front of the dryer.
6) Locate the heating element cabinet and remove the screws holding the cabinet.
7) You will see the heating element now. There are wires connecting on the sides of the heating element terminals. The wires are connected by removable connector.
8) Remove the connector carefully from heating element with the help of needle nose plier.
9) After the wires are removed from heating element’s terminals. Remove the screws holding the heating element.
10) The heating will have to be moved a bit to come out easily. Before removing the heating element out. Please note down the position of old heating element. So while placing the new heating element you don’t face any problem.
11) Remove the old heating element and insert the new heating element.
12) Connect all the wires as it were connected before.
13) Refit all the parts which you removed while removing the old heating element in reverse method. Take care you don’t miss any part fitting.
This will help. Thanks.
on Mar 20, 2010 | Dryers
I replaced fuse, high limit thermostat and thermal cut off, still heater does not cycle on and off, just gets hotter and hotter., is this the thermistor or something bigger?
I would first check to see if the heating element is shorted out. When the vent or blower housing of the dryer get built up with a lot of lint the dryer won't vent out the heat properly and it can cause the heating element to warp and short out against the cabinet. To check for a shorted element you should unplug the dryer and remove the bottom panel. On the right side you will see the heating element, remove the two wires that connect to the element. With a multi-meter, check to see if you have continuity from either side of the element to the cabinet that hold the element. You should NOT have continuity when you check for this, if you do the element is shorted out and will need to be replaced. You can also pull out the element and do a visual inspection, sometimes you can see where the element coil is touching the housing. When the element is shorted out, it will continue to heat when the dryer isn't calling for heat. They will even heat with the dryer not running, so make sure to unplug it for safety reasons.
Jul 27, 2012 | Whirlpool Dryers
Whirlpool Model LE520XTWO Not Heating. Have Manual Followed steps to check element, its reading 12 ohms.. Hooked it all back up and started in high mode.. Checked voltage at heater elements terminals,...
most whirlpool dryers have a safety therm near the top of the heater housing. Check with the ohm meter and should read 0 ohms (remove at least 1 wire). Also check power at plug for 220 volts. If not check fuses at panel.
Oct 28, 2010 | Whirlpool Dryers
No heat coming out tested power have 220 no continuity between leads figure element burned out how do you replace?
In general, remove the cabinet top, then the cabinet front. This should give access to the drum which needs to be removed. You need to release the drive belt tension by accessing the lower back panel to get to the motor where the tension device is located. Remove the screws in the center back of the drum and take out the drum. This should expose the heater assembly along with a thermostat switch and a safety high-temperature switch. Both switches should be 'on' when cold. The element(s) should read fairly low 'ohms' if good. You can sometimes just replace the heater wire, or replace the whole assembly--your choice. Re-assemble in reverse order. Check the condition of the drive belt and outer drum bearings (rollers or sliders) while you have it apart. Hope this helps!
Sep 29, 2010 | Dryers
How do i change the heating element.
The heating element is accessible through the lower front access panel. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the two screws attaching the bottom of the lower front access panel to the cabinet then slide the panel down then off the cabinet. The heating element can now be accessed and repalced.
Remove the screws securing the heating element to the heater box then pull down the heating element to remove it from the heater box.
Disconnect and label the wires for the heating element and the components. Remove the components from the old heating element then transfer it to the new heating element.
Slide the new heating element up into the heater box and secure it in place. Align the slots on the top of the lower front access panel with the locating tabs on the front access panel then slide it into position and secure the bottom of the lower front access panel to the cabinet.
Apr 13, 2010 | Amana DLE330RAW Electric Dryer
No heat, but dryer turns.
There are three common causes of a dryer not heating. First is a busted heating element. Second, the thermal cut-off has blown. Third, the high limit thermostat is not working.
Disconnect power to the machine and remove the screws at the bottom of the lower front access panel (toe panel) holding it in place. Pull the panel down and off the cabinet. You now have access to the heating circuit.
Remove the heater shield by removing its mounting screw and pulling it off the heater housing.
The heater terminal block is located at the left opening of the heater housing. Disconnect the wire from one of the heater terminals and measure the resistance of the heating element using an ohmmeter set to X1. The resistance should read 7.8 -11.8 ohms. Replace the heating element if the resistance reads open.
Disconnect the wires from the terminals of the heating element and remove the screw securing it to the heater housing. Slide the busted heating element out of the housing and install the new heating element. Secure it with the screw and put the terminal block in place. Connect the heater wires and reinstall the heater shield.
Slide the lower front access panel up into the cabinet and secure it with the screws.
Feb 28, 2010 | Kenmore Elite HE4 Electric Dryer
Heating element is out.
Instructions Things You'll Need:
  1. Step 1 Unplug the dryer from the wall before starting. Find the dryer heating element cabinet. For most dryers this is located in the back, however it can be in the front. Find the compartment on the dryer.
  2. Step 2 Remove the screws or clips to get into the compartment to expose the heating element and wires. Use a needlenose pliers to carefully remove the element wires.
  3. Step 3 Detach the can shaped object that may cover the heating element. Tip the can backward to slip it off the hooks holding it in place. Some models place the heating element with the can, while others provide easier access to it.
  4. Step 4 Unscrew the screws holding the element in place and pull it out.
  5. Step 5 Put the new element in place, and replace the screws to secure it in the dryer. Put the can back in place and connect the element wires before putting on the cabinet cover.
  6. Step 6 Run the dryer on fluff with no heat, and go outside to make sure enough air is getting through the vent system.
  7. Step 7 Break the new heating element in by running your dryer on high heat for 10 minutes without any clothes in the dryer. This cleans oily residue off the element and keep the clothes from getting smoky.
Dec 01, 2009 | Kenmore 62602 Electric Dryer
Heat elament is out
  1. Unplug the dryer from the wall before starting. Find the dryer heating element cabinet. For most dryers this is located in the back, however it can be in the front. Find the compartment on the dryer.
  2. Remove the screws or clips to get into the compartment to expose the heating element and wires. Use a needlenose pliers to carefully remove the element wires.
  3. Detach the can shaped object that may cover the heating element. Tip the can backward to slip it off the hooks holding it in place. Some models place the heating element with the can, while others provide easier access to it.
  4. Unscrew the screws holding the element in place and pull it out.
  5. Put the new element in place, and replace the screws to secure it in the dryer. Put the can back in place and connect the element wires before putting on the cabinet cover.
  6. Run the dryer on fluff with no heat, and go outside to make sure enough air is getting through the vent system.
  7. Break the new heating element in by running your dryer on high heat for 10 minutes without any clothes in the dryer. This cleans oily residue off the element and keep the clothes from getting smoky.
Sep 23, 2009 | Washing Machines
LG DLE5955 Dryer Logo
151 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
