GE Side by Side Refrigerator
Problem for GE (PSS26MSRSS) Side by Side Refrigerator
Refrigator compartment not cooling
By diannerivera on Sep 30, 2009
refrigator compartment not cooling , we re-set the temperature control to 37 has required , due to it had gone up to 50 , but instead of going down to 37 , it keep on going up and now is 54... Want could be causing this problem
Best Solution
posted on Sep 30, 2009
Helpful)
Sea Breeze
Rank: Guru  GE Refrigerators  Expert
Rating: 90%, 758 votes
This is a sign of a defrost problem or the damper is not opening from the freezer compartment. Look inside the rear of your freezer rear wall and see if frost is building up on the rear panel. If yes then unplug the refrigerator and remove the freezer rear panel to defrost the evaporator coils so you will be able to see the defrost heater under the evaporator. If burned out it will be easy to see because the outer case is glass covering the element that is inside. Let me know what you find and I will assist you in your repair, Thanks Sea Breeze
Comments:
Sep 30, 2009
- Your defrost heater part number is WR51X10055
You refrigerator has no defrost timer. The defrost is controlled by the mother control board.The part number for the defrost thermostat is WR50X10054
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
SEA BREEZE TIP'S
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Here is a link to a service manual that may be helpful.
Click Here=> PROFILE ARTICA REPAIR MANUAL
Sep 30, 2009
- Thank You For The Rate! Hope to have you fixed, Thanks Sea Breeze
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" thank you for your help ..... " - diannerivera
Popular Solutions for GE Side by Side Refrigerator
Questions and Unsolved Problems for GE Side by Side Refrigerator
Do you recommend GE (PSS26MSRSS) Side by Side Refrigerator?
Answer
Answer
freezer works great but frig side stays cool on 9.
Answer
I have a GE Fridge model number GTS18WC and the drain line is clogged. I removed the panel in the... (More)
Answer
the refridgerator stopped cooling the freezer is fine
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerator Experts
Top Refrigerator Repairmen
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
