Question about Sewing Machines
Shuttle race stop move
I have this fairly new Shark 32 ditch sewing machine and my needle suddenly started to not picking up the bottom thread while I was sewing. Then I found that the needle was bended. I opened up the shuttle race and cleaned all the parts and changed the needle. After assembled shuttle race and hood race, they stop move. I was trying to use hand wheel to make it turn but also failed. Could you please help me to solve this problem? Many thanks.
LL
SOURCE: Shuttle driver
I had this problem and I just fixed it, your machine is threaded wrong, or the tension is wrong. Mine turned out to be a little of both. I was threading the tension wrong. I was threading it (when facing the machine) going in left to right, so it kept falling out. YOU MUST THREAD GOING IN RIGHT TO LEFT, then finish the threading process until you end at threading the neadle. NOW IT WORKS. I HOPE THIS WORKS FOR YOU ALSO.
Posted on Aug 04, 2007
  • 192 Answers
SOURCE: Bottom thread will not catch
Unplug the machine and remove the needle plate so that the bobbin case if fully exposed. Lift out the bobbin case and the cup that it sets in will be visible. Locate the "hook" on this cup. It is a finger with a sharp point at the upper edge of the cup. The hook is what grabs the thread from the needle while sewing.
  • Thread the needle.
  • Turn the handwheel by hand.
  • Watch the hook as it approaches the needle from right to left.
If the hook passes by the needle AFTER the eye of the needle is above it, you timing has slipped and the machine must be taken in for repair.
If the hook catches the thread from the needle, put everything back together and try threading again.
Posted on Nov 14, 2007
bargainbox
  • 1388 Answers
SOURCE: thread catches on hook race
FIRST:
Are you sure you are using the supplied bobbins and not just any old thing that came from another machine ??
Bobbins from different manufacturers (even models from one manufacturer) will vary in diameter and height and as they don't fit properly, will present this symptom.
If the bobbins are OK, then..........
With such a new machine my first port of call would be the retailer where you purchased......quick phone call and arrange for them to have a look at it.
If it was a cash & carry store with no service technician, ask for a replacement, and they will have to sort out their return and credit with manufacturer.
Take your samples with you to show them, this may reveal the troubles to a trained eye.
There are rare occasions where settings may not be correct when a product leaves the factory, unfortunate, but if caught early and it is a warantee issue it should be very easy to repair/exchange.
Bargain Box
Posted on Jan 30, 2008
SOURCE: needle will not pick up bobbin threat
I had the exact same problem. The timing is off. You can actually fix this yourself all you need is an allen wrench. If you look at the rod the needle is inserted into and follow it up to about 2 inches below the top of the machine there should be a clamp. use the allan wrench to loosen the clamp and adjust the needle height. I used this website as a guide to getting the timing correct. http://www.sewusa.com/Sewing_Machine_Repair/Repair_Pictures/timing1.gif
now if only I could figure out why my thread keeps getting jammed under the bobbin!
Posted on Feb 22, 2008
Zenqi
  • 208 Answers
SOURCE: needle not picking up bottom thread
Remove the needle plate and the bobbin case.
Ensure that the needle is inserted all the way up into the needle clamp.
Set the machine for straight stitch, center needle position.
Slowly turn the handwheel in the normal sewing direction and observe the following hook timing setting:
When the needle reaches it's lowest point and travels up 3.5mm, the point of the hook should be directly behind the needle, or at least within 1 or 2mm.
Another view is as the hook passes the needle, it should pass the needle slightly above the eye of the needle.
If the timing looks good, use some alcohol on a bit of cloth to clean the hook, careful around the tip of the hook as it is very sharp.
If the hook timing is off, you will need to take it to a knowledgeable service person as there are several possible solutions and several other related adjustments which will need to be made.
Posted on Jan 16, 2010
Hello, I recently purchased a brother lx3817 sewing machine and it works but doesn’t stitch, what could be the problem
hi Desiree.
this is all i could find out.
There could be several things that could cause the machine not to pick up the bobbin thread.
  • The upper thread could be tangled.
    Remove the thread completely from the machine.
    The correct size spool cap should be used for the size of the thread spool.
    Re-thread the machine according to the directions in the manual.
One Point Advice Place a spool of thread on a spool pin.
One Point Advice Upper threading
  • Remove the bobbin and make sure the bobbin is threaded properly in the shuttle race.
    Remove any loose threads or lint in the shuttle race.
One Point Advice Installing a bobbin into a bobbin case
  • You could be holding the needle thread too tight.
    Hold the thread lightly to keep the end from going down into the shuttle.
  • The needle could be thread incorrectly.
    Thread the needle eye from the front to the back.
  • The needle could be bent or improperly inserted.
    Install a new needle with the flat side of the needle facing the back.
or this link might help you out some more.
