Question about Logitech G25 Wheel And Pedals Set
The steering wheel doesn't turn. But every buttons on the steering wheel and shifter, pedals are all working only steering wheels who doesn't response.
SOURCE: G25 Wheel No Longer Responsive
I have this problem and i emailed logitech, they told me to send the wheel back to the dealer for a replacement :(
Posted on Sep 19, 2007
SOURCE: Sabre steering wheel and pedals for ps2
YOU HAVE TO GO TO GAME CONTROLS.
CLICK ON ACCELLERATOR AND STEP ON THE GAS
PEDDLE TO PROGRAM IT INTO YOUR GAME.
REPEAT THIS PROCESS FOR ALL YOUR GEARS ETC.
Posted on Dec 26, 2007
SOURCE: G25 wheel not responding
Hi Guys, I have found your solution. If all the buttons work, but the steering does not, it's because the buttons are powered by the USB bus. The electric engine of the wheel need really juice from the power supply. I have just bought a G25 and all the buttons worked fine, but turning the wheel was completely undetected. The power supply was cold as a supermodel heart. I have just put a new power supply and now all the things work perfectly. By the way, my thanks to all the other guys that posted the G25 issues, it really helped me out.
Enjoy your driving !
Petro
*hiadventure@hotmail.com*
Posted on Oct 17, 2008
SOURCE: logitech Driving Force GT wheel won't work at all
Ive had this problem yesterday. Confirmed.
Call them to have words. Have respect and they refund you full.
Towards the G25.
I did that. Cause if I broke 1 DFGT then I will break more.
I think that the G25 withstands even drifters technique.
See you on PS3 Tag: DriftMagnet
Logitech Tech Support. Call 1-646-454-3200
Posted on Jul 01, 2009
  • 208 Answers
SOURCE: Steering wheel is a little off set, how do I fix it.
Open your control panel. Click on "Printers and other hardware". Click on "Game Controllers". Then click on the wheel controller. From there, you should be able to assign the buttons and fix the offset.
Posted on Oct 02, 2009
Testimonial: "It got me to the point where I could mess with the configuration. But it in itself wasn't much help."
Why won't my 2002 Volvo s80 shift out of park?
All vehicles have a safety feature that won't allow a vehicle to be shifted into gear without the drivers foot being on the brake pedal . Shifter interlock system . There is a electrically controlled solenoid that locks the shifter ,when you step on the brake pedal an electrical signal un locks the shifter ,allowing the gear selector to move.
Mar 03, 2016 | 2002 Volvo S80
Which fuse to change for steering wheel lights and gear shifter lights 2010 ford edge
It's not a fuse , the SJB - smart junction box controls these lights ! This is fords body control module . If the Heater / A/C control panel ,hazard switch ,headlamp switch , message center switch all work, it is not a fuse . The gear shifter I would say the bulb is burnt out . The steering wheel lights could be out because of an open in the clock spring . The clock spring is a device inside the steering column under the steering wheel that keeps your horn , cruise control , radio buttons etc... connected electrically . How cars clock spring works
Feb 04, 2016 | 2010 Ford Edge
Ignition key wont turn have tried everything from turning steering wheel and making sure that it was in park does the ignitoun need to be changed and is it job that i could do or does it need to go to the...
Try banging on the shifter, if this works, spray some silicone spray into the shifter at the release button (the cable from the shifter to the ignition lock sticks sometimes). If this doesn't work, you may have to replace the ignition lock. It is held in with 2 breakoff bolts that have to be drilled out.
Apr 23, 2011 | 1999 Volvo S80
5 year old grandson just found his mothers old PS2 and the Mad Catz racing wheel and pedals. Lookig for instructions for wheel/pedals so he can play his PS2 "Cars" game. Wheel doesn't turn car...
Well, the game has to first be compatable for the MAD CaTz Steering Wheel. The Mad CaTz Steering Wheel is compatable with almost any racing game. Instead Of Using the Pedal for the game, he can use the X button that is ON the Steering wheel.
Feb 16, 2011 | Mad Catz Racer Racing Wheel - PS3 for...
My sons wants get a Logitech GT steering wheel to use on PC games - will it work without using the pedals ? He needs hand controls only as he is in a wheelchair and doesnt have use of his legs. Thanks Liz
I'm not sure if it will function without the pedals being connected. However, Most PC games allow you to customize controls. i.e. You will be able to set gas and brake to the buttons on the wheel. So the pedals will not be nessessary. So to answer your question, yes, but it depends on the game, not the steering wheel itself.
p.s. The above only applies if we are talking about PC games. Without the pedals, You will lose two methods of input which may need to be assigned elsewhere (like a keyboard). Consoles like the PS2 will not have this option.
Dec 05, 2010 | Logitech DRIVING FORCE FEEDBACK STEERING...
Ignition switch will not turn on. Battery is good. Steering wheel is locked, What should we do?
Quite often that will happen when vehicle parked with wheels turned, and/or vehicle on a slope, so try to avoid that in future.If nothing else, when parked on a slope, stop, keep foot on brake pedal, apply parking brake, put transmission in neutral, then take foot off brake pedal and wait for parking brake to stop vehicle rolling, then shift it into park. When leaving, put foot on brake pedal, shift to drive or reverse whatever direction your going, then release parking brake. Sounds like a lot to remember but you won't have to pull hard on shifter as before, and it could save a lot of money on transmission repairs down the road. Always try to park with wheels straight as well.
Now, with that said, if you parked with wheels turned, try hard to turn steering wheel in same direction wheels are turning, just slightly, as you try to turn key. Sometimes a quick yank in that direction will do it. Also make sure shifter is all the way in park before you try it. If your on a slope try rocking vehicle slightly up slope as you push/pull shift lever in to park and try to turn key at same time. If no luck, try pushing brake pedal real hard and try to turn key. Let me know how it goes.
Nov 06, 2010 | 1999 Dodge Caravan
Car steering wheel locked; car won't start
If this is a floor shifter or center console shifter there is actually a lock release next to the shifter. Look next to the shifter handle and you should see a small square plug in the console remove the plug and you will see a little white button in it this is the shifter release push it and you can move the shifter.
Sep 20, 2009 | BMW 330 Cars & Trucks
2005 dodge magum locked in park will start up
there is a shift solenoid connected to the brake pedal circuit to release the shifter.it is the click you hear when stepping on the brake.otherwise it stays in park.
the manual overide will let you put it in gear.
May 15, 2009 | 2005 Dodge Magnum
G 25 steerring wheel
make sure you have the shifter in 6 speed mode (not sequential) at the start of the race hit the triangle button once and the clutch will be activated
Jul 21, 2008 | Logitech G25 Wheel And Pedals Set
Logitech G25 Wheel And Pedals Set Logo
138 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
