Question about DFI K8M800-MLVF Motherboard
Upgrade to 400 mhz 2x1GB memory
I purchased 2x1GB memory 400 mhz DIMMS (DE468A-ALC) for my DFI K8M800-MLVF mother board.
When I plug them in the machine doesn't boot.
I believe I got the right memory. Is there some jumper or something to change?
I was(is) running 333 Mhz 2x512mb now
  • 3 Answers
The RAM speed setting should be in the BIOS. Press Del or F2 (whichever shows on the screen) before the Windows sceen comes up. You usually have to press it repeatedly, because there is a short time during startup when the keyboard is not active (and you can't tell). Once you are in the BIOS there will be instructions on how to move around via arrow keys or page up, page down buttons. Look around in the menus - there will be a setting for RAM speed there. If you accidentally change something you are not sure of you can always quit (F10) withour saving changes. Hope this helps.
Posted on Sep 30, 2009
    President:
  • 1,901 Answers
Hello, First thing I would try is to just install one of the new modules in the DDR1 slot and see if it boots. If it does, go into your BIOS (Use the key I believe.) and set the ?Max Memclock (Mhz)? field (Advanced Chipset Features submenu) of the BIOS to 200. Save & Exit and allow it to boot. Shut down the computer and install the second one. Again go into the BIOS and verify it is detecting both. A second thing to try if that does not work is to install the new modules, and before powering up, reset your CMOS using the jumper between the battery and the AGP slot. If the jumper is on the 1st and 2nd pin, put it on the 2nd and 3rd pin for 15 seconds. Then replace it to the original position. NOTE: Make sure the power is OFF and the power cord unplugged when you do this. You should also press and hold the Power button for 5 to 10 seconds to discharge the capacitors in the system. If this still fails to get you going, you may have high density modules which do not work in all motherboards. Did you get the modules from MS Memory Suppliers? When I did a search for your motherboard it only gave me DDR266 PC-2100 DIMMS as compatible. No DDR400 were listed even though they should be backward compatible. Hope this helps. Thanks for using Fixya. Comment back and let me know your results.
  • Wayne Mineard
    Wayne Mineard Sep 30, 2009
    This system is always messing up. Sorry about the formatting. It wasn't like that when I was inputting it in the reply box.
    I see that it removed the DEL key for getting into the BIOS.
Memory Upgrade
The memory must be matched registered1333 MHz DDR 3 ECC memory. Make sure that the memory you purchased meets these requirements or the motherboard will not recognize any DIMMs that do not meet the requirements set by the manufacturer.
Jan 08, 2014 | IBM System x3200 M3 7328 Server tower ...
I have intel pendium d d102ggc2 motherboard. am using 512 mb ram ddr2 667mhz. Now i want to upgrade it and use 2 gb ram. please suggest.
Mother board d102ggc2
• Support for DDR2 533 MHz and DDR2 400 MHz DIMMs
• Support for up to 2 GB of system memory
Dec 27, 2012 | Intel D102GGC2 Motherboard
Dont know the ram that it use. wat is the number on the battery
  • K8M800-M7A
  • Support DDR 333/400 MHz
  • 2 x DDR DIMM Memory Slot
  • Max. Supports up to 2GB Memory
  • the battery i dont no
  • hope it helps
  • Biostar K8M800-M7A - motherboard - micro ATX - Socket 754 - K8M800 specifications
    • General
    • Product Type Motherboard - Micro ATX
    • Cache Memory None
    • Chipset Type VIA K8M800 / VIA VT8237R
    • Max Bus Speed 800.0 MHz
    • Processor Socket Socket 754
    • Max Processors Qty 1.0
    • Compatible Processors Athlon 64 , Sempron
    • Memory
    • Max Supported Memory 2.0 GB
    • Supported RAM Technology DDR SDRAM
    • Supported RAM Speed 400 MHz , 333 MHz , 266 MHz
    • Graphics
    • Graphics Controller VIA UniChrome Pro
    • Memory Allocation Technology Shared video memory (UMA)
  • Jul 20, 2011 | Biostar K8M800-M7A Motherboard
    Hi, i was windering if it was possible to use 168 pins pc133 memory modules instead of the ddr 266 into my P4B266 Motherboard, since they have the same size and work at the same frequency. In the manual,...