Why won the machine pick up the bobbin thread Brother
or this one.
brother lx3817 sewing machine doesnt stitch Google Search
Dec 06, 2017 | Brother Sewing Machines
The upper thread becomes jammed inside the lower track of the shuttle. What can I do?
Try a brand new needle. Change thread. Make sure the needle is installed facing the correct direction and is pushed all the way up. The upper tension may be too loose.
Short of that, could be the machine's timing is off.
Dec 16, 2015 | Euro-Pro Shark by Euro Pro Sewing Machine
My needle won't grab the bobbin thread
Please put on correct size needle. And check the tension & timings.
Jan 02, 2014 | New Home HF-106
Shuttle race wont move
We don't know what machine you have.
Jan 25, 2018 | Sewing Machines
I am sewing scout badges on a uniform and when I sew there is a bunch of needle thread bunched up on the bottom (the top looks fine). And the needle thread gets all caught up around the bobbin.
Clean out the bobbin area if there are any thread tangles there.
Refer to the maintenance section of the manual - see the configuration of the bobbin case and shuttle race? The bobbin case as an extending arm and the race a notch. When inserting the bobbin case into the shuttle, turn the handwheel so the needle is at it's highest position. Then lift the lever on the back of the bobbin case and insert the cast into the shuttle, arm pointing straight up toward the bed of the sewing machine.
Now thread the machine with the presser foot up - always - and see if the tangling stops.
When you forget to lift the presser foot before threading the machine, the tension control does not open to capture the thread. Then when you begin to sew, the top thread has no tension, and the bobbin thread, which does have tension, pulls the top thread to the bottom in messy loops.
Jun 25, 2011 | Kenmore Sewing Machines
Singer Model 6233 While sewing the bobbin cas...
If you broke a needle and cannot get it to pick up the thread from the bobbin you need to check your timing. Remove the needle plate and turn the machine over watching the needle, when it is at the bottom of its travel the hook on the shuttle should be right next to or a fraction from the needle. So that as the needle begins to move upward the hook should pass it if it passes to soon it will miss the loop of thread. Check to make sure your needle is installed all the way up in the bar. If your machine is out of time and you are fairly handy, you can retime it. There should be 2 set screws some where behind the shuttle. Loosen them, one loose and one only as loose as need be to turn the shuttle. The needle must have moved upward about 1/16 before the hook is in place to catch the loop. This can be time comsuming, and you will have trial and error. Good luck. P.S. always check for simple stuff before you go for the hard stuff.
May 20, 2010 | Sewing Machines
The needle does not pick up the bobbin thread
Hi!
There may be so many reasons due to which the needle does not pick up the bobbing thread like---
The upper thread could be tangled. Remove the thread commpletely from the machine. The correct size spool cap should be used for the size of the thread spool. Re-thread the machine. Remove the bobbin and make sure the bobbin is threaded properly in the shuttle race. Remove any loose threads or lint in the shuttle race. You could be holding the needle thread too tight. Hold the thread lightly to keep the end from going down into the shuttle. The needle could be thread incorrectly. Thread the needle eye from the front to the back. The needle could be bent or improperly inserted. Install a new needle with the flat side of the needle facing the back.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 08, 2009 | Euro-Pro 9105 Computerized Sewing Machine
Machine problem
Hi!
There are so many reasons due to which the thread is not picking up from the bobbin like:
The upper thread could be tangled. Remove the thread completely from the machine. The correct size spool cap should be used for the size of the thread spool. Re-thread the machine. Remove the bobbin and make sure the bobbin is threaded properly in the shuttle race. Remove any loose threads or lint in the shuttle race.
The needle could be threaded incorrectly. Thread the needle eye from the front to the back.
Do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 01, 2009 | Bernina Activa 130
Bobbin and shuttle case pop out of machine .
You might need to clean the shuttle assembly.
1. Raise the needle bar to its highest position and remove the bobbin case.
2. Push levers sideways of the shuttle assembly and liftshuttle and shuttle race cove out by the center pin.
3. Clean the shuttle race of any lint or small particles of thread with a small brush.
4. Put a drop of oil on the center pin of the shuttle and on the shuttle race.
to reassemble, hold sjuttle by center pin and it carefull into assembly opposit the shuttle driver. Slip shuttle race cover into place. Snap the levers into position.
Occasionally remove the needle plate and clean feed dog with soft brush.
I hope that helps!
Apr 23, 2009 | Brother LS-2125 Mechanical Sewing Machine
Needle won't grab bobbin thread
Check the position of the needle. Some machines have to have the needle in a certain way or they won't pick up the thread from the bobbin. Make sure the screw on the bobbin is tight but not to tight you may have to adjust it a few times to get it where it needs to be. Also make sure the bobbin is wound tight
Jun 17, 2008 | Kenmore 15208 Mechanical Sewing Machine
Sewing Machines Logo
35 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