    *********** board will suport for 133 bus speed memory.Memory Size is not the matter,what ever you can install in the mother board,may be 128/256/512,but ensure the bus speed .It wont be more than 133 mhz.,then your mobo can not support.If you have SDR 133 bus speed ram you can install .
    *********** board speed is 400 mhz,you can change 478 pin any intel processor,for better performence but the bus speed would be 400 mhz or bellow 400mhz,both will be suported.
    For detail follow bellow the link.
    http://www.firingsquad.com/hardware/p4b266/default.asp
    Hope it will you.
    Jan 08, 2011 | ASUS P4B266 Motherboard
    I want to upgrade my system ram size to 2gb...my system memory configuration as follows mother board: intel102ggc2 system bus speed :800mhz processor (p4):3.0ghz ram slots available:2 and presently i'm...
    The below is the contents of Intel published for your board
    Intel Desktop Board D102GGC2 Technical Product Specification
    System Memory The board has two 240-pin DIMM sockets and supports the following memory features: • 1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts • Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMS with x16 organization are not supported. • 2 GB maximum total system memory. • Minimum total system memory: 128 MB • Non-ECC DIMMs • Serial Presence Detect • DDR2 533 or DDR2 400 MHz SDRAM DIMM
    hope it helps, if so rate the solution
    Nov 16, 2010 | Intel D102GGC2 Motherboard
    I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
    Hi this model sopport 2Gig Memory Ram.
    RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
    Please check in to your Bios system maybe share memory Video or capacity is setting
    Nov 03, 2010 | Dell Dimension B110 PC Desktop
    One long beep two short beeps
    I hate to say it, manish, but this board runs Award bios, and as such, one long and two short indicates a video issue, not RAM. Try reseating your video card, gymnasticsby. If you are not using an add-in card (using the onboard, in other words), disconnect your power cable from the wall, ground yourself on your computers' case, and remove the onboard battery to reset your bios to defaults. You can tweak your settings once you have a functioning display; It's rather tough to accomplish anything if you can't see what your machine is doing.
    Oct 04, 2009 | DFI K8M800-MLVF Motherboard
    Please identify RAM upgrade options for Asus PSCH-L motherboard. Thank you.
    From the Asus spec site: Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB
    Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB DDR SDRAM 400; 333; 266mhz
    4 GB max 4x1024 184pin
    Hope this helps.
    Aug 26, 2009 | ASUS PSCH-L Motherboard
    RE: mother board not going on
    Hi marlonvig, what type of memory (PC3200? or PC2700) memory are you using? What type in which slot?
    The decription (In you're manual), refering to you're memory can be confusing.
    You're manual says you can use up to 1GB of
    PC3200 DDR400MHz only in Slot 1.
    If you add DDR400MHz into slot 2. The board will not support it. (weird)!
    If you want to reach 2GB of memory. You must use PC2700 (DDR333)MHz. 2x1GB PC2700 = 1GB DIMMS in both DIMM 1 & 2. You're board does not support DDR2 type memory.
    Need you're manual? Download it from this link. Click on it.
    http://www.asrock.com/mb/manual.asp?Model=775VM800
    Asrock's home page for you're 775VM800 board.
    http://www.asrock.com/mb/overview.asp?Model=775VM800
    Mike
    Apr 28, 2008 | Asrock 775VM800 Motherboard
    Open Questions:
    Official Toshiba Support ' Toshiba Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Virus like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
    Apr 19, 2018 | Toshiba Computers & Internet
    See all DFI K8M800-MLVF Motherboard Questions
    DFI K8M800-MLVF Motherboard Logo
    102 people viewed this question
    Top DFI Computers & Internet Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Tony
    Steve Frost
    Steve Frost
    Are you a DFI Computer and Internet Expert? Answer questions, earn points and help others
